Author Topic: Tulong ckb5237g(d), ckb5237l Shake screen tapos ngayon wala na picture  (Read 8373 times)
Offline Red Sonjah
  • Pogi/Ganda Points: 5
Re: Tulong ckb5237g(d), ckb5237l Shake screen tapos ngayon wala na picture
« Reply #60 on: February 27, 2008, 12:39:17 PM »
HELP  ???
Offline Red Sonjah
« Reply #61 on: February 28, 2008, 01:26:17 PM »
HELP :'(
Offline Red Sonjah
« Reply #62 on: February 28, 2008, 01:40:26 PM »
Tech pangalawa tanong
ano yung
. primary circuit
. secondary circuit
. primary ground
. secondary ground
Offline Siramiko
  • Pogi/Ganda Points: 35
  • thank you elab
« Reply #63 on: February 28, 2008, 07:02:50 PM »
ano yung
. primary circuit
. secondary circuit
. primary ground
. secondary ground
oops dyan tayo sa mga term  ;D , nariyan naman ang bestfriend natin hehehe!!! google and yahoo
I shall return
Offline Shey
  • Administrator
  • Pogi/Ganda Points: 154
    • Elab.PH
« Reply #64 on: February 28, 2008, 09:52:34 PM »
ano yung
. primary circuit
. secondary circuit
. primary ground
. secondary ground
Saan yan, sa power supply?
The darkness around me
Shores of a solar sea
Sleeping
Weeping
With you
I walk alone
Every step I take
I walk alone
My winter storm
Holding me awake
It’s never gone
Your dangerous mind
As your true colours show
A dangerous sign
Offline Red Sonjah
« Reply #65 on: February 29, 2008, 11:29:35 AM »
Oo sa power supply  :D thanks sa inyo tech at electron na maganda :)
Tech solve na yung Font nag nagdodouble, red saka balack pinalitan ko IC300 at ok na yung fonts nya hindi na naghahalo yung red at black. Tech yung IC101 KA2143 nakalagay sa service at KA2143B na nakalagay sa board ay iba sa nadownload natin dataset na ka2140. yung ka2140 ay may 28 pin samantalang yung ka2143 at ka2143b ay may 24 pin lang. saka mas malapad yung ka2140.
at may napansin rin ako sa ka2140 yung contrast at brightness ay handle nya. samantalang sa KA2143b ay hindi.
Tech yung Function na VIDEO CLAMP ng ic101 yun ba yung naghohold ng VIDEO?
Pasinya na if bumalik tayo sa topic ng IC101 kasi wala ako mahanap na sira  ;D
saka napansin ko kasi visually na yung paligid ng IC101 ay nagkulay darkbrown na parang bang meron burned na nangyari, don naman sa iba IC ng board ay wala ganun ako napapansin.
Thank sa inyo  ;)
Offline Red Sonjah
« Reply #66 on: February 29, 2008, 11:52:25 AM »
IC101 KA2143B Datasheet download Here  v
http://rapidshare.com/files/95797372/datasheet.pdf.html
Saka naghinala rin tayo nun na baka main problem nya ay nagpapalit ng resolution kaya parang nagshashake screen
Datasheet Note:
"The KA2143B is a very high frequency video amplifier
system with OSD interface intended to be used in Monitor
with high resolution up to 1024 ? 768. It contains 3 matched
R/G/B video Amplifiers with Blank signal and provides a
flexible interfacing to DC controlled adjustment system."
Tnx Tech Help me rin Electron Thanks
Offline Siramiko
  • thank you elab
« Reply #67 on: February 29, 2008, 05:14:15 PM »
Thank sa inyo  ;)
salamat naman at may nabago na , sana post mo rin ang magiging resulta hanggang sa mabuo  :)
gusto pa sana kitang tulungan, kaya lang actual trouble  shooting ang alam ko, yung mga terminology hindi namin napag-aralan ng husto, marami naman ditong tutulong sayo pagdating sa terminolgy. yung mga ini-explain ko sayo base yung sa sariling pag-aaral ko.(basa doon ,basa dito  :D
ito baka makatulong
 http://www.cedmagic.com/tech-info/data/lm2889.pdf
I shall return
Offline Siramiko
  • thank you elab
« Reply #68 on: February 29, 2008, 05:14:44 PM »
edit
sorry na save ng dalawang beses  :D
I shall return
Offline Red Sonjah
« Reply #69 on: March 01, 2008, 11:18:05 AM »
It's ok ha malaki naitulong mo. thanks ;) :-*
Offline Red Sonjah
« Reply #70 on: March 04, 2008, 11:05:56 AM »
ano pwedi replacement nya wala ako makita sa raon? IC 101 Help  :'(
