Author Topic: SHARP PRIMO 20V-R75M  (Read 1144 times)
Offline DSM_elektronix_shop
  • Pogi/Ganda Points: 153
Re: SHARP PRIMO 20V-R75M
« Reply #40 on: May 28, 2012, 10:35:36 AM »
congrats
DSM_electronics_shop
Alvin Y. Carulasan
Sinal Village, Taguig city
Offline junex
« Reply #41 on: May 28, 2012, 10:38:47 AM »
malayo pa yan sa system ic, bear in mind protected yan in terms of volt current and heat, sa deflection ka
muna mag concentrate, nag oscillate naman diba, back to stanby mode lang ang kaso
ibig sabihin, ok ang system kasi may na detect syang faulty component kaya nag hinto sya osc,
ngayon hanapin mo yon faulty component ex: resistor ecaps at iba pa, sa may horintal at vertical at crt.
go go na
maraming salamat. sis sodz,,, hindi ko pa alam paano magbigay ng pogi points,,, Godbless
Offline mcleod
  • Pogi/Ganda Points: 142
« Reply #42 on: May 28, 2012, 10:46:06 AM »
congrats ts! To give pogi / ganda points; click "recharge" under my name, ganun lang kadali!
 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Offline sodz
« Reply #43 on: May 28, 2012, 11:32:39 AM »
congrats ts, share mo pano mo nadali fbt?
« Reply #44 on: May 28, 2012, 12:01:04 PM »
pinalitan siguro fbt....;D ;D ;D malamang
Alvin Y. Carulasan
Offline junex
« Reply #45 on: May 28, 2012, 02:25:42 PM »
bumaba kasi yung b+ pag oscillate,, nacheck ko na rin lahat ng output ng fbt at hinang ko isaisa, pero magshotdown parin kaya nagdecide ako nagload ang flyback nito,, kaya pinalitan ko
« Reply #46 on: May 28, 2012, 04:54:09 PM »
baka naman nagdodrop ng supply or nag oover load kapag nakakabit??????????????
Alvin Y. Carulasan
Offline alphavic
  • Pogi/Ganda Points: 27
  • Alphavic Communication
« Reply #47 on: May 28, 2012, 09:49:35 PM »
hehehehe!yung FBT abl pin nagiging mag-asawa sila ni ground pag going osc.!kaya pala bumabagsak si B+! anyway congrats TS ;D ;D
selfish ka o duwag ka lang ma failed?
Offline junrosido
« Reply #48 on: May 31, 2012, 08:51:53 AM »
may short circuit yan sa flyback  or hi voltage section bro.magcheck ka ng mga open resistors din mga leak na zener mga short/leak na transistors.pag nakita mo na mga ito ang nasira.palit ka ng mga filter e caps din dahil ito ang mga sanhi ng mga pagkasira ng mga piyesa kumbaga sila ang mga pinagmumulan ng parts failures.
Offline gegeiboy
« Reply #49 on: July 10, 2012, 10:17:49 AM »
try mo hang ung protect transistor,q603 colector...
