Author Topic: PCB Toner Transfer Using CD/DVD Label & Laminator  (Read 1587 times)
Offline ♪ ♫ ♫ ♪ ♪ ♪ ♫ ♫ ♫
  • Pogi/Ganda Points: 124
Re: PCB Toner Transfer Using CD/DVD Label & Laminator
« Reply #20 on: May 25, 2012, 02:18:50 PM »
+1 kas!
bat 15 passes sis? kailangan pa bang painitin yong pcb copper?
  • Pogi/Ganda Points: 414
« Reply #21 on: May 25, 2012, 03:07:29 PM »
^ dapat mainit talaga yung laminator...yung READY LED nya dapat nakailaw na..
below 15 passes kasi unpredictable yung result...depende sa pcb materials na ginamit mo..
Offline efren
  • Pogi/Ganda Points: 211
  • old school audio fanatic
« Reply #22 on: May 25, 2012, 03:09:31 PM »
aba kahit pentel pen lang ok pa din
mas mabilis naman hahaha
wag ka lang manginginig sir efren
bawal pasmado nyahahaha  ;D ;D ;D
talagang mabilis sa pentel pen sir danny, pero ang pulso ko hindi na kagaya ng ako ay nasa beinte anyos palang, malaki na ang pagbabago....  ;)
"just keep 'em glowing"
« Reply #23 on: May 25, 2012, 03:14:23 PM »
nasa kanya kanyang kasanayan lang yan kasi...sakin kahit pag bend ng component leads really matter...even the orientation ng mga pyesa like resistors...metikuloso talaga..
Offline n0th1n6
  • Pogi/Ganda Points: 62
« Reply #24 on: May 25, 2012, 03:23:12 PM »
What if isalang muna sa oven toaster para ma pre heat yung board.
« Reply #25 on: May 25, 2012, 03:49:05 PM »
mahirap na ilagay yung paper if mainit..kasi dikit kaagad yun..
« Reply #26 on: May 28, 2012, 07:46:16 AM »
dapat pala preheat the pcb then presss...ganon ba ito sis kas?
« Reply #27 on: May 28, 2012, 07:54:55 AM »
Tanong ko lang sis kas,  kapag napadaanan na ng pcb yung laminator, pwede pa rin ba ito gamitin sa paglaminate ng ordinary paper, pictures or ids?
Meron din ako laminator, kaya lang gamit ko lang talaga paglaminate ng mga pictures (para di mag-fade yung kulay after so many years).
« Reply #28 on: May 28, 2012, 08:03:43 AM »
Mahirap pag preheat pa..kasi pag mainit na yung pcb instantly kumakapit yung paper..which wont allow you to adjust..sakin yung laminator lang preheat ko..
Pwede..wala naman akong binago electrically or physically..;D
pero I'm planning to mod this laminator..medyo increase ko yung init nya..
Offline Engr. Dacuycoy
  • Pogi/Ganda Points: 166
  • Proton Orcad EasyPCB User
« Reply #29 on: May 28, 2012, 08:12:45 AM »
spring loaded ang laminator. yong sa akin pinalitan ko yong thermal switch
Offline n0th1n6
« Reply #30 on: May 28, 2012, 09:32:59 AM »
de-bur lang mga edge ng pcb para di masira ang roller at ng maganda pa din gamitin sa sa PVC
  • Pogi/Ganda Points: 540
« Reply #31 on: May 28, 2012, 09:39:49 AM »
+1....these are the kinds of posting we need.....good job kaz.....
« Reply #32 on: May 28, 2012, 02:04:31 PM »
so pwede lagay o taped muna yong pattern sa pcb tapos preheat silang dalawa then preesss....ganito ba ito sis kaz?
« Reply #33 on: May 28, 2012, 04:00:34 PM »
no need preheat.. direct na sa laminator kasama ang patern. kaya mga 15 passes para kumapit sa copper ang toner (pressure ng roller is not the same in plantsa method)
Offline drx2k
  • Pogi/Ganda Points: 15
    • Drx2k Network
« Reply #34 on: May 28, 2012, 04:50:29 PM »
di pala pwede gamitin yung accetate para dun sa pattern..ayaw kumapit nung toner sa pcb kahit ilang passes at naka max temp. na yung laminating machine
« Reply #35 on: May 29, 2012, 08:39:38 AM »
slowingdown the motor feeder baka 5 passes nalang ;D
« Reply #36 on: May 29, 2012, 09:17:56 AM »
Sakin yung sensor nya isang maliit na signla diode (looks like 1N4148) nilagay malapit sa lower roller..cguro kung ilayo ko ng konti pwede ko taasan yung temp...;D
pwede..ito ginagawa ko with plantsa before..align the pattern dapat meron extra space both paper and pcb..after ma align ng maayos clip ko yung one side ng patter sa pcb then patungan ng mainit na plantsa yung copper side lng..mga 10 seconds lng..after preheat saka ko na ilalagay yung pattern..
yan din balak ko..pwede cguro lagyan ng motor speed controller to..;D
« Reply #37 on: May 29, 2012, 11:00:58 AM »
eh di halos ganon din pag binagalan.. hahaba time  ;D pag fr4 nga gamit ko 20 to 25 passes  ;D
observe nyo lang to
1. kailangang malinis pa sa labada sa tide ang copper
  a> use scrabbing material of your choice (i use very fine emery paper, it will create microscopic lines in the copper para kapitan ng toner)
  b> sabunin maigi hanggang kapit na kapit na ang tubig sa copper
2. use alcohol for final cleansing
3. never ever touch the cooper side :o
4. ito matindi...>>>>...>>> practice lang yan di ba kaz ;D
« Reply #38 on: May 29, 2012, 12:17:38 PM »
^ I concur!
the secret is..dapat yung water don't form a droplets...dapat kumapit yung water..;D
« Reply #39 on: May 29, 2012, 01:20:11 PM »
i used "Ajax" powder cleansers to scrub the copper till it becomes red-like, rinse well in running water and heat in an lpg gas stove to dry....
