Author Topic: re: troubleshoot tv  (Read 263 times)
Offline xaero29
re: troubleshoot tv
« on: July 04, 2012, 09:23:35 PM »
mga idol wat po ba problema ne2?
pensonic na tv ang history.. nia  habang nka-on my pumutok xa loob.
na check ko na po ung primary
busted fuse. 2 diode busted din \
shorted po xa primary..
re: troubleshoot tv
Offline TBG
  • Pogi/Ganda Points: 145
Re: re: troubleshoot tv
« Reply #1 on: July 04, 2012, 09:35:12 PM »
check mo rin mga ibang pa parts tulad ng diode, zener diode,resistor at capacitor  sa psu
Offline kaiky14
  • Pogi/Ganda Points: 27
« Reply #2 on: July 04, 2012, 10:33:20 PM »
pati regulator sis
Offline DSM_elektronix_shop
  • Pogi/Ganda Points: 153
« Reply #3 on: July 04, 2012, 10:35:44 PM »
check mo na rin ang fbt baka butas yun ang sanhi minsan ng pagkasira ng regulator..
DSM_electronics_shop
Alvin Y. Carulasan
NCII certificate holder# 1013160220767
PRC (ECT) Lisence Number# 0001237
Sinal Village, Taguig city
Offline xaero29
« Reply #4 on: July 04, 2012, 11:34:56 PM »
nag palit na po aq ng mosfet  un po ba ung regulator?
nag palit na rin po aq ng diode,fuse.
pag plug in q ng wire (ung naka lagay xa gilid shorted ung primary) - (degoser) po ba tawag dun?
pag tinanggal q po.. wla ng shorted
... ndi pa po aq nag test kac bka may ma busted na amn eh.
Offline TBG
« Reply #5 on: July 05, 2012, 07:18:17 AM »
no probs yan sa deguasser may resistance pagtest mo sa VOM.hung mo muna ang HOT at pwede ka na magvoltage check.
Offline xaero29
« Reply #6 on: July 05, 2012, 12:31:09 PM »
na test ko na po ganun pa din busted 2 diode ko  xa primary..
bago na po ung mosfet nia xa secondary...
ok amn po h-out nia..
wat po kya mga idol problem ne2??
pa turo na rin po kung pano mga check xa fbt.. thx^^
  • Pogi/Ganda Points: 916
« Reply #7 on: July 05, 2012, 12:39:24 PM »
model & chassis ?
  • Pogi/Ganda Points: 414
« Reply #8 on: July 05, 2012, 12:43:24 PM »
Ayan kakamadahin na ito ni ati oltra.
Concentrate ka muna sa primary mo sis at diode bridge. Tapos check mo na rin secondary mo lalo na sa fbt.
Offline leor815
« Reply #9 on: July 30, 2012, 04:18:38 PM »
kamusta na ito? ok na ba?
katatapos ko lang din kumana ng pensonic 21"...pumutok ang power supply section at kumalat ang kulay.ang naging sira.
 2 rectifier sa mains,
.1mf/2kv caps,
STR W6554a reg
at ung sabog na kulay ay sirang thermistor ng degaussing coil nya.
baka makatulong.
« Reply #10 on: July 30, 2012, 06:38:06 PM »
^Mukjang sinabi mo na titirahin ni ts.  ;D
