Author Topic: kv-14jdr1-  (Read 200 times)
Offline buddy3388
kv-14jdr1-
« on: June 16, 2012, 06:06:36 PM »
mga masters pa share naman schematic kv-14jdr1 ung b+(115v) pag nakakabit ung yoke bumamaba supply(60v) buo naman palit na me(actual subs) ok naman ecaps sa primary and sec. wala naman short pati fb pa-test ko ok naman din.minsan nawala ung continuous blinking four corners naman parang ps ic (strs6707)
baka naka-encounter na kayo same symptoms konting liwanag po mga masters.pag on mo walang yoke ok b+,pero kung may yoke 60v lang pag i-on :-[
kv-14jdr1-
Offline Ykcornisauga
  • Pogi/Ganda Points: 13
Re: kv-14jdr1-
« Reply #1 on: June 16, 2012, 07:12:55 PM »
check mo ung mga diode at mylar caps bandang horizontal circuit andun lang po yan. usually ung diode po ang salarin dyan
Re: kv-14jdr1-
Offline J@M
  • Pogi/Ganda Points: 130
Re: kv-14jdr1-
« Reply #2 on: June 16, 2012, 07:24:44 PM »
ilan resistance ng Yoke?
Don't Give up
Re: kv-14jdr1-
Offline samiel
  • Pogi/Ganda Points: 53
Re: kv-14jdr1-
« Reply #3 on: June 16, 2012, 07:31:42 PM »
replaced mo yung dalawang capacitor electrolityc sa power supply,220/16v at 1000/16v
Re: kv-14jdr1-
Offline buddy3388
Re: kv-14jdr1-
« Reply #4 on: June 16, 2012, 08:28:32 PM »
yung hor coil-4.7 ohms.napalitan ko na po ung mga cap sa ps at nag actual na rin palit me ng yoke the same results.
Re: kv-14jdr1-
Offline samiel
Re: kv-14jdr1-
« Reply #5 on: June 16, 2012, 08:37:07 PM »
yung error amp nya nagpalit ka na? se115
Offline enriz622
  • Pogi/Ganda Points: 304
Re: kv-14jdr1-
« Reply #6 on: June 16, 2012, 08:43:29 PM »
tanggalin mo muna ang load ng b+ sis at maglagay ka ng bulb at check kung babagsak pa ang b+ mo
Offline brucetech
  • Pogi/Ganda Points: 46
Re: kv-14jdr1-
« Reply #7 on: June 17, 2012, 11:10:29 PM »
ts monitor mo na lng ang b+..
suyod ng maigi psu mo..
Offline mcleod
  • Pogi/Ganda Points: 143
Re: kv-14jdr1-
« Reply #8 on: June 18, 2012, 09:54:54 PM »
hanapin ang sony blink codes, dami beses na na-post dito or sa google pede din.
Re: kv-14jdr1-
