Author Topic: Linksys WRT54G  (Read 1351 times)
Offline leor815
Linksys WRT54G
« on: July 17, 2008, 03:45:51 PM »
Hi there,
Newbie lang po ako from SBMA Olongapo.
I want to extend the wifi coverage ng wrt54g ko na router sa building namin.
Pwede ko bang i extend sa kabilang area ang antenna using a coaxial cable?
Linksys WRT54G
Offline deanc
  • Pogi/Ganda Points: 8
Re: Linksys WRT54G
« Reply #1 on: July 19, 2008, 02:22:06 AM »
Re: Linksys WRT54G
« Reply #2 on: July 19, 2008, 07:40:58 AM »
Offline sutil
Re: Linksys WRT54G
« Reply #3 on: July 25, 2008, 06:38:05 AM »
the maximum range of coaxial cable you can use is 10 meters above that will result in signal loss
Re: Linksys WRT54G
Offline deanc
Re: Linksys WRT54G
« Reply #4 on: July 25, 2008, 07:43:03 AM »
Doesn't it depend on what kind of coaxial cable and frequency being used?
Re: Linksys WRT54G
Offline graSS
  • "High"
Re: Linksys WRT54G
« Reply #5 on: August 15, 2008, 04:22:14 PM »
do you have any other options on how to boost my Linksys signal??
Offline deanc
Re: Linksys WRT54G
« Reply #6 on: August 15, 2008, 05:29:48 PM »
Change mo yung FW ng DWRT, may option dun to change the RF power output of the router.  Pero you have to take into consideration the following:
1. Changing to DWRT will void your warranty
2. Flashing your router incorrectly may brick your router
3. Increasing the RF power output may damage the Wi-Fi transmitter
Offline ROLLIE
Re: Linksys WRT54G
« Reply #7 on: September 29, 2008, 01:59:52 PM »
Hi there,
since naka WRT54G ka, mas maganda kung mag add ka na lang ng WAP54G naka repeater mode.
Re: Linksys WRT54G
