Author Topic: Torque tightening table ?  (Read 455 times)
Offline squelch
« on: June 11, 2012, 11:25:52 AM »
meron ba kayong pdf file ng torque tightening table ?
like 1/2" stainless steel bolt is 40 ft.lb .
  • Pogi/Ganda Points: 523
Re: Torque tightening table ?
« Reply #1 on: June 12, 2012, 12:39:23 PM »
« Reply #2 on: June 12, 2012, 12:40:50 PM »
we never used stainless steel bolts for connecting busbars or electrial connections....
Offline Asarnako
  • Pogi/Ganda Points: 19
« Reply #3 on: June 12, 2012, 06:11:21 PM »
Hehehe!
Wuts the use of TORQUE when u just clamping flat surface metal?
U don't use stainless steel screws/bolts in a machine!
« Reply #4 on: June 13, 2012, 06:33:39 AM »
Hehehe!
stainless steel tends to loosen up in time, that is why only we use those for fastening supports for mechanical parts especially for outdoor installations...
for fastening busbars, high tensile strength carbon steels are used....
the right torque ensures that contact resistance between mating surfaces are as low as low can be...
overtorquing may deform materials such that contact resistance is compromised...
ducter testing is done after torquing to ensure contact resistance specs are met....
Offline ™(◣◢)™
  • Pogi/Ganda Points: 14
  • Enjoy Life ;)
« Reply #5 on: June 13, 2012, 09:02:37 PM »
"high tensile strength carbon steel" bolts,
ganyan yung ginamit namin sa ginawa naming busbar gutter ng electrical system.
Not Everything that counts can be counted And Not Everything that can be counted counts.
Author?
