Author Topic: ano STKxxxx na amplifier IC preffered ninyu??  (Read 1543 times)
Offline tiktak
  • Pogi/Ganda Points: 204
    • Tiktakx's Blog
Re: ano STKxxxx na amplifier IC preffered ninyu??
« Reply #20 on: May 23, 2012, 09:29:28 AM »
Meron ako dito STK4235MK2 that came from an old Sharp mini compo, niloadan ng may ari ng 0ohms :D wala na ako makuha pinalitan ko nalang ng Laguisma, 100W + 100W ito ayun sa datasheet nya
8051 stuff
Offline acer
  • Pogi/Ganda Points: 117
« Reply #21 on: May 23, 2012, 09:31:35 AM »
subs
nevergive up
  • Pogi/Ganda Points: 321
« Reply #22 on: May 23, 2012, 09:32:30 AM »
dapat ginawa mong COB na din yung laguisma.
Offline 01110011
  • Pogi/Ganda Points: 101
« Reply #23 on: May 23, 2012, 09:37:53 AM »
yung pioneer na component dito sa bahay SX-P730 na model, STK4140MKII yung IC nya
  • Pogi/Ganda Points: 324
« Reply #24 on: May 23, 2012, 11:04:41 AM »
klaro din sa markings , ung letter K ung basehan ko.
minsan sa likod din ng IC (orig) ung alum, side may numero ex. STK4142E2A9E
« Reply #25 on: May 23, 2012, 11:26:35 AM »
yung fakes na stk is
white silicone instead of potting epoxy sa main transistors.
usually Cob ang small transistors and carbon film printed yung resistors
kapag SMT yung transistors malamang na fake.
« Reply #26 on: June 19, 2012, 10:23:26 PM »
nahalungkay ko ung STK4152 ko ;D
mura nlang pala sa newport ung STK4192 (50WATTS)
last year bumili ako sa deeco sa raon ng stk4192ii sa halagang 350 each....50w stereo ito...
sir ung vid mo na STK4050. maganda din ba ung SQ?
ung STK4192 pinag iisipan ko pa sa newport. mas mura kasi kaysa dito sa amin.
kaso ayon sa datasheet, 52.5vdc max.
traffo ng 502 gagamitin ko.
convincing din ung TDA7293.
Offline 01110011
« Reply #27 on: June 19, 2012, 10:46:53 PM »
hirap hanpin yung tda7293 ayun sa iba mas maganda pa daw tunog ng stk ics kumpara sa mga multiwatt packaged na amplifier ics
« Reply #28 on: June 19, 2012, 10:51:21 PM »
thanks +1
kandidato din to
http://www.steveselectronics.com/files/STK402-120.pdf
darlington ung output.
Offline efren
  • Pogi/Ganda Points: 211
  • old school audio fanatic
« Reply #29 on: June 19, 2012, 11:40:13 PM »
yung sa pioneer na VSX model na mini compo, di ko na matandaan number pero STK din sya, ang pangeeeet :P  ng  tunog kahit anong speaker ikabit sa kanya ;D ;D
"just keep 'em glowing"
« Reply #30 on: June 19, 2012, 11:41:35 PM »
^ napapa isip na naman ako nito ;D ;D ;D
Offline efren
« Reply #31 on: June 19, 2012, 11:49:45 PM »
sa parents ko yan, napalitan na nila nung bumigay yung 3 CD changer/player, bumili ng Kenwood worth 40+K di pa rin pumasa sa panlasa ng tenga ko ;D kaya binigay ko yung EL84 SE amp ko, para pag pumapasyal ako yun ang pinakikinggan ko, ayun mas madalas gamitin ni utol ;D
Offline 4XFOUR
  • Pogi/Ganda Points: 30
« Reply #32 on: June 20, 2012, 10:38:54 AM »
yung sa sony rv-600d, STK402-100S pangit ng bass...
ano kaya problema nito, pag ON naka power protect na?
3rd Island Epicenter
Officially Deployed
Offline jaguar3275
  • Pogi/Ganda Points: 131
  • BAKLA LANG ANG MAGTAMPO AT MAG EMOT2X!!!
« Reply #33 on: June 20, 2012, 02:22:10 PM »
Stk4182II mayron ako, baka maydatasheet kayo nito?
Exodus 15:2 The LORD is my strength and my song, and he has become my salvation; this is my God, and I will praise him, my father’s God, and I will exalt him.
Offline 4XFOUR
« Reply #34 on: June 20, 2012, 02:36:16 PM »
http://www.datasheetcatalog.org/datasheet/sanyo/STK4182.pdf
kasama na PCB layout nyan
tsaka may sample protection circuit, muting circuit at thermal shutdown
Officially Deployed
Offline jaguar3275
« Reply #35 on: June 20, 2012, 02:53:58 PM »
thanks point sis...
Offline 01110011
« Reply #36 on: June 20, 2012, 05:40:31 PM »
yung sa tatay ko PSX7300 model na pioneer, maganda naman tunog hindi ko lang nasilip yung loob ayaw ng dad ipabukas kasi, baka pagexperementuhan ko daw, retired na ngayon, napalitan na ng b&w na component
Offline mund24
  • Pogi/Ganda Points: 37
  • Certified Boy'z
« Reply #37 on: June 20, 2012, 08:49:45 PM »
true
mas trip ko sounds ng STK VS multiwatt
mine from old Promac Karaoke using STK4152 nung nasira because of fault line, ayun pinalitan ko ng STK4192II, OK na OK ang tunog nito, mas trip ko eto VS sa LM3886 regards sa sound
as of now sa lahat ng amp ko eto ang pinaka trip kung tumunog! oh siguro nasanay lang tenga ko dito since eto ang pinaka old  since 1997 :)
isa eto sa mga pinagpraktisan ko :)
anyway ang taas ng gain ng mga eto kalimitan nasa 100  :o
Offline Tukkar
  • Pogi/Ganda Points: 27
« Reply #38 on: June 21, 2012, 09:55:31 AM »
mine from old Promac Karaoke using STK4152 nung nasira because of fault line, ayun pinalitan ko ng STK4192II.
Meron ako stk4192II dati umaandar kaso ng ginawa ko yung pcb sa datasheets di na umandar...i've check all the layout with respect to schematics and seems correct....pero pag saksak lagi blown out yung fuse ng PS....tama ba yung layout sa Datasheets?
Talagang mataas ang gain ng mga ito...sinubukan ko minsan babaan kaso parang nag o-oscillate sya...
Offline mund24
  • Certified Boy'z
« Reply #39 on: June 21, 2012, 10:46:34 AM »
baka shorted na OP tran ng IC sis?
tama naman yung shematic sa Sanyo
from STK4152 - STK4192 may pinalitan lang akong resistor may pin sa 5 and 15
