Author Topic: Analog multimeter vs. Digital multimeter  (Read 3872 times)
Offline xlagi
  • Pogi/Ganda Points: 6
« on: July 20, 2008, 04:08:37 AM »
ano mas gussto mo gamitin DT-380B or yung YX-360TR
PALABASIN ANG MGA DRAGON
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
Re: Analog multimeter vs. Digital multimeter
« Reply #1 on: July 20, 2008, 08:57:03 AM »
i prefer to use both. Meron kasi iba-ibang unique uses ang dalawang type ng multimeters
Offline xlagi
« Reply #2 on: July 20, 2008, 08:56:00 PM »
ahehehe pareho pala tayo sir paranz gamit ko din yung dalawang yan e
Offline paranz
« Reply #3 on: July 20, 2008, 09:57:45 PM »
Sa DMM i like the continuity test and the BJT hfe test. Sa analog naman yung ohmeter test for diodes, capacitors, and LEDs
Offline 1110000
  • Pogi/Ganda Points: 28
« Reply #4 on: July 20, 2008, 10:05:37 PM »
atsaka sa linear measurement ng voltage drop maganda gamitin ang analog kasi makikita mo talaga na pagalawgalaw yung needle di tulad sa digital yung ibang digital meter talagang magalaw
E153C51513
« Reply #5 on: July 21, 2008, 11:14:33 AM »
Ako I also prefer analog and digital. Tanda ko pa nung panel interview tapos pinagdemo ako sa paggamit ng tester ung analog ginamiit ko tapos pinakita ko pa proper calibration before using. yun ok nman tanggap me.
Offline paultrax
  • cage bunshin no jutsu
« Reply #6 on: September 02, 2008, 12:29:10 PM »
i prefered both too.. ;D ;D ;D
pareho lng nmn yon madaling gamitin  ;D ;D ;D
Offline lightelectro
  • Pogi/Ganda Points: 51
    • Android Tablet Lover
« Reply #7 on: September 02, 2008, 02:00:38 PM »
both 8) 8)
LATEST ANDROID TABLET NEWS
« Reply #8 on: September 02, 2008, 02:08:32 PM »
kahit ano basta nakakasukat ;D ;D ;D
preferred ko ang analog sa mga deflection test ng capacitor...
Offline ferdie444
  • Pogi/Ganda Points: 4
« Reply #9 on: September 03, 2008, 02:31:38 AM »
for me both,why?for monitoring the variation of very small amount of current and voltage(ma/mv) eh digital is the best and if you want to carry-out out of circuit test of elex components like x'tor,diode,capacitor & resistor and of course to check the continuity eh analog is the best.i'm using fluke process meter and sanwa mutitester.thanks....
Offline akosiikem
« Reply #10 on: September 03, 2008, 10:03:20 AM »
Kylangan talaga both meron ka.
DMM for measurements syempre mas accurate
Analog for troubleshooting and testing components.
Offline Dennis.
« Reply #11 on: September 03, 2008, 10:33:06 AM »
ako rin ginagamit ko sa capacitor, diode , transistor ang analog yung sa digital naman sa volt kasi palagay ko mas accurate siya. (check me if I'm wrong, not related sa electronic course ko.) at sa resistor
« Reply #12 on: September 03, 2008, 10:38:40 AM »
dapat pala analog ang kasunod ko bilhing tester
Offline kirk simone
  • Pogi/Ganda Points: 7
« Reply #13 on: September 07, 2008, 06:23:59 PM »
ako din both for monitoring ung dmm
shake it .....
Offline nath630
  • Pogi/Ganda Points: 37
« Reply #14 on: September 22, 2008, 05:48:01 PM »
ano po best na DMM/gamit nyo?
Offline 'yus
  • Pogi/Ganda Points: 299
  • hw -> fw -> sw
    • yus' projects
« Reply #15 on: September 22, 2008, 06:25:16 PM »
pag portable, gamit naman usually ay FLUKE:
Offline nath630
« Reply #16 on: September 22, 2008, 06:40:09 PM »
how much po yang fluke nayan?
yung alexan po ba ok din?
gamit ko kasi SAnwa DMM old model,,,matagal ng nagresign...hehehe..
Offline rommelpm
  • Pogi/Ganda Points: 13
  • learning is a continuous process...
« Reply #17 on: September 22, 2008, 08:17:50 PM »
I use Analog for:
   - For quick troubleshooting. Kadalasan ay kailangan mo lang makita ay yung deflection.
   - capacitor check
   - diode forward/reverse
   - open/close circuit
   - DC/AC voltages/current.
Digital tester for me is best for:
   - measuring voltages/current specially when the frequecny (sinewave) is beyond 60Hz
     (Sanwa CD800a is capable of measuring voltages at 40-400Hz)
   - when monitoring voltages/current at a certain period
   - Capacitance and Inductance measurements
   - HFE measurements
   - measuring frequencies/duty cycles
