Author Topic: Homemade Frequency Counter (ICM7225 based)  (Read 16256 times)
Offline ecestud
Re: Homemade Frequency Counter (ICM7225 based)
« Reply #20 on: June 23, 2010, 08:04:01 PM »
hmmmmm. maganda xa... pewde ko bang gawin proposal ito?? kung pwede lang..
Offline webscatter
  • Pogi/Ganda Points: 14
    • Webscatter Online World-WOW
« Reply #21 on: June 23, 2010, 08:49:44 PM »
There is no such "homemade"...change the proposed title
Offline ecestud
« Reply #22 on: June 23, 2010, 09:39:33 PM »
pwede ko ba itoh. e propose na project?? para sa project proposal namin??
Offline webscatter
« Reply #23 on: June 23, 2010, 11:04:12 PM »
circuit ito...u must have apps assign from freq counter...maybe for other related apps or integrate it to become a system
Offline uranium235
  • Pogi/Ganda Points: 8
  • hobbyist, stupident
« Reply #24 on: June 23, 2010, 11:46:58 PM »
magandang isama sa frequency counter ung fucntion generator  ;D
Offline julzbond09
« Reply #25 on: October 17, 2011, 09:53:30 PM »
kuya tinest ko po ung circuit nyu kaso ayaw gumana..d q po alam qng bkit pero ginaya ko lang as in ung drawing..bka po pde phelp..di ko po kc magetz ung logic nung circuit..thankz po..
« Reply #26 on: October 17, 2011, 11:48:58 PM »
gawa ka muna nang schematic diagram mo mismo. block diagram yung drawing eh...
Offline julzbond09
« Reply #27 on: October 18, 2011, 12:29:43 AM »
hindi ko din po kc mgetz ung logic nung block diagram kya nahihirapan po me..i min kung paano po macocount ung frequency gamit ung block diagram :)
Offline julzbond09
« Reply #28 on: October 18, 2011, 12:54:35 AM »
and ung schematic nga po pla nung tinest ko ay nkabase lng dun s block diagram...as in kagag po.. ;D tpos ung JK ay kinonek ko sa +5V..
sa analysis po kasi na ginawa ko...nakita q na the counter will work when store is connected to the ground, reset is supplied/floating and when count is nkclock. Pero panu po ba mcacatch ung dapat na exact reading nung frequency? mag change po ba ung state ng store the time na mreach nung count ung measured frequency? how will the input/measured frequency affect the circuit/output of the circuit? senxa na po..mahina po ako pag dating sa frequencies e.. looking forward for replies.. thanks in advance  :D
Offline nucleus
« Reply #29 on: October 18, 2011, 01:42:33 AM »
naku lokohan ata to natesting na pala gamit yung block diagram?
yung mga sagot sa tanong mo sis ay nasa datasheet
Offline bravokilo
  • Pogi/Ganda Points: 105
« Reply #30 on: October 18, 2011, 09:56:19 AM »
take a look at freq counters parang testers sa deeco for P2,200. kumpleto na. walang ng trip to alexasn,casing, switches etc...mura lang gawa na.
Offline julzbond09
« Reply #31 on: October 18, 2011, 11:40:46 AM »
tiningnan ko na ung mga datasheets ng bawat components kaso hindi nya po aq natulungan maintindihan ung logic nung block diagram :(
Offline julzbond09
« Reply #32 on: October 19, 2011, 01:23:15 AM »
 ;D ngayon ko lang po napansin...continuous po kc ung count nya kya i thought mali ung output..but nung sinukat q ung frequency input q then sa first reading from 0...tama naman cya  ;D un nga lang nag add ung frequency imbis na dapat titigil na cya dun..i think ind lng ng fufunction ng ayos ung sa reset and store q..tingnan ko nlng kung anu magagawa ko para maayos.. ;D thankz po sa block diagram ~  :)
Offline MonDU1FV
« Reply #33 on: December 27, 2011, 06:54:04 AM »
I wish there are kits available for the home constructor. I assembled these more than a decade ago from a kit packed in japan.
Homebrewing or assembling gear is a rewarding activity. yes you can buy ready made stuff, but where is the fun with that?  Heathkit was and is an education company and a primary objective in kit making is education.
I was planning on modifying this old project by breaking out the internal jumper between the prescaler and the counter board. that way, i can use it for the lower frequencies with better performance. An external bnc to bnc jumper will allow me to use it again for vhf/uhf measurements. So since i had it opened up , kinunan ko na rin ng litrato, kataon nabasa ko itong thread na ito kaya pinost ko na rin for reference. hihi.
Offline nucleus
« Reply #34 on: December 27, 2011, 11:29:06 AM »
repost ko lang:
