Author Topic: am receiver help po..  (Read 1345 times)
Offline soulhast
« on: July 19, 2008, 02:22:44 PM »
ask ko lng po kng pano gumawa ng am receiver.. en can i have a copy of its circuit diagram? tnx po.. :)
Offline danny
  • Pogi/Ganda Points: 324
Re: am receiver help po..
« Reply #1 on: July 19, 2008, 02:40:15 PM »
did u try alexan or sa raon?
i think may mga kit ata na nabibili doon. :)
danny
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
« Reply #2 on: July 19, 2008, 08:23:44 PM »
Marami naman sa internet. Google mo na lang..
  • Pogi/Ganda Points: 635
« Reply #3 on: July 19, 2008, 11:10:24 PM »
basic AM receiver is a peak detector. Diode (or Rectifier) and Capacitor lang. the very first use of semiconductor in electronics. ;D
Offline Born2BeWired
  • Pogi/Ganda Points: 171
    • e-Gizmo Mechatronix Central
« Reply #4 on: July 21, 2008, 10:13:30 AM »
A.K.A Crystal Set. If you are in  metro or within a few kilometers from a AM transmitting station, pwede ito. Wire antenna- LC tuned circuit- diode - earphone lang ito. It does not even require a battery.
Sample Link:
http://www.electronics-tutorials.com/receivers/crystal-radio-set.htm
Offline tikbalang
  • Pogi/Ganda Points: 23
    • kill sp@m
« Reply #5 on: July 21, 2008, 11:03:18 AM »
isa sa mga circuit frustrations ko ang crystal radio.
Offline soulhast
« Reply #6 on: July 31, 2008, 02:21:19 PM »
thanks.. i went to alexan and i bought am kit transistor type.. mas mhirap kc pag ic type pa eh.. thanks again..
Offline che_083088
« Reply #7 on: July 31, 2008, 02:29:40 PM »
hmmm..help naman po about rf id tagging
Offline Janine
« Reply #8 on: July 31, 2008, 04:16:40 PM »
bibilihin mo yun RF Id tags at yun Transceiver sa digikey kasi walang available dito sa PI. It requires lots of programming kumpleto na yun datasheet ng rfid transceiver ng lahat ng kailangan mong info.
« Reply #9 on: August 02, 2008, 09:33:09 AM »
sa e-gizmo may rfid reader. Try to visit them or their site.
