Author Topic: sony KV-2187MT low B+  (Read 438 times)
Offline omok101
« on: June 26, 2012, 09:33:20 AM »
pahelp po sa Sony KV 2187MT mababa po B+ inalis ko na po load ganun pa rin bago po yung reg. STRS 6307 nagpalit na rin po ako ng capacitor na 47/16v nasira po kc dati at check ko na rin po mga crystal diode ok naman help po mga master kung anu po ang aking next move 11ov po muna ginagamit kung input sa line ok lng po ba ito?
  • Pogi/Ganda Points: 811
Re: sony KV-2187MT low B+
« Reply #1 on: June 26, 2012, 09:37:03 AM »
may 2ndary switch yata yan ah
pakihang muna ang hot sis saka observe mo ang b+
Offline omok101
« Reply #2 on: June 26, 2012, 09:44:29 AM »
napansin ko lng po kc sa mga narepair ko na po pg ok naman PS labas agad yung Normal B+ voltage pero eto po kahit walang load mababa po talaga gagawin ko po yung cnabi po nyo TY po sa maagap na pg reply =)
« Reply #3 on: June 26, 2012, 09:49:00 AM »
nagpalit knb ng regulator nyan?
Offline omok101
« Reply #4 on: June 26, 2012, 09:51:33 AM »
bago po yung reg
« Reply #5 on: June 26, 2012, 09:54:02 AM »
autovolt ba yan?
baka 220v lang ang primary
double check
Offline omok101
« Reply #6 on: June 26, 2012, 10:13:12 AM »
autovolt po kaya ginamitan ko muna 11ov
« Reply #7 on: June 26, 2012, 10:19:19 AM »
double check ka sa pri at sec ng PSU nyan at nahuhuli mo rin ang salarin
Offline acer
  • Pogi/Ganda Points: 107
« Reply #8 on: June 26, 2012, 10:28:52 AM »
may SExxx siguro yan
nevergive up
Offline omok101
« Reply #9 on: June 26, 2012, 12:13:42 PM »
meron po se115
« Reply #10 on: June 26, 2012, 01:37:28 PM »
pwde idirect sub muna yan para mapadali ang trobolshot
Offline techies
« Reply #11 on: June 26, 2012, 01:48:05 PM »
sis bago k nagpalit ng new reg ncheck mo ba yung ibang componet sa ps.. mahal din ang reg
ONE FOR ALL ........ALL FOR ONE
Offline omok101
« Reply #12 on: June 26, 2012, 02:12:41 PM »
opo nagcheck na po ako halos lahat ng piesa dun sa mismong PS section aandar po ba yung PS pag temporary naalisin yung SE115?
  • Pogi/Ganda Points: 909
« Reply #13 on: June 26, 2012, 03:54:02 PM »
kng di ito dumadaan ng realy at directly pumapasok ang 300VDC sa Regulator...
i highly recommend mag resistance check ka muna  ng mga resistor ma lower or higher value
Offline omok101
« Reply #14 on: June 26, 2012, 04:09:01 PM »
gagawin ko po update ko po kau
Offline Min
  • Pogi/Ganda Points: 202
« Reply #15 on: June 26, 2012, 04:12:53 PM »
Pwede mo yan subukan kahit delikado na maaring mag overvoltage ang secondary output. Ang ginagawa ko sa ganyan para instantly malaman kung sa feedback ng secondary circuit ang diperensya ay pinag so short ko ang pin 1 and 2 ng opto. para malaman kung me reaction( kung tataas ba output). Pero kailangan alisto ka at minsan gumagamit din ako ng bulb.
M I N 2 5  e l e c t r o n i c s
  • Pogi/Ganda Points: 143
« Reply #16 on: June 26, 2012, 09:30:49 PM »
sure ka good ang transistors mo 2 near regulator str-s6307?
« Reply #17 on: June 27, 2012, 09:33:18 AM »
wag na wag mo gagawin yan sis
manganganak ng sira ang unit mo
Offline omok101
« Reply #18 on: June 27, 2012, 09:41:20 AM »
mga master di halos nagawa ko na po lahat cnabi nyo ang ginawa ko po ay test ko po flyback back baka sakali lng ako with ring tester at saka arcing na rin ok naman sa ring at arcing accidentally di ko po naihinang yung isang pin ng FB yung ground po sa pagkakaalam ko yun yung ground sa screen bigla po taas ng b+ over voltage nga po anu po kaya nagyari wala naman akong makitang short posible po kayang sira yung FB samy screen?
Offline DJFEL
« Reply #19 on: June 27, 2012, 11:14:09 AM »
sub...
dj fel on the mix
