iniisa isa mo pa kasi buttons ng kada segment. sa standard clock, typically merong isang SET button tapos hiwalay na HOUR at MINUTE button. tapos 'yung alarms mo, pwedeng isang button lang, lilipat lang siya. parang Channel or Volume ng TV.
hmmm bump for this one kasi nakagawa n poh ako ng process flow ito poh:is there any mistake about this?
I dont see process flow. pra pa rin itong block diagram. Process flow should have a start and end/loop kung saan makikita mo flow of program.
^ flowchart lang ng program ang gusto makita ni master nomad13here is the example : -underpazz campaigns for more technical post on technical threads-underpazz campaigns for "no hijack policy" on technical sections
i dont know if this OT but its better now to use GPS module to design clocks as in "relo" kasi medyo mura nalang ang module saka konting prog lang ng PIC ayos na....UTC accurate pa...wag nyo lang akong e pm hindi pa po ako nakatry gumawa nakakita lang po ako ng desenyo napakasimply kasi
paano kung walang signal from GPS
nakagawa po ako noon nyan na walang gamit na MCU. hehe. puro logic gates lang. hehe.
