Author Topic: Gizduino 168 or 328?  (Read 614 times)
Offline JojoD818
  • Pogi/Ganda Points: 23
  • Rest when you're dead...
    • JD Labs Projects
Re: Gizduino 168 or 328?
« Reply #20 on: May 22, 2012, 01:57:32 PM »
Ok ANITO is just like Arduino pero may customized IDE and will be one of the collaboration project of PHILROBOTICS
as for GIZDUINO and ARDUINO we are same NEWBIE ;D ;D ;D
Kung may spare cash ka bili ka na din ng Universal Trainer from E-GIZMO GIZDUINO
I believe Sis Akhen is also working with some s exercise manula for it
Thanks for the info master! :)
Well, Arduino or Gizduino will be my first try with microcontrollers. I was so amazed by the amount of support and tutorials I found in the net, fits well to noobs like me. I'm not new to electronics, but I'm so alien with MCUs. ;D ;D ;D
Yep I saw the Universal Trainer ni Sis Akhen in another thread, ganda at mukhang kumpleto na. The Universal Trainer will have to wait until next month (next 15th payday ;D), sabay na sa pasukan ng mga bata lahat ng gastos ko sir hehehe...
« Reply #21 on: May 22, 2012, 01:59:55 PM »
Gawa yan nila sir. PhilRobotics version of ARDUINO ata. ;D Tama po ba master supremo? ;D
again, its an arduino inspired project.. it was developed by the members of philrobotics from scratch(hardware, software and firmware library) ;)
Sample Program:
Code: [Select]
unsigned int uiTimerToggleLED = 0; //Create a Variable,
  void init()  //Initialization
       /* Builtin components doesnt need to configure Pin Direction */
       setPinLow(LED1); //set Builtin LED to Low
       setPinLow(LED2);
       setPinHigh(LED3); //set Builtin LED to High
       setPinHigh(LED4);
       setPinOutput(PIN0); //set Pin0 to Output
       setPinInput(PIN1); //set Pin1 to Input
       setPinHigh(PIN0);  //set Pin0 High (Output Logic 1)
       setPinHigh(BUZZER); //set Builtin Buzzer High (Enable/turn on)
       uiTimerToggleLED = getTimeMs();  //Initialize Timer, get Current time in milliseconds
  void program() //Main User Program
       if(getElapsedTimeMs(uiTimerToggleLED) >= 1000){ //Check if 1s lapsed
               togglePin(LED1);  //Toggle Builtin LEDs
               togglePin(LED2);
               togglePin(LED3);
               togglePin(LED4);
               uiTimerToggleLED = getTimeMs();  //Reset Timer
       if(isPinLow(SW1)) //Check builtin Button1 State (Active Low)
               setPinLow(BUZZER); //set Builtin Buzzer Low (Disable/turn off)
       else if(isPinLow(SW2)){ //Check builtin Button2 State (Active Low2
       if(isPinLow(PIN1)){ //Check Input Pin1 State (Active Low)
               setPinLow(PIN0); //set Pin0 Low (Output Logic 0)
       else{
Offline JojoD818
    • JD Labs Projects
« Reply #22 on: May 22, 2012, 02:23:52 PM »
wow very nice!  8)
Offline Mayor Johnaray
  • Pogi/Ganda Points: 238
« Reply #23 on: May 22, 2012, 04:22:59 PM »
OT
Sis JojoD818... ikaw ba yung na feature sa Philippine Star yung CNC machine? nakita ko kasi sa ibang POST mo JDLABS
Offline JojoD818
    • JD Labs Projects
« Reply #24 on: May 22, 2012, 04:28:10 PM »
OT
Master Supremo... Yup ako nga yun na feature sa Philippine Star and my diy CNC machine. :)
« Reply #25 on: May 22, 2012, 04:47:28 PM »
^ Natuwa ako at nakalagay din doon na bumibili ka din ng parts sa EGizmo ;D ;D ;D
teka bakit di ka namin maabutan doon
Offline JojoD818
    • JD Labs Projects
« Reply #26 on: May 22, 2012, 05:04:15 PM »
Yup, yun mga stepper motor drivers ko at parallel port breakout board from eGizmo yan sir! ;)
Minsan na ako nasiraan ng isa (X-axis) kaya bumili ako ulit sa eGizmo, nagkataon naman na dala ko yun sira and pwede pala ipa-repair so yun ang babalikan ko sabay bili ng Gizduino... ;D ;D ;D
From Valenzuela pa kasi ako sir, napapadaan lang ako ng eGizmo pag pumapasok ako ng Makati sa www.diyAudio.com, head engineer at chief for special projects ako doon. Kaya usually opening pa lang sa eGizmo nandun na ako sir hehehe...
Offline JojoD818
    • JD Labs Projects
« Reply #27 on: May 24, 2012, 08:55:22 PM »
got my Gizduino 328 this afternoon! yeebah!  ;D
