Author Topic: KOLIN CRT TV No vertical deflection. - next time i-post mo sa tamang section  (Read 1223 times)
Offline enriz622
  • Pogi/Ganda Points: 350
sa input ng vertical ic kapain mo at check mo kung aangat ang line
Offline angel_017
  • Pogi/Ganda Points: 121
focus lang tatay sa vertical section muna...
try to float input pin (pin4) ng vert. ic at mag insert ka ng signal.. small audio pwede na... pag may reaction at unti unting bumubuka ang one line,,, wala sa vertical section mo ang problema kundi nasa ibang section (jungle, eeprom & etc.)....
pero pag walang reaction nasa vertical section nga ang problema mo tatay...
check mo agad ang supply mo pin6 & 3 dapat parehong solid yan at stabled..
pag meron iyan check mo naman ang output mo.. def yoke partial test (resistance check) at supply nito alam mo naman ang voltage reference
pag ok ang mga yan tatay..  isa isahin nyu na ulit lahat ng peripheral parts ng ic..
copper clad ng pcb baka may hair line crack or loose con... pag ok na lahat at ayaw pa rin.. palitan na bagong working na vert ic...
pag ayaw pa rin... isauli mo na yan tv sa may ari tatay... ayaw nya  yatang mag paayos sayo  ;D
"For god so loved the world that he gave his one and only son that whoever believes in him should not perish but have an eternal life"  JOHN 3:16
THINK like a man of ACTION. :)
ACT like a man of THOUGHT.
https://www.facebook.com/iamsandraflirt
Offline TBG
  • Pogi/Ganda Points: 257
[/quote]
pero pag walang reaction nasa vertical section nga ang problema mo tatay...  ;D ;D ;D ;D ;D
Offline RhedN14
on order pa ang ic na TA8427K bka nextweek ko ma update ito slamat.
Offline RhedN14
bad news po di na po gumagana ung crt nadagdgan ang problema pano ba yan?
Offline RhedN14
hndi na nagbabaga ang cathode ray tube mga sir/mam. no kya to?inistock ko lng ng 1week
Offline Deantyne
  • Pogi/Ganda Points: 122
  • Use P-C-D-A in daily life.
ddead set na? baka may natanggal lang or baka may shorted solder..
suyod ulit and recheck.
"To gain new ideas, read the old book" - UNKNOWN
Offline RhedN14
nasuyod na po ng mabuti may nasunog na resistor papuntang flyback eto po ang value...0.75Ω at 0.22Ω w;a naman atang gnyang resistor aha
Online xxx1987virusxxx
  • Pogi/Ganda Points: 216
  • SERVE THE LORD WITH JOY 0G&68O05H2&12Dcdgn
kung yang resistor na yan sis nka series sa suply ng vertical ok lang yan palitanb mo ng 3ohms pababa...fusible resistor lang naman yan masisisra tlaga yan pag shorted na ic mo or may problema sa vertical mo..nasubukan mo bang direct sub ng yoke...o baka naman may nagkadikit...suyurin mo sis sa vertical lahat bka may leak...tsaka dapat kung maari original na vertical gamitin mo...bka makatulong... :)
"MAY MAS MAGANDANG PLANO ANG DIYOS KAYSA SA MGA PLANO  NATIN"
"A3L ELECTRONICS REPAIR SHOP"
Offline TBG
wala ng oscillation!check muna ng B+ at ibang voltage like 12v,etc...
Offline RhedN14
basura na ata to pagkatpos ko palitan crt socket ayaw na gumana ng crt.kya tama na madami nadin nakain to P1,1050, ang gastos hahaha di parin na ayos tpos bebenta mo 200 lng? ngee
sayang naman nyan try mo uli relax ka muan....step by step trouble shooting mo..
Offline TBG
nanganak na .hehehe,,..
Offline RhedN14
kya nga eh ano kya problema?bgla nlng di guma ung crt nya kya nagsurrender na ako bnenta ng may ari skin 150 haha
Offline >>>???<<<
  • Pogi/Ganda Points: 545
Pahinga muna ng isang araw at re-analyze.
http://www.elab.ph/forum/index.php?topic=41860.0 My DIY transformer... ? ? ? Test Build Uli
http://www.elab.ph/forum/index.php?topic=33717  I2c / spi programmer
http://www.elab.ph/forum/index.php?topic=37150.0 Lcr esr makikigulo rin ba kayo ??? Test Build
http://www.elab.ph/forum/index.php?topic=29963.0 Esr collection na malamig
http://www.elab.ph/forum/index.php?topic=25854.0 Basic C++ Programming Tutorials by Prof Asimo
3T LTB DIY P50 tunogsarilingsikap
Offline TBG
refresh muna ang mind at mag 3n1.
Offline sirjon
  • Pogi/Ganda Points: 138
Baka naka 'standby mode'. On mo sa remote
Offline TBG
sis tama ba ang crt socket ang pnalit mo?i mean na ang mga pins.
Offline RhedN14
wla po ung remote XD
Offline RhedN14
[/img]
yup tamang tama naman  :-[ at wla naman grounded? eto ung socket
www. sourcingmap .com/gzs864-television-part-pin-soldering-pcb-mount-crt-socket-white-p-169827.html
