Author Topic: battery charger using relay  (Read 2650 times)
Offline -edz-
« on: February 05, 2008, 04:49:54 PM »
tulong lang po, sino po ang nakakaalam kung paano gawin ang battery charger gamit ang isang relay?
Offline microlan2008
  • live, love, eat, and be happy
Re: relay
« Reply #1 on: February 05, 2008, 04:56:12 PM »
gamit ka na lang ng semiconductor device para sa charger mo instead of relay.
Re: relay
Re: battery charger using relay
« Reply #2 on: February 10, 2008, 01:04:43 PM »
ay ang galing! bakit di ko yan naisip.... kasi bibili pa sana ako ng current meter na 10A. mahal! gagamitin ko lang naman para madetect kung almost zero na yung current! hehehe
ok to!
Offline stcboy
  • Pogi/Ganda Points: 5
« Reply #3 on: February 12, 2008, 02:59:39 AM »
Masusunog po siguro ang winding ng relay unless maliit lang ang charging current .
Offline mcu_expert_daw
« Reply #4 on: February 12, 2008, 07:51:29 AM »
papalitan ang winding nyan depende sa current requirement
« Reply #5 on: February 12, 2008, 08:40:43 AM »
syempre, semiconductor is better than a magnetic relay, pero for the sake that it should work, ok na din yung relay. at syempre, gagamit tayo ng mas mataas na rating para di masunog.
btw, iv known this teacher in electronics, he ask students to use relay as the tripping breaker during short in power supply. and all the time, naka "on" yung relay, di naman nasususunog. so, sa tingin ko,  basta tama yung rating na ginagamit mo, di naman yan masususnog.
  • Pogi/Ganda Points: 412
« Reply #6 on: February 12, 2008, 04:23:27 PM »
I can't really see the point in using the relay in charging circuit..relay is switching device..anu kinalaman nito sa charging?
Offline fnvillafuerte
« Reply #7 on: February 12, 2008, 07:07:30 PM »
Siguro gagamitin nya yung relay to cut off the charging current once the battery is already fully charged para di maovercharge yung batt.
"Failure?  I never encountered it.  All I ever met were temporary setbacks."
Offline -edz-
« Reply #8 on: February 19, 2008, 03:32:41 PM »
opo, gagamitin ko po ito para icut ang current pag full charge na yung battery
Offline pathfinder4wd
« Reply #9 on: February 26, 2008, 01:07:32 PM »
oo nga no, iniisip ko nga rin.
yun pala pang-cut ng current pag full charge na. ;D
need din sigurado ng zener diode para sa voltage cut nya :)
Philippines is a nation of corruption, Filipinos are people of corruption.....
Simulan na ang Pagbabago!
Offline zer0w1ng
  • Pogi/Ganda Points: 305
    • The Cebuano Geek
« Reply #10 on: February 26, 2008, 03:31:12 PM »
Maybe like this:
     +---------------+--o o----o VCC charge
    COM             COIL
  NC  NO---+         |
  |  Z12V  |         C
  +--z<|---+--1K--B NPN
  |        |         E
 BAT       1K        |
 GND      GND       GND
The Cebuano Geek
Offline jctupazvi
« Reply #11 on: April 03, 2008, 08:23:51 AM »
I would suggest you use a thyristor like an SCR. Ang concept kasi nito ay ang holding current which turns on the thyristor kapag natrigger, pero once the current falls below the holding current it will turn off. Kapag ang battery ay magfu-full charge na yung current will lower down until it goes below the threshold then hihinto na yung charging. If you use a transistor para magfeed back dun sa trigger mag-kakaroon ng trickle charging automatic na din ang trigger.
"God does not play dice with the universe".
Offline electronic repairer
  • Pogi/Ganda Points: 12
  • amu lat im....
« Reply #12 on: April 11, 2008, 10:47:24 PM »
Bro share ko lang baka makatulong...
   http://www.4shared.com/dir/6487936/8464e3ae/sharing.html
i'm using this one to design charger for car battery
Patience is the best attitude of an electronic repairer.
Offline kinyo
« Reply #13 on: April 12, 2008, 12:28:38 AM »
yung mga lumang kotse, circa 50's to 60's, relays ang laman ng voltage regulator nila for charging the battery ... one coil limits the voltage, another coil limits the current ... the "alternator" is actually a DC generator  ;D
  • Pogi/Ganda Points: 631
« Reply #14 on: April 12, 2008, 01:01:52 AM »
OT: if I remember correctly yan ang origin ng Switchmode Power Supply...diyan din nagsimula ang Resonant Converters (ZVS - Zero Voltage Switching or Zero Current Switching), napansin kasi nila na ang lakas mag-spark nung relay and mahal ang physical solutions...
Offline ahlburuto
  • E&I tech.
« Reply #15 on: June 06, 2008, 05:43:42 AM »
salamat dito sa info mo....
br
