Author Topic: canon iP2700 series The ink absorber is almost full error  (Read 3864 times)
Offline de PatAtas
  • Pogi/Ganda Points: 332
  • ' The unbreakable
« on: May 21, 2012, 04:11:39 PM »
' palaging lumalabas...
' action taken... enoperahan ang printer hinugasan ng running water ( sa gripo ) tapos pinatuyo binilad sa araw... 4 half day... then enistall again..
 ang result.. " canon iP2700 series The ink absorber is almost full  error again..
another action.. reset printer,..
 ang result .. " canon iP2700 series The ink absorber is almost full  error..
 history... nag overflow ang black ink naligo ng ink ang luob ng  printer pati kamay ko na rumi2x ( buset )... eninject ko kasi ng hangin... ayaw kasing
mag flow ng ink sa tube/hose...
' ano pa kaya ang dapat gawin dito... bago ko itapon to... ;D
  • Pogi/Ganda Points: 369
  • Design, Engineer, Create electronics circuits.
Re: canon iP2700 series The ink absorber is almost full error
« Reply #1 on: May 21, 2012, 04:13:31 PM »
anong resetter software ginamit mo sir?
Offline nucleus
« Reply #2 on: May 21, 2012, 04:13:41 PM »
linis lang talaga yan at reset
« Reply #3 on: May 21, 2012, 04:17:57 PM »
FIRST STEPS:  Entering Service Mode
You have to enter in service mode in order to used the resetter. To do that follow this procedure,
1. Turn off the printer without pulling the power cords.
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Then Press Resume button 5 times then let BOTH buttons go.
5. You will notice that the Alternate Blinking error is gone, this means that the printer is in Service Mode state.
SECOND STEPS: Using the Resetter
1. After you download the resetter, extract it and double click "servicetool.exe"
2. Press the "Main" Button, Then press "EEPROM Clear" button if a pop-up appear just click OK
5. Then power off the printer(sometimes you have to press twice the power button to turn off) and turn on again. and its done!
« Reply #4 on: May 21, 2012, 04:19:01 PM »
Credits to.. :
hXXp://pcmediks.blogspot.com/2010/10/how-to-reset-canon-pixma-ip2770.html
Offline de PatAtas
  • ' The unbreakable
« Reply #5 on: May 21, 2012, 04:23:01 PM »
' wala akong ginamit na resseter,, di kasi available ang ganitong model ,, kaya ito ginawa ko
Put the printer in service mode
 To apply this software you have to put the printer in service mode:
Switch off the printer
Push and hold the "Resume" button
Push and hold the "Power" button
Hold both buttons for about five seconds
Let go of the "Resume" button
Press the "Resume" button twice
Let go of the "Power" button
' nilinis ko nman ah... yung buong loob ng printer,,,  no effect may sensor kaya ito,, na pweding bulagin ;D
« Reply #6 on: May 21, 2012, 04:25:31 PM »
yung pinost ko na PCM_servicetool.rar ang gamitin mo.
ganyan talaga canon printers. tulad nang printer ko ngayon ip1980 pero gamit kong eeprom resetter is yung pang ip1900.
Offline nucleus
« Reply #7 on: May 21, 2012, 04:26:19 PM »
available ang pang reset nito, napost na ni sis martina sa taas.
Offline de PatAtas
  • ' The unbreakable
« Reply #8 on: May 21, 2012, 04:31:59 PM »
' ok,,, na Dl ko na po,,, e try ko po gamitin salamat pla sir insomartin
Offline de PatAtas
  • ' The unbreakable
« Reply #9 on: May 21, 2012, 04:43:53 PM »
' ganon pa rin...
Offline j a y k e z
  • Pogi/Ganda Points: 185
  • gimmegaggigsss
« Reply #10 on: May 21, 2012, 04:59:33 PM »
pa subs ;D
resetter soft lang kelangan nito,
search ka sa google master fatatas,
Offline nucleus
« Reply #11 on: May 22, 2012, 12:58:10 AM »
' ganon pa rin...
screen shot ng pagkareset :)
Offline >>>???<<<
  • Pogi/Ganda Points: 545
« Reply #12 on: May 22, 2012, 11:42:35 AM »
' ganon pa rin...
Woi master patatas ganito added procedure gawin mo. Habang buo pa yung printer mo ipadetect mo sa computer tapos test print. Kapag error tanggalin mo na. Tapos linis ng loob.
Balik mo uli. Reset mo via software o key combi. Tapos padetect mo uli. Kapag error pa rin. Shutdown mo computer habang nakakabit pa printer.(Additional kung di nakuha sa una na nakaon ang printer sa sunod i-off mo rin) Tapos reboot mo uli. Tapos padetect or test print.
Kapag di pa rin reset printer three times. Baka makuha sa ganto.
http://www.elab.ph/forum/index.php?topic=41860.0 My DIY transformer... ? ? ? Test Build Uli
http://www.elab.ph/forum/index.php?topic=33717  I2c / spi programmer
http://www.elab.ph/forum/index.php?topic=37150.0 Lcr esr makikigulo rin ba kayo ??? Test Build
http://www.elab.ph/forum/index.php?topic=29963.0 Esr collection na malamig
http://www.elab.ph/forum/index.php?topic=25854.0 Basic C++ Programming Tutorials by Prof Asimo
3T LTB DIY P50 tunogsarilingsikap
Offline de PatAtas
  • ' The unbreakable
« Reply #13 on: May 22, 2012, 12:35:03 PM »
' ok try ko po ulit... kasi kahapon mga 20 times ko na na reset yung printer mismo... at saka yung software na pang reset... yung may effron clear...
Offline de PatAtas
  • ' The unbreakable
« Reply #14 on: May 23, 2012, 11:28:22 AM »
' update ko lang po... nadagdagan po ang sakit ,,, after mg print ng isang page ,,, nag jajam paper jam..
Offline >>>???<<<
« Reply #15 on: May 23, 2012, 04:43:24 PM »
Hmmm napapaisip na ako dyan sa printer mo, ang arte.  ???  :D
  • Pogi/Ganda Points: 482
« Reply #16 on: May 23, 2012, 10:23:07 PM »
bumili ka na ng bago..yung sakin tinapon ko na...:P
di ko alam bat nag overflow yung black..whatta mess! 3 points sya sa basurahan...;D
Offline >>>???<<<
« Reply #17 on: May 23, 2012, 10:43:13 PM »
Sa ibang forum dapat daw service mode tapos saka gamitin ang resetter soft.
Offline de PatAtas
  • ' The unbreakable
« Reply #18 on: May 24, 2012, 03:43:09 PM »
' oo nga surrender na ako ;D
' kakahuyan ko nlang,,, tapos bili nang bago
' nka service mode po ako sir nung nag reset..
Offline Macoy8932
« Reply #19 on: May 24, 2012, 03:57:50 PM »
hmmm kung paper jam po baka nasupress ang movement ng line ng continues ink papaunta sa cartridge..
