Author Topic: dc to dc converter (12V to 3V)  (Read 1971 times)
Offline lightelectro
  • Pogi/Ganda Points: 51
    • Android Tablet Lover
« on: September 04, 2008, 08:34:23 PM »
hello, sino po ba may circuit nito? kasi gagamitin ko sa kotse na 12V battery. gusto ko kasi i power ang small fm radio na 3V. unang ginawa ko ay potentiometer, voltage divider. meron paba kayong ibang masa suggest?  8)
LATEST ANDROID TABLET NEWS
http://androidtabletlover.blogspot.com/
Offline beginner wan
  • Think Positive! Matutupad yang dream mo!
    • [im]Duino
Re: dc to dc converter (12V to 3V)
« Reply #1 on: September 04, 2008, 08:55:44 PM »
pwede ka pong gumamit ng LM317.. pwede mo maset yung regulated output voltage sa kanya from 1.25 to 37 volts IIRC..  ;D ;D ;D
i;0.?QrEpM?4DEZZ]bkH{w@F<38.Jq@92Ds3KPQj60?EA7U\3M<A84J|AI.H
R@>&?Ej,@;5H)o::7KE/:?QcXf?gX'39=,Z_Q[eYXc
« Reply #2 on: September 04, 2008, 09:02:10 PM »
thanks po. what do you think sa paggamit nang potentiometer as a voltage divider circuit?  8)
Offline 1110000
  • Pogi/Ganda Points: 28
  • 6 yrs ng napa2Xso sa soldern iron at di pa titigil
    • http://yelectronics.net63.net
« Reply #3 on: September 04, 2008, 09:07:10 PM »
??? ...................................... bad practice ;D
E153C51513
    • [im]Duino
« Reply #4 on: September 04, 2008, 09:14:37 PM »
hehehe.. tama si totoy.. saka kasi, pag nagbago yung input voltage, magbabago din yung output mo.. saka kung di ako nagkakamali, sayang yung ibang power at nagiging init..
« Reply #5 on: September 04, 2008, 09:57:12 PM »
yap. thanks. try ko mga 500k na potentio. hindi pwede kasi maliit na ang current. thanks. meron pa naman akong regulator na 317. thanks.  8)
Offline underprezzure
  • Destroyer! Web Crawler! Buster! Babaylan!
    • www.instructables.com
« Reply #6 on: September 05, 2008, 12:47:54 AM »
Tama ka waste of power nga ito. but there is a solution. especially when other components runs at 12V and others runs lower from it and if you need a single power source. Here is the solution. Use a switching regulator before the voltage regulator.  ;)
-underpazz campaigns for more post on technical threads
I am not reinventing the wheel, I am just making a difference.
Follow Forum Rules and Regulations
Search the forum before posting
Zero tolerance on spam
Stop thread hijack
Online glutnix_neo
« Reply #7 on: September 05, 2008, 08:01:49 AM »
bad practice daw oh, parang may nakita ako dati bata na ngpost na inisasuggest yun dati, hehehehe,
masearch nga yung post na yun :-*
Offline engineer7@home
  • Pogi/Ganda Points: 13
  • Google Search--> Noel Rios Circuit Cellar
« Reply #8 on: May 21, 2010, 02:36:14 AM »
For efficiency and simplicity, pwede kang gumamit ng buck regulator.  Marami kang pag pipilian sa www.maxim-ic.com.  Wag mo lang kalimutan na mag lagay ng inline fuse from the battery papuntang buck regulator.  Also please use the right size of inductor and capacitor to minimize the noise. In addition, use a schottky diode like a 1N5819 and not a 1N4001 for efficiency if needed in the circuit.
If this helps, please give me a pogi point.
Love the Lord your God with all your heart & soul and with all your mind & strength.And love your neighbor as yourself.
The devil only comes to Kill,Steal & Destroy John 10:10
UKrobotics
Microcircuits gave me schizophrenia for Php2600/month in 1992
Offline badalicious
« Reply #9 on: February 02, 2011, 08:02:44 AM »
pwed po phingi ng circuit ng 12v-3v converter using lm317.tnx po
