Author Topic: skills requirement to be a certified electronics engineer  (Read 1060 times)
Offline alphatu_24
« on: August 04, 2008, 06:12:21 PM »
ano bang dapat na alam ng mga ece w/c will help dem to their career sa field...
Re: skills requirement to be a certified electronics engineer
« Reply #1 on: August 04, 2008, 06:14:33 PM »
depende sa gusto mong pasukan. kung sa telecommunications dapat related dun ang skills mo.
Offline gtxr2.ren
  • Pogi/Ganda Points: 8
  • if it can be thought of, it can be done.
« Reply #2 on: August 04, 2008, 09:09:10 PM »
I think the title should be modified and clarified.
To become a certified electronics engineer skill is not needed, you need only to pass the board exams given by PRC. If you pass the board exams then you are a "certified" and "duly registered" electronics engineer. Not unless the boss will give you the certification of being a certified electronics engineer and probably the 'smartest' in the company then skill is a big issue for boss requirements. He will trade-off his "first son" for a vulcan of engineers and programmers.
Q: ano bang dapat na alam ng mga ece w/c will help dem to their career sa field?
A: The most important factor that you need to know which being a successful engineer someday are not the tools u mastered, the techniques u develop, the technology u conquer, or  even the single solution of solving the navier-stokes hypothesis that u have but rather the - quality of yourself - Engineers are never satisfied, they want more and more..more learning, more technical experience, they tend to die more with their designs, trading-off their soul just only to received the characters in the hyper-terminal, etc. which sumtyms they forget their proper conduct if it is still worthy or not and later realizing he forget how to live..It is always been the will and the determination "inside" that makes people success but let's not forget that we are humans and where we came from.
"The only real valuable thing is intuition."
- Albert Einstein
Offline graSS
  • "High"
« Reply #3 on: August 06, 2008, 02:07:26 PM »
EXperience lng po sa field na napasukan mo... ako d2 ako work sa ELectric power company kaya more on electrical practices tsaka swerte rin kc naassign ako sa Protective Relay Section kya ngagamit din ung Electronic practices kc gamit ng company ngayon more on electronic relays na.
