Author Topic: power supply  (Read 3519 times)
Offline ferdie444
  • Pogi/Ganda Points: 4
Re: power supply
« Reply #20 on: September 12, 2008, 03:22:28 AM »
@ striker_24,another option is to use transistor and zener diode.
parts list:
T1-transformer 220vac/7.5vx2(c.t.)@ 1A
D1-4 or bridge type diode 2a/50v rectifier
C1-2,200uf/25v or 4,700uf/25v electrolytic cap./filter(input)
C2-470uf/16v electrolytic cap./zd1 filter
C3-1000uf/16v filter out cap.electrolytic
R1-390 ohms/.5w carbon
Zd1-12v/.5w zener diode
Q1-2SC1060/61 regulator x'tor w/ heatsink
thanks @ sana makatulong......
Re: power supply
Offline striker_24
  • Pogi/Ganda Points: 33
  • www.cantsolve.blogspot.com
    • TUPPERWAREZ___CANTSOLVE
Re: power supply
« Reply #21 on: September 17, 2008, 02:55:57 PM »
thank u po ng mrmi sa lhat!
Re: power supply
Offline striker_24
Re: power supply
« Reply #22 on: September 18, 2008, 09:00:33 PM »
bnago na po pla ang specs..
Power Supply with an output of 0-12V (whole numbers only; 0, 1, 2, 3, 4, ..., 12) and 1A..
cno po my schematic nito?
Nu pong mterials kelngan gmitin?
lamat! ;)
striker_24
Re: power supply
Offline ferdie444
Re: power supply
« Reply #23 on: September 18, 2008, 09:31:55 PM »
lamat! ;)
striker_24
@striker_24,pls refer on my previous post na parts list,bale palitan mo lamng ung T1-transformer den remove mo ung c2,c3,zd1 and q1 @ change mo ung value ng r1=1k @ 1w pati ung c1=2,200uf/16v plus rotary selector switch 6 poles and don't forget to put fuse f1=1amp sa primary.you can put also on/off switch sa main ac line line.otherwise meron din nman na power supply kit na mabbili sa alexan and deeco w/ schematic diagram....
Re: power supply
Offline graSS
  • "High"
Re: power supply
« Reply #24 on: September 18, 2008, 09:39:04 PM »
try this one... simulated na rin yan, u can add or change some parts pra mgkaroon ka ng idea kng paano mgstart...
Re: power supply
Offline striker_24
Re: power supply
« Reply #25 on: September 19, 2008, 10:47:28 AM »
wla po kc ako sa mnila e kya di ako mkkbili sa alexan..:(
nwei,lamat po sir! tpos,send mo nalng po skin sir ang schematic na cnbi m po ha..:D
lamat! ;)
thanks po sir sa diagram..;)
Re: power supply
« Reply #26 on: September 19, 2008, 10:58:25 AM »
Maybe you could start at 1.5 V minimum then saka ka pa lang magstep ng 1v increment.
eto simple schematic nya using lm317
to make different voltage palitan mo lang ung value ng r2 using ng calculator below
http://www.electronics-lab.com/articles/LM317/
kung hindi possible ang fixed value resistor dahil sa unavailable ito gumamit ka ng variable resistor.
eto simpleng diagram. just add more resistor to create more output.
Offline striker_24
Re: power supply
« Reply #27 on: September 24, 2008, 12:30:30 PM »
mrming slamat po sa mga tumulong!..
isa nlang po problem ko ngaun,dpat po mging zero or 0.1 ang minimum Voltage..
0.6 po kc sa actual ang ngging minimum e..
here is the schematic diagram..
lamat po uli! :D
note:
LM317t po pla ang gmit kong regulator..;)
striker_24
Offline 'yus
  • Pogi/Ganda Points: 299
  • hw -> fw -> sw
    • yus' projects
Re: power supply
« Reply #28 on: September 24, 2008, 12:37:48 PM »
'di ba 1.25V ang minimum output ng LM317? ???
Re: power supply
« Reply #29 on: September 24, 2008, 12:47:48 PM »
pra dyan kailangan mo ng negative reference.
Re: power supply
