Author Topic: Microsoft Visual Studio 2008 Service Pack 1  (Read 1134 times)
« on: August 12, 2008, 07:37:38 PM »
Offline lavender2010
Re: Microsoft Visual Studio 2008 Service Pack 1
« Reply #1 on: February 01, 2010, 03:20:56 AM »
http://www.microsoft.com/downloads/details.aspx?FamilyID=27673c47-b3b5-4c67-bd99-84e525b5ce61&DisplayLang=en
hello po!
pa help po sna sa project nmin, kasi po kabado na kmi dhil mlapit na deadline nmin...huhuhu     :'(     :'(      :'(
eto po ung problems nmn
1. How to use the serialport component of microsoft visual basic 2008?   ???
            naguguluhan na po ako sa mga topics na nkikita ko sa net,
            tapos ung mismong msdn forum po hnd nmn diniscuss ung pang vb 2008
            patulong po pls...
            tapos kung meron po kayong easy to understand sources and/or sample codes pa-dagdag ndin po pls
2.How to interface the pic4550 with a laptop (vista os) using vb 2008?      ???
            anu po ung mga kelangan both for hardware and software tapos
            panu po ung paraan ng programming?
3. hehe? may alam po ba kayong tool na pwedeng gmitin pra macontrol ung application na tinawag gmit ang process component ng vb 2008?   :-[
             for example po ung amcap.exe ng a4tech, ung webcam po..
             na kung saan po ginamit ko xa sa vb 2008 as process1 sa aking form1 where it is opened and closed (only) by button1
             eh ang gusto ko po sna eh, macontrol ko din kung panu xa mag-exit,
             like the way i could control which can close my form1, either the user, application or task manager...
4. (kalabisan!!!)   ehehehe..patulong nmn po sa license ng psremote1.81...     ::)
i really hope matulungan nio po kmi..lalong lalo na po sa problems 1 and 2 nmn...
:'(     huhuhuhu...2 weeks nlng po, submission na...
tlagang in dire need of help po kmi..
pleassseeee po!!!!
eto na po ung final stage nmn with regards sa hardware ng project nmn..pleassse po patulong
malakilakilakilakilakilakilaking at madamidamidamidamidaming THANKS in advance po!!!      :D
« Reply #2 on: February 01, 2010, 08:11:07 AM »
hello po!
            patulong po pls...
pleassseeee po!!!!
1. applicable din naman yung C# sample codes ng serialport component,  magiiba lang ng syntax pero same din ang principle.
Ganito lang naman paggamit nun: Sa Form Designer, set mo na yung mga properties nung component. Tapos sa code mo, call mo yung Open() Method. Tapos pwede mo na gamitin. (After mo gamitin, call the close,dispose method :) )
2. USB PIC ito, pero based sa unang tanong mo, ang gagamitin mo is SerialPort Component? Tama ba ako? Look for the app note ng microchip na Migration from RS232 to USB. May mga sample codes jan. Makikita mo rin mga sample codes sa Microchip USB Framework.
3. Take a look on the Process class sa MSDN.
4. hijack ;D heheh...
« Reply #3 on: February 01, 2010, 09:21:24 AM »
hehe wala pa kong SP1 nito.. =) pero 2008 gamit ko..=)
@TS,
yung sa
2. pede mo check mga samples ng CCS C..=)
Offline black_circuit1
« Reply #4 on: December 20, 2010, 09:14:07 PM »
vb.net po yan???what the diffence with .net and ung wala??
« Reply #5 on: December 20, 2010, 09:20:44 PM »
ipapa-delete ko na siguro itong thread.. outdated na kasi ang VS2008 :D may VS2010 na...
« Reply #6 on: December 21, 2010, 09:29:51 AM »
i lock mo na :D
« Reply #7 on: December 21, 2010, 09:34:12 AM »
locked :D
