Author Topic: [help]paano malalaman voltage ng zener diode  (Read 484 times)
Offline turotoknis
  • Pogi/Ganda Points: 14
Re: [help]paano malalaman voltage ng zener diode
« Reply #20 on: May 18, 2012, 05:13:35 PM »
i see, in case na you want to reconsider eto data sheet ung c** lang nagkakaiba, baka posible din na di na nilagay yun
http://pdf1.alldatasheet.com/datasheet-pdf/view/61997/GE/BZX55-C10.html
tnry ko bumili 10 volts... ang binigay sken kulay silver na zener diode, IN 5240B nkasulat,  same lang daw
mas panget mas maganda, mas maganda mas panget
Offline mcleod
  • Pogi/Ganda Points: 143
« Reply #21 on: May 18, 2012, 06:10:05 PM »
google.com _____________ 1N5240B datasheet [enter](di nga pala I yun number 1; di ba ang transistor 2Sxxxx)
para mapadali oo 10 V siya. http://www.datasheetcatalog.org/datasheet/fairchild/1N5240B.pdf
