Author Topic: SHARP PRIMO 20V-R75M  (Read 1145 times)
  • Pogi/Ganda Points: 315
Re: SHARP PRIMO 20V-R75M
« Reply #20 on: May 18, 2012, 09:49:08 AM »
^ mga resistor na malapit sa flyback minsan.
Offline junex
« Reply #21 on: May 18, 2012, 11:46:10 AM »
na check ko na rin lahat master ryu wala namang change value, opeb short.
Offline junex
« Reply #22 on: May 19, 2012, 10:36:28 AM »
paambon naman ng schematic diagram mga master
thanks
Offline DSM_elektronix_shop
  • Pogi/Ganda Points: 153
« Reply #23 on: May 19, 2012, 11:02:27 AM »
check RGB voltage during on...
check krvoltage,kg voltage and kb voltage..yan ang salarin ng ginawa ko dati isang driver ng rgb ang leaky...
ill send you schema wait for the link
DSM_electronics_shop
Alvin Y. Carulasan
NCII certificate holder# 1013160220767
PRC (ECT) Lisence Number# 0001237
Sinal Village, Taguig city
« Reply #24 on: May 19, 2012, 11:20:54 AM »
Alvin Y. Carulasan
Offline junex
« Reply #25 on: May 21, 2012, 11:19:41 AM »
salamat sir try ko,,, magupdate lang ako mamaya,,,, Godbless
Offline m@r
  • Pogi/Ganda Points: 59
« Reply #26 on: May 21, 2012, 11:34:36 AM »
parang di pa napalitan ang B+ ecaps nito ah!
http://www.4shared.com/rar/h7r05FaP/SHARP21VR70m75m.html
pm mo ko para sa passcode
sir DSM baka pwede rin paambag na rin sa passcode para sa mapa..?
it's not how much what we have but it's how we used what we have...
Offline ultimate
« Reply #27 on: May 22, 2012, 05:01:04 PM »
back to standby mode ulit seguro to after mag oscillate? check mo din protect circuit baka sakali, d603
  • Pogi/Ganda Points: 142
« Reply #28 on: May 22, 2012, 08:06:58 PM »
sundin sa itaas ko. damay po pati transistor katabi near optocoupler ata ito.
pag di pa nadale, basahin mo yung mga nasa ibaba nito topic!  ;D
Offline alphavic
  • Pogi/Ganda Points: 27
  • Alphavic Communication
« Reply #29 on: May 25, 2012, 02:36:49 AM »
paumanhin kung iba yung chassis
D1004= LEAK (replace 1n4148), R604= 39k (replace)= swak!!!
selfish ka o duwag ka lang ma failed?
Offline junex
« Reply #30 on: May 27, 2012, 01:39:59 PM »
Good day sis parang walang d1004 na parts sa board ko,,,napalitan ko na ecaps sa b+ ganon pa rin.
Offline sodz
« Reply #31 on: May 27, 2012, 01:47:51 PM »
isa isahin mo kaya mga resistor i check , i hang resistor 1 leg tapuz resistance check malapit sa fbt
1/4 watts pataas ha, sana ma solve na.
Offline junex
« Reply #32 on: May 27, 2012, 01:50:57 PM »
cge sis, hindi kaya ang system nito sis yong malaking ic na smd?
« Reply #33 on: May 27, 2012, 01:53:50 PM »
yung sinubo na D603 na check mo na? isama mo D602, Q603 sa checklist. + R602, R603, R604 at R605 puro high value resistor yan.
Offline sodz
« Reply #34 on: May 27, 2012, 02:39:02 PM »
malayo pa yan sa system ic, bear in mind protected yan in terms of volt current and heat, sa deflection ka
muna mag concentrate, nag oscillate naman diba, back to stanby mode lang ang kaso
ibig sabihin, ok ang system kasi may na detect syang faulty component kaya nag hinto sya osc,
ngayon hanapin mo yon faulty component ex: resistor ecaps at iba pa, sa may horintal at vertical at crt.
go go na
Offline alphavic
« Reply #35 on: May 27, 2012, 03:10:22 PM »
x-prot ata ito sis! abl sec. pakisuyud para makita ang salarin!including yung mylar cap 563k ata yun!
Offline alphavic
« Reply #36 on: May 27, 2012, 03:51:47 PM »
sorry doublepost! backread po ako bumabagsak pala yung HOT mo, cap 563k po paki check maigi baka may leak, tsaka q603 dapat wala talagang leak, kung meron sigurang prot yan. kung hindi pa nakapagsuyud sa C board paki include nalang po sis baka nandoon ang isang salarin! :D :D :D
Offline m@r
« Reply #37 on: May 27, 2012, 11:49:09 PM »
ano na kaya update nito?
« Reply #38 on: May 28, 2012, 08:41:46 AM »
congratss...
Offline junex
« Reply #39 on: May 28, 2012, 10:29:32 AM »
at last na dali na rin,, flyback ang sira, nagload cya,,,
sa lahat ng mga master ,, mga sis,, maraming salamat sa mga advice , tips,, ninyo
thank you very much, tkcre, Godbless
