Author Topic: P61 Amplifier  (Read 7009 times)
Offline jlester87
  • Pogi/Ganda Points: 74
P61 Amplifier
« on: June 11, 2012, 03:34:11 PM »
Who's interested? I'm currently making a pcb layout for it.
http://web.archive.org/web/20020606122126/http://sound.westhost.com/project61.htm
P61 Amplifier
Offline jlester87
Re: P61 Amplifier
« Reply #1 on: June 11, 2012, 03:37:10 PM »
I'll provide the component values later  ;D
Re: P61 Amplifier
Offline pEN DoTA
Re: P61 Amplifier
« Reply #2 on: June 11, 2012, 03:53:21 PM »
interested ako sis., pa share sis pag matapos na.
GOD LOVES YOU
Re: P61 Amplifier
Offline j a y k e z
  • gimmegaggigsss
Re: P61 Amplifier
« Reply #3 on: June 11, 2012, 04:30:21 PM »
Subscribing master jlester ;D
Re: P61 Amplifier
Offline jiggins20
  • Pogi/Ganda Points: 15
Re: P61 Amplifier
« Reply #4 on: June 11, 2012, 06:46:06 PM »
pasubs din..master sa pcb layout..
Audio amp addict
Re: P61 Amplifier
Offline jlester87
Re: P61 Amplifier
« Reply #5 on: June 11, 2012, 07:41:37 PM »
Layout is completed, for those who are interested, please pm your email.
Di ko po ipopost yung details dito... top secret eh haha...
Offline danny
  • Pogi/Ganda Points: 323
Re: P61 Amplifier
« Reply #6 on: June 12, 2012, 01:47:55 AM »
o bakit naman naging top secret iyan sis?
danny
Offline tiktak
  • Pogi/Ganda Points: 203
    • Tiktakx's Blog
Re: P61 Amplifier
« Reply #7 on: June 12, 2012, 07:52:33 AM »
dahil siguro retired na ito, dahil pinaalis na ni hugh dean sa site ni rod
8051 stuff
Offline 01110011
  • Pogi/Ganda Points: 98
Re: P61 Amplifier
« Reply #8 on: June 12, 2012, 08:22:51 AM »
sino nakagawa nito? pasub
Offline NORTH LUZON
  • Pogi/Ganda Points: 812
Re: P61 Amplifier
« Reply #9 on: June 12, 2012, 10:12:05 AM »
wait natin kung may nakagawa na nito
Offline jlester87
Re: P61 Amplifier
« Reply #10 on: June 12, 2012, 10:15:41 AM »
Eto yung schem, almost the same lang pala sa baby aksa, except sa bias servo
Kinuha ko galing dito:
Offline vintong
Re: P61 Amplifier
« Reply #11 on: June 12, 2012, 10:46:22 AM »
12v lang va to...?
Offline jlester87
Re: P61 Amplifier
« Reply #12 on: June 12, 2012, 10:49:55 AM »
Mga masters, pwede bang iintegrate yung bias servo nito sa p61?
Offline vintong
Re: P61 Amplifier
« Reply #13 on: June 12, 2012, 10:57:10 AM »
ilang watts..?
  • Pogi/Ganda Points: 316
Re: P61 Amplifier
« Reply #14 on: June 12, 2012, 11:07:29 AM »
kakaiba ung sa feedback. sure ba ito?
pde
Offline jlester87
Re: P61 Amplifier
« Reply #15 on: June 12, 2012, 05:11:03 PM »
Nilagay ko yung component values ng p61 sa aksa conceptual schematic
Offline fantom_mayonaise
  • Pogi/Ganda Points: 30
Re: P61 Amplifier
« Reply #16 on: June 13, 2012, 10:36:48 AM »
Merong post si designer kung paano iimprove yung p61. hanapin ko lang lang. nasa diyaudio yun.
Re: P61 Amplifier
« Reply #17 on: June 13, 2012, 10:45:36 AM »
Gianluca,
Enhance the quality of the P61 this way:
1. Place a quality 1uF film/foil across the Vbe multiplier
2. Set bias to 55mV across the two output device emitters after half an hour of idling with no signal. Correct as necessary.
3. Reduce C5 to 36pF.
4. Insert 15pF silver mica from base of T2 (feedback transistor on diff pair) to base of upper (15030) driver.
5. Increase bootstrap cap to 220uF 35VW, using the best quality electro you can find.
That should do it. Then tell us the result!
Cheers,
Hugh
http://www.diyaudio.com/forums/solid-state/22410-aksa-55-vs-esp-p3a-vs-3.html
Jlester : pag nabuo mo sir, gawa ka ng p3a vs aksa comparison :)
Early AKSAs did in fact use two 1N4148 diodes and a small 100R pot, diodes thermally contacting the heatsink, for bias generator. It worked extremely well as Bigun suggested, and in fact I believe the diodes sound a bit better than the usual Vbe multiplier, which I moved to down the track.
Offline jlester87
Re: P61 Amplifier
« Reply #18 on: June 13, 2012, 12:05:31 PM »
Sir what could be the value of c6 in aksa conceptual schematic? is it 100nf or 68pf?
Kaya ko rin inupdate yung p3a para magawa ko na din at macompare sa aksa  :)
Offline jlester87
Re: P61 Amplifier
« Reply #19 on: June 13, 2012, 12:22:10 PM »
yung orig p3a pala kahawig ng aksa... bat kaya iniba ni rod yung p3a?
Re: P61 Amplifier
