Author Topic: SONY MHC-RV600D  (Read 425 times)
Offline 4XFOUR
  • Pogi/Ganda Points: 30
SONY MHC-RV600D
« on: June 21, 2012, 12:40:54 PM »
mga master patulong, ano kaya problema nito kasi pagka ON nagdidisplay siya alternately  "PROTECT" and "PUSH POWER",
3rd Island Epicenter
Officially Deployed
SONY MHC-RV600D
Offline j a y k e z
  • gimmegaggigsss
Re: SONY MHC-RV600D
« Reply #1 on: June 21, 2012, 12:49:37 PM »
baka sira na power amp nyan
some part sa amplifier section  :D
Re: SONY MHC-RV600D
Offline 4XFOUR
Re: SONY MHC-RV600D
« Reply #2 on: June 21, 2012, 01:03:59 PM »
a ok, so sa tantsa mo sis PA circuits ang deperensya nito sis? IC kaya?
reading input voltage ko nito ay 47.8V at -48.2V
pahirapan pa naman magbaklas ulit nito ;D
Officially Deployed
Re: SONY MHC-RV600D
Offline j a y k e z
  • gimmegaggigsss
Re: SONY MHC-RV600D
« Reply #3 on: June 21, 2012, 01:16:44 PM »
ou nga hehehe, masasanay ka din ;D
Re: SONY MHC-RV600D
Offline J@M
  • Pogi/Ganda Points: 130
Re: SONY MHC-RV600D
« Reply #4 on: June 21, 2012, 05:57:14 PM »
Common na sira power amp pag ganito scenario,pero check pa din mga fusible resistor paikot.
Don't Give up
Re: SONY MHC-RV600D
Offline 4XFOUR
Re: SONY MHC-RV600D
« Reply #5 on: June 21, 2012, 07:26:15 PM »
thanks... update this thread soon pag andyan na pyesa wag lang mapeke sa IC ;D
J@M pwede ko kaya palitan ang IC nito originally STK402-100S @100W to STK402-120S@120W kakayanin kaya ng default power supply?
Officially Deployed
Offline J@M
Re: SONY MHC-RV600D
« Reply #6 on: June 21, 2012, 08:20:27 PM »
Ndi ko pa na try yan..wait mo advice iba master...wag ka muna mag palit be sure na good lahat ng asa palibot nyan.
Don't Give up
Offline 4XFOUR
Re: SONY MHC-RV600D
« Reply #7 on: June 21, 2012, 08:25:13 PM »
ok sis j@m will do... waiting for the expert in this amp....
Officially Deployed
Offline samiel
  • Pogi/Ganda Points: 53
Re: SONY MHC-RV600D
« Reply #8 on: June 21, 2012, 08:32:06 PM »
ok lang yung stk402-100 papalitan ng stk402-120,check u muna dalawang 100 ohms 1/2 watts na resistor,papuntang paa ng ic,if ok...pwd mo naman tanggalin yung mga paa ng ic...para ma isolate mo lang problema...pagtanggal ng ic at magnormal power,8s means ic talaga problem nya...
Offline 4XFOUR
Re: SONY MHC-RV600D
« Reply #9 on: June 22, 2012, 08:53:53 AM »
ok thanks.. salamat sa guide ^1
dami ko na rerepairing gamit dito sa bahay.. :P will update this soon kasi dami ko na babaklasin gamit hehehehe...
Officially Deployed
Offline laopan
Re: SONY MHC-RV600D
« Reply #10 on: September 29, 2012, 09:32:41 AM »
masters, yung s component ko, mhc-zx70 ayaw bumukas ng lagayan ng  dvd. ano solusyon dun
Offline ako si binoe
  • Pogi/Ganda Points: 49
Re: SONY MHC-RV600D
« Reply #11 on: October 07, 2012, 02:34:38 PM »
tama si master samiel
Offline acer
  • Pogi/Ganda Points: 117
Re: SONY MHC-RV600D
« Reply #12 on: October 07, 2012, 02:57:05 PM »
mag sheshare din ako, pwede rin pag komparahin ang left and right channel pin ng IC
nevergive up
Offline THE UNFøRGIVEN
  • Pogi/Ganda Points: 61
  • my homemade stunner
Re: SONY MHC-RV600D
« Reply #13 on: October 29, 2012, 07:00:38 PM »
tama si sis samiel, check muna dalawang 100 ohms resistor na connected sa dalawang main filter caps , kakagawa ko lng ng compo kanina, 2resistor lang sira.hihi sirain tlga yan, check u muna po bago pagsuspetsahan ang power amp. Check for loscon din lalo na sa mga connectors,hihi .. Gudluck po sis! Mabohay
Practice as if you're the weakest,
Perform as if you're
the best..
Re: SONY MHC-RV600D
