Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Mixed Systems and Specialization
Communications Engineering
General Wireless Communication
(Moderator:
marcelino
Impedance Matching
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Impedance Matching (Read 2241 times)
rdpzycho
Technical People
Solar Power Satellite
Pogi/Ganda Points: 632
Gender:
Respect Begets Respect
Impedance Matching
on:
August 28, 2008, 08:57:14 PM »
question sa mga RF engineers at mahilig sa RF.
'yung device kasi 50 ohms ang impedance tapos 75 ohms 'yung coax. kailangan ko ng wideband matching (halos DC to 1GHz
), resistive network 'yung una kong design (L-pad) dahil pinaka-simple (at pinakamura
). based sa mga texts, insertion loss nung resistive network 5.7dB lumalabas. kapag hindi ako nagmatch 0.177dB naman ang mismatch loss. is it really worth to match the impedances kahit na halos 1/4 na lang ang matitira sa akin sa resistive network o ok na 'yung mismatched at 0.177dB mismatch loss and VSWR of 1.5:1?
pwede ko pa rin namang i-consider ang LC matching, pero mukhang mababa naman na 'yung VSWR at mismatch loss. sa ngayon lalagyan ko lang muna ng provision para sa L-network kung sakali mang ima-match ko.
Logged
"Divide each difficulty into as many parts as is feasible and necessary to resolve it."
Impedance Matching
on:
ef - el - ay - pee
Lead Acid Battery
Pogi/Ganda Points: 34
Gender:
Regrets, I have a few...
Re: Impedance Matching
Reply #1 on:
August 28, 2008, 11:21:38 PM »
mukhang maliit lang naman ang mismatch loss...pwede na po siguro
Logged
"Engineers are the Oompah-Loompahs of Science" - Dr. Sheldon Lee Cooper
Reply #1 on:
rdpzycho
Technical People
Gender:
Reply #2 on:
August 28, 2008, 11:31:41 PM »
'yun din nga iniisip ko. hehehe.
Logged
Reply #2 on:
ef - el - ay - pee
Lead Acid Battery
Gender:
Reply #3 on:
August 28, 2008, 11:34:19 PM »
kung di naman po kayo nasasayangan sa power ok na yun, di po ba maximum power transfer lang naman ang purpose natin sa matching, di naman po siguro ganun kasignificant ang heat na maproproduce ng untransfered energy due to mismatch...
Logged
Reply #3 on:
rdpzycho
Technical People
Gender:
Reply #4 on:
August 28, 2008, 11:41:13 PM »
maliit lang 'yun. nasa -20dBm lang 'yung signal ko.
Logged
Reply #4 on:
ef - el - ay - pee
Lead Acid Battery
Gender:
Reply #5 on:
August 28, 2008, 11:44:44 PM »
pero di ko po kasi alam ang long term effects ng mismatch, pero since mababa lang...teka research muna ako...
Logged
rdpzycho
Technical People
Gender:
Reply #6 on:
August 28, 2008, 11:51:38 PM »
'yan din ang concern ko, puro theory at concepts lang kasi ang alam ko pagdating sa matataas na frequency, in practice wala akong alam kung ok na bang palagpasin 'yun. theoretically kasi mababa naman parehas ang mismatch loss at VSWR (sa ibang device pwedeng 4:1 ang VSWR at acceptable pa rin).
isa ko pang problema, walang Network Analyzer sa office. kapa kapa lang.
Logged
ef - el - ay - pee
Lead Acid Battery
Gender:
Reply #7 on:
August 28, 2008, 11:59:41 PM »
pupugak pugak rin ang VNA dito, at di ko pa natry ang mismatch, well sana ma try ko to hahaha
Logged
paranz
Technical People
Nuclear Reactor
Pogi/Ganda Points: 177
Gender:
1/4W resistor specialist
Reply #8 on:
August 29, 2008, 12:01:45 AM »
OT: how much ba ang VNA ngayun? yung pinakamura..
Logged
PIC16 Programming Tutorial using MPLAB and Hi-Tech C
www.rapidsignalph.com/tutorials/pic16-tutorials
Arduino & gizDuino Tutorials
www.rapidsignalph.com/tutorials/arduino-tutorials
ef - el - ay - pee
Lead Acid Battery
Gender:
Reply #9 on:
August 29, 2008, 01:46:53 AM »
ewan, matagal nang nilalait ng electronix yung HP naming VNA,kelangan na daw palitan, kasi nagbebenta sila ng VNA na 2M ang isa...nagdemo sila sa amin as if naman kami ang may K bumili, strategy is that ma-amaze kami para mapilitan ang lab head namin na i-endorse sa Admin na bumili nito, o well...
