Author Topic: 555 is Not a Timer nor an Oscillator  (Read 7959 times)
Offline underprezzure
  • Pogi/Ganda Points: 44
  • Destroyer! Web Crawler! Buster! Babaylan!
    • www.instructables.com
Re: 555 is Not a Timer nor an Oscillator
« Reply #40 on: September 24, 2008, 07:17:48 AM »
minsan po try ko mgcalculate khit sa 555 timer.. ung resistor at capacitor..  aun, mas ok po tlga ang calculated values.. kesa trial and error...
hehehe.. wow naapreciate mo na ang numbers.. sige tuloy mo lang .. masarap ang lasa ng numbers.. ;)  nga pala 555 timers.. i posted detailed mathematical equations dito sa forum.. ito ang link oh
http://www.electronicslab.ph/forum/index.php?topic=4750.msg82722#msg82722
Tama po si sir nomad13. 555 astable ang kailangan mo since pulsating "low" and "high" configuration ito. Things to remember in astable operation of 555 IC.
1. Do not expect that the Mark time(tm) is always equal to Space time(ts). Ibig sabihin duration ng state "high" is not equal to the duration of the state "low". But there is a way to make it closiest as possible.
          where , Mark time (output high): Tm = 0.7 × (R1 + R2) × C1
                    Space time (output low): Ts  = 0.7 × R2 × C1
2. Period(T) = 0.7 * (R1 + 2R2) * C1
       where R1, resistor from pin7 directed to the Vcc
                R2, resistor connected from pin7 to pin2
                C1, capacitor connected from pin2 to ground
3. Frequency(f) = 1.4 /[(R1+2R2) *C1] with variable definition the same as stated above
4. Period(T) is also = Tm(on_state) + Ts(off_state)
Note: To make the two states almost equal then you have to make R2 >>>>>> R1. Palakihin ang R2 ng todo.
-underpazz campaigns for more technical post on technical threads
-underpazz campaigns for "no hijack policy" on technical sections
Zero tolerance on spam
Stop thread hijack
Offline glutnix_neo
  • Pogi/Ganda Points: 165
    • Underground Workbench
« Reply #41 on: September 24, 2008, 07:34:05 AM »
eto magandang calculator, may freeware version sila
http://www.schematica.com/555_Timer_design/555_Timer_PRO.htm
Just don't expect magagamit mo tong calculator na to sa mga circuits shown below, nyahahahahahaha
Offline Woots29
  • Pogi/Ganda Points: 344
  • asan si mojacko?
    • Woots Page
« Reply #42 on: September 24, 2008, 09:49:39 AM »
hahaha! oo nga ;D ;D
WootsPC2 Videos  Woots Page
Offline macky
  • Pogi/Ganda Points: 51
« Reply #43 on: September 24, 2008, 12:24:20 PM »
saan naman po pwedeng gamitin yang calculator na yan? sa simple circuits like LED blinkers? ;D
sayang pa time pag-calculate kung LED blinker lang ang paggagamitan...heheheh
john 3:16 | oil of gladness
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #44 on: September 24, 2008, 12:45:13 PM »
hindi lng blinkers application nyan. (may LED kc sa simulation) xempre nndun din duty cycle at rise and fall of pulse.
Offline macky
« Reply #45 on: September 24, 2008, 12:58:23 PM »
thanks!  :)
Offline Lenjei
  • Pogi/Ganda Points: 9
« Reply #46 on: September 24, 2008, 03:23:44 PM »
thaks po.. eh un nmn po kasi tlga ang mganda ung may computed value.. ewan ko nga b s mga prof ditu kung bket hindi nila turo un..  :(
« Reply #47 on: September 24, 2008, 03:52:59 PM »
sakim sila ! ayaw nila i-share sa iba.. for sure alam din naman siguro ang basic calculation.. self study na lang.. hehehe  ;)
Stop thread hijack
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #48 on: September 24, 2008, 03:57:36 PM »
wel may narinig akong prof eto sinabi: "if they're interested to learn more, they'll have to self-study and research."
Offline macky
« Reply #49 on: September 24, 2008, 09:15:41 PM »
i agree with that!
experience ko yan nung nag-aaral pa ako ng computer programming, ang daming hindi itinuturo kaya self-study ako, hanap ako ng mga books na national bookstore yun kay Peter Norton books, C, Assembly, etc... kaya mas advance ako nun kesa sa klasmeyts ko! ;D
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #50 on: September 25, 2008, 08:55:09 AM »
hehehe. bos pwedeng pagawa sau ng prog na cocontrolin nya parallel port for free  ;D ;D
Offline Lenjei
« Reply #51 on: September 25, 2008, 08:57:36 AM »
gnun n nga lng po tlga.. at un tlga ang ginagawa nmin ditu.. haay.. kung pwede lng silng plitan .. ginawa n nmin..  :(
« Reply #52 on: September 25, 2008, 08:58:26 AM »
bakit mo pa iaasa sa iba kung available na cya. Marami demo code sa planet source code.
« Reply #53 on: September 25, 2008, 09:09:23 AM »
Tama. iilang lines lang ng codes yan. sending data to the parallel port can be done in exactly one line of code. without counting the default commands for Visual basic.
Stop thread hijack
« Reply #54 on: September 25, 2008, 09:17:06 AM »
HALA OFF TOPIC TAYO NETO:   ;D  ;D  ;D
Contextual in meaning naman kasi yan. Well,  sa university namin default na talaga na maraming alam ang professor pero since culture na rin sa school namin na super basic lang talaga ang ituturo kaya ayon self study and panay research ang ginagawa namin. Pero not all university in our country has this kind of culture that is where i would say na contextual in meaning ang "if they're interested to learn more". To what extent is learning lesser than the "more" that we are thingking off. Pag magtuturo ako ng physics and then ituturo ko lang ang basics ng EM principle tapos magbibigay ako ng exam na combination ng quatum EM with Maxwell equations,, sa tingin niyo enough ba at makatarungan yon? of course, iiyak si fafa niyan dahil nose bleed talaga lahat ng fafa at mama sa exms.. it is good to learn more given that the basics are well defined to each students. but learning more when you do not have anything in your pocket then that is a different story...
Stop thread hijack
  • Pogi/Ganda Points: 412
« Reply #55 on: September 25, 2008, 11:50:33 AM »
ito yung 555 book ko..hehehe..dami rin circuit dito..
Front Cover:
Back Cover:
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
« Reply #56 on: September 25, 2008, 10:18:12 PM »
^ uy ayus yan..
baka naman pwede mo i-post yung mga scanned pages hehe  :D
« Reply #57 on: September 26, 2008, 12:44:05 AM »
^ uy ayus yan..
Check your PM, i have almost the same type of ebook for you. Enjoy!
Stop thread hijack
Offline paranz
« Reply #58 on: September 26, 2008, 06:48:41 AM »
great.. thanx a lot  ;)
Offline Cute_Worm_1983
« Reply #59 on: September 26, 2008, 09:52:40 AM »
pa PM din sis underpazz thanks!
I love electronicslab.ph
