Author Topic: pci interfacing card.  (Read 4249 times)
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
Re: pci interfacing card.
« Reply #20 on: July 15, 2008, 03:22:53 PM »
There are several experimenters board for pci try to search for that pra nman di na kyo mahirapan sa board. Kung talaga nman cut an old pci card and solder the wire thru it.
meron kaya available locally?
Offline paranz
« Reply #21 on: July 15, 2008, 03:31:38 PM »
ito ISA prototyping board...
« Reply #22 on: July 15, 2008, 05:12:04 PM »
saan nakakabili nyang experimenter's board? parang maganda yan ah... pero kung sa practicality, sa USB ako dahil plug and play...
Offline paranz
« Reply #23 on: July 16, 2008, 08:31:55 PM »
wala yata available dito locally
Offline aze
  • Pogi/Ganda Points: 14
« Reply #24 on: July 16, 2008, 09:17:49 PM »
sayang naman po... kng wlang available locally. mganda pa naman ung pci prototyping board. ung gagamitin ko kcng pci card is ung pci card na gamit na isosoldered ko nlng ng wires pra mka interface. hehehe
Offline paranz
« Reply #25 on: July 16, 2008, 09:22:58 PM »
pwede ka namang gumawa siguro ng board. Orcad layout meron footprint for PCI and ISA slots
Offline aze
« Reply #26 on: July 16, 2008, 09:49:24 PM »
un nga po ang iniicp namin. kya lng sa sobrang katipiran namin po un nlng ang gagamitin hehehe
wla dn po kcng available na malapit na mga electronic stores dito smin na double sided na pcb. sbi nrn ng teacher namin ok na ung gamit na na pci card basta hindi lng mgka interconek ang mga pins at maayos ang pagkasoldered.  kya nga doble na ang hirap pero ok nrn po atleast dagdag sa kaalaman hehehe sir paranz sa inyo po ba yang isa na prototype board?
Offline paranz
« Reply #27 on: July 16, 2008, 09:58:12 PM »
hehe sa internet galing ang pics, wala ako nyan
« Reply #28 on: July 17, 2008, 08:45:30 AM »
Meron din po ako nakita sa eagle 5.0V kchcheck ko lang ngaun.
Offline motion55
  • Pogi/Ganda Points: 244
« Reply #29 on: July 17, 2008, 09:10:58 PM »
Connecting to the PCI bus isn't easy. It isn't TTL signaling. It uses "reflected wave" signaling. It also uses special handshaking protocols. If you want to build your own, the normal route is to use an FPGA chip and use the readily available PCI design IPs.
Having said all the discouraging things, here is a tip. Apparently you can implement a simple PCI interface using just three GAL chips. Here is a link to a PCI diagnostic card using such method.
http://www.pctechbytes.com/DIY/pcidiagnostic.htm
Try to get a hold of this or similar card and reverse engineer the schematic. I think it is available at one of Gilmore PC stores.
"Set your mind free!"
Offline paranz
« Reply #30 on: July 17, 2008, 09:38:23 PM »
^ hehe mahirap nga, ISA nalang muna ako...
Offline aze
« Reply #31 on: July 18, 2008, 08:30:04 AM »
sir ung pci na pcb na gmit na mtatanggal ba ung metal nun ng feric chloride ung bronze nya? tinanggal ko na po ung varnish na color grin.
« Reply #32 on: July 18, 2008, 09:08:13 AM »
kung di ako nagkakamali tin coated yta yun? not so sure.
Offline aze
« Reply #33 on: July 18, 2008, 09:18:17 AM »
kc po kelangan ko tanggalin ung metal o ung bronze na nka conek sa mga pins ng card. ang planu ko po takpan nlng ng masking tape ung pins at tatanggalin ko ung metal using feric chloride ang tanung ko po kng matatanggal ung bronze hehehe
Offline paranz
« Reply #34 on: July 18, 2008, 10:31:13 AM »
trial and error ka nalang hehe
Offline aze
« Reply #35 on: July 18, 2008, 10:38:25 AM »
cge po tnx po sir. hehe
« Reply #36 on: July 19, 2008, 08:13:13 AM »
mukhang mahirap nga siya...
