Author Topic: Ethernet Cables question  (Read 879 times)
Offline ΔЅịMø
  • Pogi/Ganda Points: 140
  • "Live Curious"
Re: Ethernet Cables question
« Reply #20 on: June 11, 2012, 08:04:39 PM »
medjo nahilo ako sa thread nato  ;D
pa subscribe
;D ;D ;D
Offline Super zHero
  • Pogi/Ganda Points: 73
  • That's not me but might as well be.
« Reply #21 on: July 22, 2012, 05:38:06 PM »
Twisted wire and shielded ba yung mga wires sa loob ng ethernet cable?  I'm wondering kung pwede gamitin sa video signal ito.  I don't care about the impedance at this point.
Offline Timothy Marquez Pacquiao
  • Pogi/Ganda Points: 35
« Reply #22 on: July 22, 2012, 07:20:44 PM »
 check ko files ko
I'm open to trying new ideas. Nothing ventured, nothing gained...
« Reply #23 on: July 22, 2012, 07:25:45 PM »
ito bro complete
Offline j a y k e z
  • gimmegaggigsss
« Reply #24 on: July 22, 2012, 07:29:02 PM »
^ bakla reupload mo dito photobucket.com  ;D  ;D  ;D
« Reply #25 on: July 22, 2012, 07:40:10 PM »
kita ko naman wala naman si palakang toti haha
ok describe konalang kapag hub straight coonect. kapag PC to PC crossover dahil magkatalikod yong 2 rj45 altered natin ang TX+,TX- RX+, RX- ibig sabihin kong ikoconnect natin ang rx+ sa tx+ vice versa ganun rin sa negative (-) sa lahat naman ng mode + man o negative straight parin ang connection ibig sabihin kapag positive sa mode positive parin nakaconnect
Offline /
  • Pogi/Ganda Points: 317
« Reply #26 on: July 22, 2012, 08:17:04 PM »
noong unanang panahon na wala pa ang auto sensing kinakailangan masunod ang rules about cabling configuration.
kung saan, same devices uses crossover configuration and different devices uses straight.
pero sa panahon ngayon, most devices are designed to work either cross or straight called auto sensing capability.
pero sa mga manageable na cisco routers and switches na naencounter ko, karamihan sinusunod parin ang ganyan concept na, pag same device crossover, pag not same device straight.
  • Pogi/Ganda Points: 411
« Reply #27 on: July 22, 2012, 09:40:54 PM »
I concur master itong nagsabi eh.
« Reply #28 on: July 22, 2012, 10:19:39 PM »
agree tama problem lang hinde lahat ng devices ay makabago na ang design meron parin gumagamit ng mga luma, kaya para sure sundin nalang yong cabling configuration
Offline 4XFOUR
« Reply #29 on: July 22, 2012, 11:05:03 PM »
OT: mag photobucket kayo, kasi pag di registered ang mag viewers di makikita image nyo galing imahetulala...
3rd Island Epicenter
Officially Deployed
Offline ♥ ♥ Mel ♥ ♥
« Reply #30 on: August 01, 2012, 08:00:09 PM »
OT:
mga sir ask ko lang po kung mabilis yung file transfer ex: is 32Gb Pc to laptop using crossover cable. kasi po ginagwa ko lang filetransfer gamit yung router(zykel pldt) medyo mabagal lang siya. mas mabilis po kaya or same lang din kung d-direct ko PC to laptop?
Truth may suffer but it cannot perish -St. Teresa of Jesus
"All is well when we seek only the Divine Pleasure"
-St. Therese of the Child Jesus
« Reply #31 on: August 01, 2012, 09:37:01 PM »
OT:
basic math sir... wag muna natin tackle si full or half duplex.
100mbps yung connection. that's megabits.. per second. Zero's and Ones.
let's assume yung data is sent in 8bits plus parity... assuming lang ah. ang byte natin.
11,111,111 BYTES per second ang transfer rates nya... or 11 MB/s (Megabytes per second)
now... 32 gigabytes naman ang gusto natin padaanin sa 100megabit connection.
32,000 megabytes... / 11MB/s (Megabytes per second)... 2909 seconds... in about 48 minutes na transfer na yan.
tandaan din na may CRC checking.. acknowlegdge.. encryption... atbp..
bandwidth nang SATA 2 is nasa 3.0Gigabit per second. SATA 3 is 6Gbps... so better na hard disk to hard disk na lang.
or a faster 1gbps LAN.
kya hard disk to hard disk ang mabilis.
« Reply #32 on: August 01, 2012, 09:41:20 PM »
pa correct na lang kung may bukol. hehe.
