Author Topic: lcd problem  (Read 1629 times)
Offline hockey_rizzo
lcd problem
« on: February 11, 2008, 02:58:23 AM »
hi. tanong lang ano po ba ang usually sira kapag ang lcd monitor ay may manipis na blue vertical line sa bandang kanan ng display? kahit walang video signal may line pa rin nagiging red nga lang. inverter section po ba ang sira or yun mismong lcd na?
thanks
lcd problem
Offline Shey
  • Administrator
  • Pogi/Ganda Points: 154
  • "E tangi ana koe Hine e hine, E hine e Hoki maira"
    • Elab.PH
Re: lcd problem
« Reply #1 on: February 13, 2008, 09:04:53 PM »
usually pag sira ang inverter ang problema mo diyan ay dim ang ilaw mo or totally walang ilaw. Yung inverter kasi, power supply yan nung CCFL ( cold cathode fluorescent lamp ) na backlight.. Kapag may  vertical lines, ang problema diyan ay yung controller or yung lcd mismo..
I wish for this night-time to last for a lifetime
The darkness around me
Shores of a solar sea
Oh how I wish to go down with the sun
Sleeping
Weeping
With you
I walk alone
Every step I take
I walk alone
My winter storm
Holding me awake
It’s never gone
I fear that soon you'll reveal
Your dangerous mind
As your true colours show
A dangerous sign
Re: lcd problem
Re: lcd problem
« Reply #2 on: February 14, 2008, 04:25:03 AM »
thanks admin. so wala na remedyo ito kundi palitan ang lcd. di ko ma-chek yun contact from lcd to circuit board kasi fixed and naka-glue yun ribbon cable connector niya sa lcd. dell e1703fp ang model nito.
anyway thanks uli sir
baka sakali lang kung may solusyon pa.  :D :D :D
Re: lcd problem
Offline Shey
  • Administrator
    • Elab.PH
Re: lcd problem
« Reply #3 on: February 14, 2008, 07:11:05 AM »
possible na contact points ang may problema so it needs to be checked. Kahit iPod nakakapag-experience din ng ganyan. Yung iPod ko may vertical black line sa right side that wouldn't disappear kahit na naka-off yung unit, obviously LCD na talaga ang problema..
Sleeping
Weeping
With you
I walk alone
Every step I take
I walk alone
My winter storm
Holding me awake
It’s never gone
Your dangerous mind
A dangerous sign
Re: lcd problem
Re: lcd problem
« Reply #4 on: February 14, 2008, 05:48:20 PM »
ok thanks for the reply.
Re: lcd problem
