Author Topic: patulong nmn posa project nmin about scoreboard  (Read 5139 times)
Offline micromindfs
  • <center><embed src="http://www.layoutcodez.net/fla
Re: patulong nmn posa project nmin about scoreboard
« Reply #20 on: September 14, 2008, 04:46:17 PM »
mga sir yan n po ngawa ko,two digits lang po muna.score p lang po yan
sa code lng po my problem....p ckeck nga po....
Code: [Select]
#include<pic.h>
//Configure Bits
__CONFIG(XT & PWRTDIS & WDTDIS & UNPROTECT);
//Delay
void delay(void)
int t;
for(t=0;t<=0x00FF;t++)
void main (void)
      unsigned char digit=0x00;
      unsigned char tens;
      unsigned char ones;
      TRISA  = ~0x0F;
      TRISB  = ~0x0F;
      PORTB &= ~0x0F;
      PORTA &= ~0x0F;
      while(1)
       tens = digit/10;
       ones = digit - (tens * 10);
       //ones
       PORTA=0x01;
       PORTB=ones;
       delay();
       //tens
       PORTA=0x02;
       PORTB=tens;
       delay();
        if(RB4==0)  //plus1
        delay();   //debounce delay
        digit+=1;
        if (digit>99)
            digit=0x00;
if(RB5==0)  //plus2
        delay();
        digit+=2;
        if (digit>99)
            digit=0x00;
       if(RB6==0)  //plus3
        delay();
        digit+=3;
        if (digit>99)
            digit=0x00;
if(RB7==0)  //minus1
        delay();
if (digit>0)
             digit-=1;
        if (digit<0)
            digit=0x00;
pnu po pag 3 digits n?
Offline micromindfs
« Reply #21 on: September 14, 2008, 05:01:16 PM »
Mga sir, 3 digits na score...
pahingi nmn po ng code....
post nyo nlng po code.....tnx
  • Pogi/Ganda Points: 635
« Reply #22 on: September 14, 2008, 07:28:27 PM »
actually kahit siguro hanggang 100 7 segments kakayanin ng isang PIC16F84. pero hindi mux/demux gagamitin. try to search for 74HC595, latching shift registers. 3 pins lang kailangan mo for dozens of 7 segments.
merong gumagawa ng scoreboard isang PIC16F84 lang ang gamit. eto rin ang gamit para 3 pins (+2 for supply and ground) para pwede mapagbali-baligtad 'yung connector from shot clock to time clock, etc.
« Reply #23 on: September 15, 2008, 04:05:22 AM »
salamat po sa inyong lahat...huh...
mga sir,balak ko kc 2 pic16f84 nlng ggmitin ko.ung 1 para sa timer and shot clock then ung isa sa score.pwede po b un?
ung sa timer nd shootclock nlng kelangan ko....
salamat sir gigs....gamitin ko bigay mo.un din po b ang code pag 3ssd?
hehe yung nakapost na code pang mikroC na compiler yan, yan yung unang gawa ko, kaya pati yung EEPROM read/write hindi ko pa nailalagay.. tapos na yung Code ng pang 3 SSD ko, what i mean complete na sya.. timer naman ang gagawin ko..  next time gagawa ako nito na gagamit ako ng shift registers ^_^
not familiar sa syntax ng Hitech eh kaya hindi ko maintindihan ehhehehe
pede kang magrely dun sa mga sample codes ni sir paranz sa tutorial thread nya..^^
Offline micromindfs
« Reply #24 on: September 15, 2008, 10:20:21 AM »
ganun po b,ginamit ko po hitech,kc po d ko nabuilt sa mplab ung code mo,kaya po edit ko nlng.
penge po code mo sa 3SSD,try ko po simulate.bkit po ganun pag press ko ung 1 pt button,kung anu-ano lumulabas n number?ganun lng ba talaga pag dito sa simulator lang?pag sa hardware nb labas n ung true value?
Offline micromindfs
« Reply #25 on: September 15, 2008, 10:23:59 AM »
salamat po uli sir gigz09!!!!
Offline anthonydp
  • Pogi/Ganda Points: 54
    • My Empty Blog
« Reply #26 on: September 15, 2008, 11:00:01 AM »
#include<pic.h>
//Configure Bits
//Delay
void delay(void)
   int t;
void main (void)
      unsigned char hundreds;
      unsigned char tens;
      unsigned char ones;
      unsigned char debounce;
      TRISA  = ~0x0F;
      TRISB  = ~0x0F;
      PORTB &= ~0x0F;
      PORTA &= ~0x0F;
      debounce = 0;
      while(1)
       hundreds = digit/100;
       digit = digit - (hundreds * 100);
       tens = digit/10;
       //ones
       PORTA=0x01;
       PORTB=ones;
       delay();
       //tens
       PORTA=0x02;
       PORTB=tens;
       delay();
      //hundreds
     PORTA=0x04;
     PORTB=hundreds;
     delay();
     if (debounce>0)
          debounce--;
          delay();
        if(RB4==0 && debounce == 0)  //plus1
        debounce = 255;   //debounce delay
        digit+=1;
        if (digit>250) //highest score is 250.  let digit rollover from 255 to 0
            digit=0x00;
   if(RB5==0 && debounce == 0)  //plus2
        debounce = 255;
        digit+=2;
        if (digit>250)
            digit=0x00;
       if(RB6==0 && debounce == 0)  //plus3
        debounce = 255;
        digit+=3;
        if (digit>250)
            digit=0x00;
   if(RB7==0 && debounce == 0)  //minus1
        debounce = 255;
   if (digit>0)
             digit-=1;
        if (digit<0)
            digit=0x00;
your question appears to be an XY Problem.
why don't you just tell us exactly what you're trying to do?
