Author Topic: Cellular phones as extension phones  (Read 908 times)
Offline laem
« on: July 12, 2008, 04:58:44 PM »
Im planning to use cellular phones as a extension phone for my landline, would it be possible? This is for me not to miss important calls even im not in my office.
Re: Cellular phones as extension phones
« Reply #1 on: July 12, 2008, 05:14:57 PM »
Very simple, subscribe your landline for an additional call forwarding service and forward your calls to your cellphone if the landline is not answered.  Its that simple.
Offline laem
« Reply #2 on: July 12, 2008, 05:30:35 PM »
the caller will be charged higher as compared to the usual charge that applies in making landline to landline calls.
« Reply #3 on: July 13, 2008, 07:41:54 PM »
kung ayaw gumamit ng call forwarding, kailangan ng isa pang cellphone or GSM module na pwedeng tumanggap ng voice. (though hindi ko alam kung pwede 'tong gawin indirectly sa software)
then kailangan siyempre ng ring detector (this is a simple circuit). kung naka-set to forward, sasagutin nung cellphone or modem yung call then a tone or recorded voice should remind the caller that he will be forwarded. tapos may AT command to call a number. kailangan connected ang output ng phone sa input ng cellphone and vice versa.
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
« Reply #4 on: July 14, 2008, 12:32:58 AM »
very simple nga
« Reply #5 on: July 14, 2008, 12:22:52 PM »
this is not so practical ksi pwede ka nman gumamit ng pldt wireless phone. mas mura pa charge tapos you can use as an ordinary landline.
« Reply #6 on: July 14, 2008, 08:25:29 PM »
actually a similar project was posted on www.getafreelancer.com and it closed at $xxxx.xx hehehe.
Offline zer0w1ng
  • Pogi/Ganda Points: 305
    • The Cebuano Geek
« Reply #7 on: July 15, 2008, 11:30:36 AM »
This maybe possible but difficult.
Depends on the cellular phone, if the audio codec can be accessed using symbian libs or java and can be routed to bluetooth.  Then a bluetooth audio gateway can be used in parallel with the landline.
The Cebuano Geek
