Author Topic: PCI TV Tuner to Stand alone TV Tuner Mod  (Read 1861 times)
Offline n0th1n6
  • Pogi/Ganda Points: 62
« on: September 04, 2008, 10:05:30 AM »
Hi, Meron po nakapagsabi sakin na madali lang daw i modify yung PCI TV Tuner to stand alone TV Tuner. Marami na din kasing 2nd hand tv tuner ngayun na 500petot lang, baka sakaling meron pong naliligaw na schematic dyan :D. Tnx
Re: PCI TV Tuner to Stand alone TV Tuner Mod
« Reply #1 on: September 04, 2008, 03:21:05 PM »
Parang mahirap ito ksi ang PCI TV tuner eh wla nmang composite TV out. Kailangan mo ng computer to process the image from the tuner then convert it to a signal with which the computer sends to the monitor thru video accelerator card.
Online glutnix_neo
  • Pogi/Ganda Points: 166
    • Underground Workbench
« Reply #2 on: September 04, 2008, 03:31:20 PM »
lakas ng trip mo bro ah, hehehehe
i would suggest bili ka na lang ng TV tuner na VGA output,
Offline n0th1n6
« Reply #3 on: September 04, 2008, 04:20:46 PM »
:D, nagbabakasakali lang naman po. Minsan kasi tayong mga pinoy eh masyadong malilikot ang isipan, baka kako eh meron nang gumawa at gusto namang mag share hehe.
Online glutnix_neo
« Reply #4 on: September 04, 2008, 06:26:03 PM »
cheapest alternative na nga yung tv tuner for monitor, no need pa ipowerup ang pc, kahit lcd monitor lang.
« Reply #5 on: September 04, 2008, 09:30:55 PM »
check mo datasheet nung TV Tuner na nasa yerong lalagyan. kapag ang output noon ay Video IF at FM PLL merong demodulator, makakakuha ka ng idea sa I2C specification sheet. ;D
meron ding mga Tuner na ang output ay CVBS na, 'yun lang hindi mo magagamit sa LCD monitor. from CVBS to VGA/RGB/YPbPr, that's a different story.
I can't share every detail but this is doable. ;D
basta check mo lahat ng datasheet ng IC, kung ASIC, wala ka nang magagawa. at one part diyan ginawa 'yung demodulation (pwede ring wala) at pinasok sa ADC.
Offline engr...
« Reply #6 on: August 16, 2009, 01:26:34 PM »
e2ng po bang tv tuner eh pedeng ikabit s lcd projector directly??para no nid for tv na hehhe.. meaning ang pinakamonitor ko eh ung projected image ng projector??
Offline tiktak
  • Pogi/Ganda Points: 203
    • Tiktakx's Blog
« Reply #7 on: August 16, 2009, 01:31:00 PM »
madami nitong TV Box sa CDRKING diretso projector na yun
8051 stuff
Offline Woots29
  • Pogi/Ganda Points: 344
  • asan si mojacko?
    • Woots Page
« Reply #8 on: August 16, 2009, 03:11:34 PM »
sir noth1ng, gumawa na ko nyan dati sony tuner ang ginamit ko kasama na yung IF block
with additional potentiometer and 32 volts, and 9 volts supply
and audio video outputs,
ok na ok ang dating
ginawa ko ulit sa lumang VHS player na my built in IF block
hmm
tagal na pala neto nabuhay uli dahil sa projector ;D
WootsPC2 Videos  Woots Page
Offline n0th1n6
« Reply #9 on: August 16, 2009, 04:10:25 PM »
Oo, nakalimutan ko na nga rin to kasi bumili na ako nung TV Box sa CDR King. Pero me nakapagsabi sakin na pwede nga daw gawin talaga. Ni-confirm ko lang po dito kung meron na nakagawa.
« Reply #10 on: August 16, 2009, 04:17:59 PM »
merong Philips demodulator na CVBS plus Audio ang output. 'yung TV Box ko (KWorld) 'yun ang IC pero 'yung PCI TV Tuner ko dati, 'di ko na-check kung ano 'yung demodulator (nawala na).
typical, I2C ang control sa paglipat ng channel doon sa mismong tuner na box.
