it's not a simple job.. kailangan mong gumawa ng high power sinewave generator na nakakabit sa step down transformer. Take note na ang ordinary silicone steel EI core is designed to work at 60 Hz, i'm not sure kung may reduction in efficieny yan if you try to run it at 400 Hz.
I need a help from you guys about changing the output of the wall outlet power from 220VAC/60Hz to 110VAC/400Hz. Converting it to 110V is easy but Im having trouble converting its frequency to 400Hz. Any ideas what simple component to add? Thanks in advance.
Looks like we got a member who is into avionics. Mukhang marami kang gadgets na pang eroplano ah? I will go along with the idea of electron ang egnome692002. The easiest path may be to hack a UPS to tweak its frequency to get your 400Hz source. All the electronics hardware are already in there. I hope you are not working on some weapon guidance system and thinking of blowing something up
So how do I change nga the output of a UPS from 60Hz to 400Hz? I cant think of anything inside a UPS to tweak on to change the output frequency.
