Author Topic: ask lang po may damper diode ba ang TT2222?  (Read 232 times)
  • Pogi/Ganda Points: 776
« on: May 24, 2012, 02:40:41 PM »
TT2222 horizontal output ng samsung ultra flat
wala pa kasi sa net ang datasheet nito
Offline Johannah Aleksandria
  • Pogi/Ganda Points: 138
  • Make it simple
Re: ask lang po may damper diode ba ang TT2222?
« Reply #1 on: May 24, 2012, 03:20:05 PM »
Look for TT2202, maaring pareho lang sila sis, at meron itong damper diode.
Gawa ng Sanyo yung TT2202.
« Reply #2 on: May 24, 2012, 03:25:31 PM »
nag try ako ng tt2190 may • On-chip damper diode. pero bakit walang diode yung actual na transistor hay naku china talaga
Offline Min
  • Pogi/Ganda Points: 212
« Reply #3 on: May 24, 2012, 03:29:57 PM »
Pati ba naman sa mga pyesa gumaganti satin ang china? ;D ;D ;D
Offline gorex
  • Pogi/Ganda Points: 47
« Reply #4 on: May 24, 2012, 03:34:37 PM »
philips na parts gamitin mo yung me damper diode kasi pag tsina madami peke. ito sa HOT Philips BU 2508AF
« Reply #5 on: May 24, 2012, 04:41:39 PM »
madali po mag replace ng parts or replace ng part # but may problem here i'm not sure kong may damper diode ang TT2222.. thank you
  • Make it simple
« Reply #6 on: May 24, 2012, 04:47:22 PM »
Pag TV nman may damper yata tlaga, pero tignan mo kung nasa labas, hindi on-chip.
Offline gorex
« Reply #7 on: May 24, 2012, 05:04:08 PM »
built in ang damper diode sa iba pre nasa loob ng transistor ang HOT. yung philips di built in damper diode yung 2508af kanina na sinabi ko.nakita ko sa datasheet. walang datasheet ang tt2222 sa inet di kk nakita
Offline Min
« Reply #8 on: May 24, 2012, 05:10:08 PM »
Meron din kasi few HOT na wala damper diode, kaya gusto makasiguro ni sir pete.
« Reply #9 on: May 24, 2012, 05:17:41 PM »
tama halus same kasi ito sa LG yung ultra slim walang damper yung flat  lang may damper pero same board chassis