Offline micromindfs
« Reply #27 on: September 15, 2008, 11:49:08 AM »
sir,ayaw po mag increment nung number...
dhil po ata sa debounce,tinanggal ko debounce,mejo ok pero iba iba number n lumulabas....
huh....pero slamat....nkatulong po sa development...heheheheh....
Offline anthonydp
    • My Empty Blog
« Reply #28 on: September 15, 2008, 12:02:40 PM »
hindi sya mag-iincrement kasi mabagal kapag sini-simulate pa lang.  try the code pero use 2 for the debounce reload value instead of 255.  pero kapag i-flash na sa chip, use a larger value like 255.
i'm glad that it helps.
Offline anthonydp
    • My Empty Blog
« Reply #29 on: September 15, 2008, 12:16:18 PM »
mali pala code code.
change this part:
       tens = digit/10;
to this:
       tens = (digit  - (hundreds * 100))/10;
       ones = digit - (hundreds * 100) - (tens * 10);
sorry for the mistake...
Offline micromindfs
« Reply #30 on: September 15, 2008, 12:20:35 PM »
ok po.wait try ko po uli....hehehehehe.edit ko lng
salamat uli.....huh
Offline micromindfs
« Reply #31 on: September 15, 2008, 12:29:26 PM »
ok n po.....
salamat....
pag sa actual n po ,kelangan nka 255 n ung debounce?
Offline anthonydp
    • My Empty Blog
« Reply #32 on: September 15, 2008, 12:39:08 PM »
yes.  posible kasi na kaya di nag-rerespond yung increment (or decrement) switch ay dahil sa mabagal yung simulation ng delay.  kapag 255 kasi, 255 times nya i-execute yung delay sa:
if (debounce>0)
 debounce--;
 delay();
pero kung 1 lang (or 2)  yung reload value, similar yung delay execution speed sa original code mo.
actually, you can try different reload values depending on how fast the button-response you want.
Offline micromindfs
« Reply #33 on: September 15, 2008, 04:19:38 PM »
ahhhhhhhh....ok po.....
salamat po s info.
« Reply #34 on: September 16, 2008, 06:16:22 PM »
hehe pasensya na sir heheh kasi yung program ko pang 999 points sya... ^_^ saka mikroC nga. pero i guess ok na kasi tama yung binigay ni sir anthonydp, 250 ang max points nya...
BTW, si sir anthonydp yung isa sa mga tumulong sa akin dati sa scoreboard namen last year.. actually 74LS192 gamit namen and isa sya sa nag-introduce sa akin ng MCU doon sa TipidPC website... ^_^
sir anthonydp! thank you! ^_^ ngayon nagpprogram na din ako ng PIC MCU using C and Assembly Language ^_^ and making some projects too.. ^_^
Offline micromindfs
« Reply #35 on: September 21, 2008, 05:16:09 PM »
mga sir,bkit po sa hardware ayaw gumana nung circuit?
kc try ko sya s bread board,sa part po ata nung 7447 ang problema,kc pag open lang pin 8 umiilaw ung 3 seven segment pero pag connect ko n sya sa ground wla n ilaw nung seven segment.huh......
Offline anthonydp
    • My Empty Blog
« Reply #36 on: September 22, 2008, 09:02:18 AM »
post mo schematic.
yung pin 8 ng 7447 ay supply-ground.  kailangan talaga naka-kabit sa ground yun.
yung 7447 ay may ripple-blanking-input (/RBI) at blanking-input (/BI) na kapag naka-low ay mag-logic-high lahat ng output (turned-off lahat ng segment kasi open-collector ang segment outputs ng 7447).
Offline micromindfs
« Reply #37 on: September 23, 2008, 07:38:46 PM »
ok n po sir,npgagna ko n po ung score...huh...
salamat po ng mrami...
ung timer nlng po ginagwaan ko ngaun ng program...huh....
Offline lrs_05
« Reply #38 on: September 23, 2008, 09:49:44 PM »
interesting po ito, gusto ko din sana gumawa nito para sa basketball court sa amin.
pa post naman sir "fherdysheng" yung complete schematics and code pag natapos mo na..thanks
Offline micromindfs
« Reply #39 on: September 25, 2008, 01:01:40 AM »
ok po....
pagtapos n....post ko nlng...
