Author Topic: power supply  (Read 3526 times)
Offline striker_24
  • Pogi/Ganda Points: 33
  • www.cantsolve.blogspot.com
    • TUPPERWAREZ___CANTSOLVE
power supply
« on: August 20, 2008, 10:13:08 PM »
Pwede po bang humingi ng idea or design kung pno gumawa ng POWER SUPPLY?
12Volts po ang maximum tpos 1Ampere ang current..
Salamat sa mga tutulong! ;)
striker_24
power supply
Offline beginner wan
  • Pogi/Ganda Points: 46
    • [im]Duino
Re: power supply
« Reply #1 on: August 20, 2008, 10:15:41 PM »
pwede ka gumamit ng 7812 na regulator... or LM317, pwede din.. ;D
Re: power supply
  • Pogi/Ganda Points: 635
Re: power supply
« Reply #2 on: August 20, 2008, 10:16:34 PM »
transformer, rectifier, filter capacitor, then 7812. ;D na-post na pala ni wan. ;D
Re: power supply
Offline mArKhAo
  • Pogi/Ganda Points: 70
  • point and shoot
Re: power supply
« Reply #3 on: August 20, 2008, 10:17:11 PM »
pwd dn ung madaming secondary winding. hehe, ung mano mano ung switch, ganun ung una qng power supply e. hehe
Re: power supply
Re: power supply
« Reply #4 on: August 20, 2008, 10:18:09 PM »
hehehe. ganun din supply ko. improved na ngayon dahil may regulator na. ;D
Re: power supply
Offline p®otocol
  • Pogi/Ganda Points: 57
  • konni chi wa
Re: power supply
« Reply #5 on: August 20, 2008, 10:48:52 PM »
what is 7812???
Selling Arduino Uno & Shields
www.circuit-help.com.ph
Offline mArKhAo
  • point and shoot
Re: power supply
« Reply #6 on: August 20, 2008, 10:52:26 PM »
78L12 isang uri ng 3-terminal regulator kung saan 12 volts ang output nya. at ang input ay mga 24volts? hehe, nsa datasheet nmn po un. ;)
Offline p®otocol
  • konni chi wa
Re: power supply
« Reply #7 on: August 20, 2008, 10:55:08 PM »
dc to dc poh b un??
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
Re: power supply
« Reply #8 on: August 20, 2008, 10:55:19 PM »
^ it is a voltage regulator IC
7812 yung generic name that can supply a +12V and 1 A max current typical, though some other 7812 IC versions can provide 1.5A
meron din 78L12 which can only provide 100mA
Offline p®otocol
  • konni chi wa
Re: power supply
« Reply #9 on: August 20, 2008, 11:02:22 PM »
ah i see! thnx..!
Offline paranz
Re: power supply
« Reply #10 on: August 20, 2008, 11:08:11 PM »
just refer to your favorite electonics design textbook for more detailed discussion ;)
Offline striker_24
Re: power supply
« Reply #11 on: August 20, 2008, 11:35:11 PM »
slamat po sa lhat! Kya lng,la akong idea sa pggwa e..pwede po bng mkhngi ng suggestion bout sa design?
Offline paranz
Re: power supply
« Reply #12 on: August 20, 2008, 11:41:00 PM »
sa mga textbooks, nandoon na yung discussion sa theory, formula, circuit operations as well as the PS circuit itself ;)
Offline striker_24
Re: power supply
« Reply #13 on: August 20, 2008, 11:45:41 PM »
anong specific pong book? :D
Offline paranz
Re: power supply
« Reply #14 on: August 20, 2008, 11:48:20 PM »
any electronics textbooks
boylestad
floyd
neamen
etc
Offline striker_24
Re: power supply
« Reply #15 on: August 20, 2008, 11:51:38 PM »
ok sir..tnx poh!
pwede mo rin po ba akong m2lungan sir bout dito?
http://www.electronicslab.ph/forum/index.php?topic=4201.0
Offline mArKhAo
  • point and shoot
Re: power supply
« Reply #16 on: August 21, 2008, 01:19:07 AM »
bakit kailangan mo pa ng resistor bank ???
Offline striker_24
Re: power supply
« Reply #17 on: September 11, 2008, 10:33:21 PM »
project din po kc nmin ang rsistor bank e..pwede mo ba kong mtulungan sir?
lamat!
nu po pla ang lhat ng mga kkailanganin sa pggwa ng power supply?
    • [im]Duino
Re: power supply
« Reply #18 on: September 11, 2008, 10:46:07 PM »
ayan ang kailangan mo..  ;D
Offline ferdie444
Re: power supply
« Reply #19 on: September 12, 2008, 02:50:07 AM »
@ striker_24,another option is to use transistor and zener diode.
parts list:
T1-transformer 220vac/7.5vx2(c.t.)@ 1A
D1-4 or bridge type diode 2a/50v rectifier
C1-2,200uf/25v or 4,700uf/25v electrolytic cap./filter(input)
C2-470uf/16v electrolytic cap./zd1 filter
C3-1000uf/16v filter out cap.electrolytic
R1-390 ohms/.5w carbon
Zd1-12v/.5w zener diode
Q1-C1060 regulator x'tor w/ heatsink
thanks @ sana makatulong......
Re: power supply
