unsigned char message[90];void display_char_byte(unsigned char ascii_char, unsigned char char_column){ unsigned char char_position; if (ascii_char<0x50) { char_position=(((ascii_char&0xff)-0x20)*5); nokia_write_data(TABLE1[(char_position+char_column)]); } else if (ascii_char>0x4f) { char_position=(((ascii_char&0xff)-0x50)*5); nokia_write_data(TABLE2[(char_position+char_column)]); } else return;}void display_R2L(unsigned char line){ unsigned char a, b, c, d; for(a=0; a<strlen(message) - 14; a++) { for (b=0; b<5; b++) { nokia_gotoxy(0,line-1); for(c=b; c<5; c++) display_char_byte(message[a],c); if(b!=4) nokia_write_data(0x00); for (d=1; d<14; d++) nokia_printchar(message[a+d]); for (c=1; c<=b; c++) display_char_byte(message[a+14],c-1); if(b==4) display_char_byte(message[a+14],4); //delay_ms(50); } } }void init() { setup_adc_ports(NO_ANALOGS); setup_adc(ADC_OFF); setup_spi(FALSE); // output_low(lcd_pwr); //power on LCD delay_ms(200); nokia_init();}void main(){ init(); sprintf(message," www.ElectronicsLab.Ph "); display_R2L(3); // output_high(lcd_pwr); //power off LCD // sleep(); }
Patay ka na naman nito kay Leeya.May free lapdance ka na naman.
o cno ung leeyasir glenjoy hehhee
Si Rafft na lang ang sasayaw
nyahahaha bawal ang "SISTER" sumayaw...sabi ni yus!
