Author Topic: Dell Inspiron 2600 Password Protected  (Read 1627 times)
Offline Min
  • Pogi/Ganda Points: 202
« on: May 31, 2012, 07:58:49 AM »
Mga masters patulong dito. Bios and HDD pasword protected sya. Hindi ma open, hindi ma aceess ang bios set up cannot even re format kasi access to HDD is denied. Ang lupet ng dating may ari nito. Baka maraming laman porn. ;D ;D ;D
Any GOOD suggestions?
BTW sira ung keyboard nito kaya external ang gamit ko.
Offline BhongTech
  • Pogi/Ganda Points: 152
Re: Dell Inspiron 2600 Password Protected
« Reply #1 on: May 31, 2012, 08:10:47 AM »
na try mong tanggalin ang battery ng matagal sa cmos?
Offline Min
« Reply #2 on: May 31, 2012, 08:17:09 AM »
Sir wala po CMOS batt. ung modelo na to. It was designed that way. Ni research ko isa daw option is to contact DELL to request for password they can provide it daw pero hindi ganun kadali kaylangan daw proof of ownership. Nyaaaahh....Meron din ibang site nag ooffer ng unlock code gurranteed daw effective syempre may bayad (Dollars) ;D
Syempre dn muna tayo sa free. ;D Tsaka luma na ito laptop sayang lang kasi baka magawa pa.
Offline BhongTech
« Reply #3 on: May 31, 2012, 08:22:42 AM »
opps wala nga pala. :)
naku ganyan talaga walang libre...
Offline Min
« Reply #4 on: May 31, 2012, 08:27:34 AM »
Ung HDD password naka save sa HDD tama ba sir? So kung sakali ma erase, full erase laman ng HDD possible ba na maka install na ako ng windows?
Offline Lola Baciang
  • Pogi/Ganda Points: 131
« Reply #5 on: May 31, 2012, 08:39:24 AM »
win2000 ba OS nyan sis?
Expect The Unexpected
Offline Min
« Reply #6 on: May 31, 2012, 08:46:27 AM »
Win XP sis ito, me sticker sya.
Intel Celeron 1.2G processor 256RAM
Offline Asarnako
  • Pogi/Ganda Points: 19
« Reply #7 on: May 31, 2012, 08:58:17 AM »
Hehehe!
Google up "backdoor password"....
Wuts the Bios brand ba? Ususally ire retype mo yung Bios brand..
Offline Min
« Reply #8 on: May 31, 2012, 09:03:57 AM »
PhoenixBIOS. Me mga suggestions sa EHow.com na mga backdoor passwords for this model trinay ko pero no luck. ;D
Offline Asarnako
« Reply #9 on: May 31, 2012, 09:09:23 AM »
Same prob kow noon yan... Have to pay somebody in the netfor the damn pass!
I try mo ang Bios w/ different caps... yung iba napagana kow sa ganyan... usually 7 character yan pass...PHOENIX!
Offline Min
« Reply #10 on: May 31, 2012, 09:12:00 AM »
^OK, i will try that sis.  ;D
Open parin ako other tricks and suggestions.
Offline mcleod
  • Pogi/Ganda Points: 143
« Reply #11 on: May 31, 2012, 09:35:45 AM »
o eto manood ka muna and enjoy!
« Reply #12 on: May 31, 2012, 09:44:59 AM »
Locate the Paswrd jumper on the motherboard and remove the small jumper pin from the center and outside pin.
Then insert it in the center pin and the other side outside pin. Leave it there for about 30 seconds and the put it back to the original pins.
This should reset the BIOS to the default password which is "No Password".
Assemble the case, plug the power cable in and reboot.
The system should boot without the need to enter a password.
Hope this helps.
Offline mcleod
« Reply #13 on: May 31, 2012, 09:53:36 AM »
Hope this helps.
Lola pang desktop yang tricks mo!  ;D ;D ;D walang jumper dito. at di rin pede basta remove cmos battery.
suot mo salamin at makita mo first post laptop picture!  ;D
Offline Asarnako
« Reply #14 on: May 31, 2012, 09:54:52 AM »
follow that nga pala... flushing ur BiOS... limot kow yan huh! ::)
Offline Min
« Reply #15 on: May 31, 2012, 09:57:40 AM »
Salamat sis sa mga suggestions nyo. Ita try ko yan. ;D
Meron din ako na research suggestion pero parang delkado, ihuhuli ko nlng ito, dun muna ko sa medyo safe.
eto daw
Meron din isa pa Dari'ks Boot and Nuke the purpose? eradicate any trace of data in the hard drive including password. Pero wala din gurrantee na uubra.
Anyway tnx mga masters, update ko nlng uli ito kapag totally sira na ;D ;D ;D ;D ;D ;D or.....malay natin gawa na. ;D
Offline Min
« Reply #16 on: May 31, 2012, 09:59:06 AM »
Flashing bios pwede rin option. Cno meron procedure dyan?
Offline mcleod
« Reply #17 on: May 31, 2012, 10:04:52 AM »
paano ka magfaflash kala ko bios pa lang di ka na maka-enter, mali ba intindi namin? so ibig sabihin hard disk ang may password hindi bios?
yung share ko hindi naman dangerous kasi di mo naman i-short the whole time, tap tap lang. kung shoshort mo nga ng matagalan eh sunog nga iyan.
Offline Min
« Reply #18 on: May 31, 2012, 10:14:13 AM »
Un din ang question ko sis kung pwede ma flash ang bios kahit sa ganyang condition? pwede kaya?
Actually sis nka Bios password sya at the same time naka HDD password. Lupet no? Tingin photos sa taas 2 PW. Kapag nakakabit HDD, HDD Password hinihingi. Pero remove HDD Bios password nman ang hinihingi.
« Reply #19 on: May 31, 2012, 10:15:29 AM »
eto daw
isa na to oh may pag-asa pa ;D
tanda na talaga ako tsk tsk tsk sensya na foh ;D
master password manggagaling mismo sa seller nyan baka gusto mo kontakin,kaya lang may charge na yan kasi out of warranty :D
There are web sites that publish "back-door" passwords for many different BIOS programs. Do a search.