Logged
gie62
Lead Acid Battery
Pogi/Ganda Points: 56
Gender:
Reply #10 on:
September 07, 2008, 07:33:16 PM »
sir, meron namang 50 ohms na coax, dapat ba talagang 75 ohms ang coax na gagamitin? 1.5:1 na vswr ok naman ito, pero mas maganda kung kaya pang ibaba. ang long term effect ng mataas ang vswr ay masisira ang rf amp. ng device. ano ba gamit ng device mo sir?
Logged
rdpzycho
Technical People
Gender:
Reply #11 on:
September 07, 2008, 09:27:40 PM »
75 ohm coax kasi 'yung panggagalingan ('yun ang ipro-provide nila, ayaw nilang magpalit sa 50 ohm coax).
50 ohm input nung LNA, medyo mababa naman input kapag mineasure, nasa -70 to -80 dBm siguro.
Logged
Hydroelectric
Pogi/Ganda Points: 123
Truth suffers, but never dies.
Reply #12 on:
September 07, 2008, 09:53:11 PM »
Okay naman ata yan na mismatch, kasi mas malaki yong coax imp kay sa device saka min lang ang VSWR, matanong ko lang RX at TX ba ang device mo?
Logged
rdpzycho
Technical People
Gender:
Reply #13 on:
September 07, 2008, 09:57:21 PM »
ang mangyayari, ipapasok 'yung device sa pagitan nung 75 ohm coax. wideband input kaya hindi ko magamitan ng reactive matching (medyo maraming passives kapag pinilit kong gamitan ng reactive match 'yung buong band), resistive lang ang simpleng design. tapos ilalabas ko ulit papunta sa 75 ohm coax. wala na akong problem sa output, medyo mas madali i-match.
Logged
zer0w1ng
Technical People
Gas Turbine
Pogi/Ganda Points: 305
Gender:
Enter any 11-digit prime number to continue...
Reply #14 on:
September 08, 2008, 08:53:23 AM »
A 1:1.5 wideband transformer will do.
Logged
The Cebuano Geek
gie62
Lead Acid Battery
Gender:
Reply #15 on:
September 08, 2008, 10:30:05 AM »
sir sa CATV ba ang paggagamitan ng device? yung mini circuits device(MAR-X) mukhang sakto dyan sa project mo. sir kung nadadalian ka sa output matching, yun din ang gamitin mo sa input. reverse mo lang yung input output. kailangan mo talagang imatch yan kasi ang hina ng signal input mo, baka humina pa yan dahil sa mismatch..
Logged
rdpzycho
Technical People
Gender:
Reply #16 on:
September 09, 2008, 12:30:23 AM »
'yung output ko kasi narrowband na kaya madali ang matching. thanks.
meron akong amp din from mini circuits ERA-x. 'yun kasi 'yung medyo marami.
sa ngayon, wind muna ako ng transformer para sa experiments.
Logged
xdaatom206
Size AAA Battery
Pogi/Ganda Points: 0
Reply #17 on:
September 12, 2008, 12:55:06 PM »
Hello Sir,
Are you still a student?
Supplier ako ng RF test equipments maybe we could cater to your needs based on your budget
We have SPA na handheld and we also have VNA na 2 ports
www.rohde-schwarz.com
Key Facts
The tracking generator extends the R&S FSH3
Frequency range 100 kHz to 3 GHz
High level accuracy: 0.5 dB typ
Displayed average noise level typ. -114 dBm (RBW 1KHz)
Resolution bandwidths 1kHz to 1 MHz, 1 and 3 steps
Wide range of detectors : sample, max/min peak , auto peak, RMS
Tracking Generator from 5 MHz to 3 GHz
Logged
rdpzycho
Technical People
Gender:
Reply #18 on:
September 12, 2008, 08:48:08 PM »
nope. commercial project.
Logged
Reply #18 on:
Print
Pages: [
1
Go Up
« previous
next »
(Moderator:
marcelino
Impedance Matching
