Author Topic: PICkit2 clone  (Read 14905 times)
Offline magike
PICkit2 clone
« on: August 11, 2008, 08:12:20 PM »
pwede po ba mgprogram ng ibang PIC un PICkit2 clone?? for example PIC16F877/PIC16F84a?? need lang talaga ng USB programmer
PICkit2 clone
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
Re: PICkit2 clone
« Reply #1 on: August 11, 2008, 08:14:47 PM »
it can program lots and lots of PIC MCU ;)
Re: PICkit2 clone
Offline akhen
  • Pogi/Ganda Points: 47
Re: PICkit2 clone
« Reply #2 on: August 12, 2008, 02:18:59 AM »
absolutely yes. Since it is a clone of original Pickit 2, it can do just the same as the original.
Re: PICkit2 clone
Re: PICkit2 clone
« Reply #3 on: August 12, 2008, 06:04:21 AM »
Take note of the word clone.  A lot of pickit2 clones are not actually clones but rather "pickit2 compatible" only to some degree.
Re: PICkit2 clone
Offline magike
Re: PICkit2 clone
« Reply #4 on: August 12, 2008, 03:46:56 PM »
ok.. ;D thanks guyz  ;D ;D
Re: PICkit2 clone
Offline magike
Re: PICkit2 clone
« Reply #5 on: August 12, 2008, 03:56:35 PM »
pwede po ba un PICkit2 clone sa Vista  ??? paano po pala ikabit un target pic sa programmer  ???
Re: PICkit2 clone
« Reply #6 on: August 12, 2008, 04:55:55 PM »
gawa ka ng programming socket, bukas post ko hapon na kasi uwian na.
Offline magike
Re: PICkit2 clone
« Reply #7 on: August 12, 2008, 06:09:02 PM »
thanks po ng madami... :D....hintayin ko po
Offline magike
Re: PICkit2 clone
« Reply #8 on: August 14, 2008, 10:49:00 AM »
meron po ba nakakaalam ng programming socket para sa PICkit2 clone???? hindi na kasi ngpost c nomad
Re: PICkit2 clone
« Reply #9 on: August 14, 2008, 11:05:58 AM »
Sory po nalimutan ko na, ito na po:
for softcopy pki pm na lang sa akin ung email add nyo.
This will work for any size ng pic at memory as long as tatama ung programming pin.
You can use this as reference sa position kung saan ilalagay ang mga pic.
http://www.winpic800.com/descargas/REV2/ZIF_10_12_16_18_24_93_rev2.pdf
Offline magike
Re: PICkit2 clone
« Reply #10 on: August 14, 2008, 04:04:17 PM »
cge po...thanks po
Offline magike
Re: PICkit2 clone
« Reply #11 on: August 14, 2008, 08:34:15 PM »
Re: PICkit2 clone
« Reply #12 on: August 18, 2008, 12:19:15 AM »
may tanong ako dito...
based from http://www.winpic800.com/descargas/REV2/ZIF_10_12_16_18_24_93_rev2.pdf,
for instance pic16F84 ang ipoprogram natin, 18pins yan,
ang kailangan na pins ay pin numbers 4,5,12,13 and 14 (vpp,vss,pgc,pgd and vdd, respecively)
makikita natin, na ang pin16(osc1/clkin) ay nakaconnect sa VDD.
PIN18, connected sa PGC... at marami pang ibang pins aside sa required ang nakakabit.
natutunan ko dito na pwede pala yun...
pero ang tanong ko, bakit pwedeng ganun?
Offline 1110000
  • Pogi/Ganda Points: 28
Re: PICkit2 clone
« Reply #13 on: August 18, 2008, 12:21:33 AM »
meron din ako design
E153C51513
Offline 1110000
Re: PICkit2 clone
« Reply #14 on: August 18, 2008, 12:28:03 AM »
hehehehe nilagyan ko ng led :) para kapag nagpoporogram ay iilaw yung indicator kung saan dapat nakatapat yung PIN 1 ng chip ;) hehehehehehe kumpleto na yung board ko na yan kulang na lang ng IDC connector ::) baka may mabait na magbibigay saakin dyan ;D
E153C51513
Offline 1110000
Re: PICkit2 clone
« Reply #15 on: August 18, 2008, 12:30:03 AM »
atsaka sakto nakakabit na rin sa isang HC-001 na housing from Alexan :D inalis ko yung isang side ng HC-001 tapos yung board yung ipinalit ko ;D bukas kuhanan ko ng pict
E153C51513
Offline 1110000
Re: PICkit2 clone
« Reply #16 on: August 18, 2008, 12:31:58 AM »
yung saakin po kung hanggang 18 pin yung chip itatapat doon sa isang led sa baba tapos yung jumper ay ililipat din sa baba :D
kaya po pwedeng ganun kasi ginawa ng Microchip na ganun :) para madali ang programming :)
E153C51513
Re: PICkit2 clone
« Reply #17 on: August 18, 2008, 12:45:47 AM »
nice... ok yan... gamit ka nga filled plane para tipid sa etching solution.
kaso, bakit nga ba pwedeng ganun? heheh
Re: PICkit2 clone
« Reply #18 on: August 18, 2008, 12:47:46 AM »
unang tingin ko parang tali yung mga traces  hehehe ;D
Offline 1110000
Re: PICkit2 clone
« Reply #19 on: August 18, 2008, 12:50:43 AM »
sige po next time :)
kaya po pwedeng ganun ay dahil hindi nakakaabala sa programming kahit nakakabit iyon doon :) parang nag poprogram ka lang ng incircuit diba? nakakabit sa mga peripherals yung ibang pin pero di pa rin naiistorbo yung programming :)
E153C51513
Re: PICkit2 clone
