Author Topic: capacitor nag leak at lumobo  (Read 804 times)
  • Pogi/Ganda Points: 413
Re: capacitor nag leak at lumobo
« Reply #20 on: June 24, 2012, 09:48:30 PM »
Teka pasaan yung wire galing ng center tap traffo?
Offline 01110011
  • Pogi/Ganda Points: 98
« Reply #21 on: June 24, 2012, 09:49:14 PM »
sis post mo yung problem at ang solution para, makita din ito ng ibang ka elab na may ganito din na problema :)
Offline eboy88
  • I love Electronics!
« Reply #22 on: June 24, 2012, 09:51:18 PM »
mukhang gaynclone amp toh ah TDA???
ung heatsink maliit yan ;D
TDA2030 po yan plus may 4558D na tone control bass,mid,treble,
another question is kasi yung 4558 max nya ata is +18v eh ang supply ko is 20.25v okay lang kaya yun?
yung heatsink meron na po ako malaki, di ko palang po nabutasan hehe.
I love to make DIY's,... but I need your helps.. :D
Offline eboy88
« Reply #23 on: June 24, 2012, 09:51:53 PM »
papunta po sa ground
Offline 4XFOUR
« Reply #24 on: June 24, 2012, 09:58:36 PM »
---edit-----
namalikmata lang ako...
3rd Island Epicenter
Officially Deployed
« Reply #25 on: June 24, 2012, 10:00:25 PM »
Idrawing mo yung traffo output mo sa ps then paano nakakabit sa amp mo para makita ng mga masters natin.
« Reply #26 on: June 24, 2012, 10:06:10 PM »
sa simula pwede 'yan, pero kapag tumagal masisira din 'yan.
masyadong malapit 'yung voltage rating ng ecap sa voltage mo, kaya kung pangit 'yung ecap, unti-unti talaga siyang lolobo. ;)
Offline eboy88
« Reply #27 on: June 24, 2012, 10:07:23 PM »
heto po
//i50.tinypic.com/a1sur.jpg
so dapat po mga 50v yung cap ko?
plug ko po ulit yung ampli. gumagana po, lakas lang ugong parang may grounded pero nawala din, yung capacitor naririnig ko yung pag LEAK ng liquid sumisirit yung tunog
« Reply #28 on: June 24, 2012, 10:08:40 PM »
Ayun me hatol na si ate rdp.
Ito ata schema ni ts.
« Reply #29 on: June 24, 2012, 10:10:45 PM »
Ang laki naman pala ts akala ko tinypic eto?  ;D
Offline eboy88
« Reply #30 on: June 24, 2012, 10:18:54 PM »
meron ako di nabago, yung vin papunta sa 4558 dapat 20.25 na kasi nagpalit na ko transformer
Offline eboy88
« Reply #31 on: June 24, 2012, 11:37:55 PM »
ano po mag masters, palit lang ako ng cap?
Offline BABY AMPLI
  • Pogi/Ganda Points: 56
  • it is my life and i live it how i want
« Reply #32 on: June 25, 2012, 02:06:55 AM »
pede po pala yung 20.25vdc pwede gawin 16 volt using resitor lang?..verify lang po sa mga master
before you judge me..make sure that you are perfect
« Reply #33 on: June 25, 2012, 02:10:38 AM »
^ pwede, pero hindi laging parehas ang boltahe mo sa paglagpas ng resistor, depende kasi sa current ang voltage drop ng resistor.
regulator ang ginagamit kapag ganyan.
Offline 4XFOUR
« Reply #34 on: June 25, 2012, 07:52:34 AM »
from source -V pagpunta sa OP amp bumaligtad naging +V ganyan ba talaga design nyan?
Officially Deployed
Offline eboy88
« Reply #35 on: June 25, 2012, 09:11:55 AM »
mali po yung schematic nagawa ko hehe, pero sa notebook ko po tama..
Offline eboy88
« Reply #36 on: June 25, 2012, 09:16:42 AM »
heto po revised schematic //i47.tinypic.com/2h659g8.jpg
Offline 4XFOUR
« Reply #37 on: June 25, 2012, 09:36:58 AM »
Officially Deployed
Offline eboy88
« Reply #38 on: June 25, 2012, 10:12:04 AM »
salamat sir, so paano po problem ko? fake yung cap o taasan ng voltage?
« Reply #39 on: June 25, 2012, 10:21:35 AM »
since local/hindi branded 'yung capacitor, use a higher voltage one, merong 35V or pwede ring 50V.
