Author Topic: Help NEC tv c-14r5 wala picture wala sound pero may light on  (Read 7967 times)
Offline Mike
« on: February 13, 2008, 02:40:08 PM »
Help naman wala picture wala sound tv nec
Offline Siramiko
  • Pogi/Ganda Points: 35
  • thank you elab
Re: Help NEC tv c-14r5 wala picture wala sound pero may light on
« Reply #1 on: February 13, 2008, 02:45:18 PM »
check mo power supply section, hanggang horizontal section, check mo b+ ng flyback kong may supply 110
I shall return
Offline Mike
« Reply #2 on: February 14, 2008, 01:13:10 PM »
tv ano kadalasan ichecheck na components (parts) o mga suspected diode lang ba?
Offline Siramiko
  • thank you elab
« Reply #3 on: February 14, 2008, 02:19:53 PM »
depende yan sa sira ng tv, halibawa walang tunog ,check mo ang speaker,kung wlang picture check ang heater ng crt  ;)
I shall return
Offline Mike
« Reply #4 on: February 15, 2008, 01:06:24 PM »
 :) what I mean is component sa B+ at flyback
Offline Siramiko
  • thank you elab
« Reply #5 on: February 15, 2008, 02:32:56 PM »
1st check ang transsistor kung may sira, regulator at horinzontal output transistor.
I shall return
Offline Mike
« Reply #6 on: March 15, 2008, 11:45:53 AM »
palagay nyo ano main sira nyan wala video wala sound, kapag december lang siya nasisira kapag malamig ang panahon minsan bumabalik sa normal kapag lumamig uli panahon wala uli video at sound? :o :o
Offline Siramiko
  • thank you elab
« Reply #7 on: March 15, 2008, 11:53:34 AM »
nasubukan mo na bang ,mag play ng movie dyan ?
baka kasi nag mute ang video pag walang signal na masagap .
I shall return
Offline gry43
  • Pogi/Ganda Points: 43
« Reply #8 on: March 15, 2008, 05:13:51 PM »
Seasonal? kung corroded ang crt socket dapat may sound at least..try to look for corroded capacitor muna and cold solder joints
Offline Mike
« Reply #9 on: March 17, 2008, 11:30:56 AM »
Oo seasonal siya may mga sira ako nabasa sa internet ganito rin, @tech  kahit sa tv mode at video wala sound at picture hindi rin siya naka-standby mode base sa picture green na light niya binuksan ko wala light tube nya. kung tube sira atleast may sound sana, pero ito wala sound dati bumabalik kapag mainit panahon. pero kapag malamig december o kaya january ganun uli bumabalik minsan sa normal minsan naman kapag sobra lamig ng panahon kailangan mo muna i-on/off ng several time para maging normal. resolder kona sa mga hot spot pati narin sa iba
Offline Siramiko
  • thank you elab
« Reply #10 on: March 17, 2008, 03:36:01 PM »
seasonal  ;D tingin ko nyan nagiging mamasamasa(moisture) ang board ,o kaya yung mga button   may umido(brown or green ang kulay) sa loob, nahihirapan mag dikit yung mga contact ng micro switch
I shall return
Offline Mike
« Reply #11 on: March 19, 2008, 11:30:10 AM »
parang wala power crt nya
posible solution spray lang ba yung button sa channel/volume ? :)
Offline Siramiko
  • thank you elab
« Reply #12 on: March 19, 2008, 07:01:18 PM »
pwede spray lang, pero hindi mo malilinis ng husto ang loob , ang ginawa pinapalitan o kaya naman binabaklas ko ang micro switch , kung may umido/mamasamasa ang board pwede mong hugasan ng tubig na malinis pero siguradohin matutuyo agad ang board, bilad mo sa araw o kaya gamit ka ng hair dryer , wag mong papa ulanan kasi pwedeng kalawangin ang mga paa ng pysesa  :) , wag mong papaadarin hanga't hindi natutuyo ng husto.
I shall return
Offline snider
  • Hi.
« Reply #13 on: March 22, 2008, 10:12:00 PM »
boss check mo baka my relay yan tapos need pa trigger ng cpu pra mg on ang power supply ;D
Offline Mike
« Reply #14 on: March 26, 2008, 11:11:38 AM »
Hi
Test ko Flyback,
. pin 1 "H-out" = sa palagay ko yung ang B+ dahil siya ang nakaconnect sa gitnang pin ng HOT.
  ang reading nya ay mababa 94.5v tapos yung
. pin 2 "115v" ang reading nya ay mababa rin 92.3v
. test ko rin malaki capcitor base sa post mo techno08, practical tv repair at hinde naman shorted.
. pati RL test ko rin kung madumi na pin nya
. mga button switch main at lahat ng button pinalitan ko dahil may iba button na madumi na at wala na reading
Originally 100v ang input power nya japan tv meron lang siya tranformer na 220v input 100v output,
Yung mababa reading sa flyback posible kaya na yung dahilan kaya wala ilaw tube at wala sound?
Ano iba pa dahilan kaya ganun ang reading?
check kona mga diode around flyback gunon rin sa iba pa diode. visually wala ako makita capacitor na sira.
yung  RELAY nakiclick kasabay ng light on, pero wala siya sound at picture.
salamat
yung ba dahilan kaya hindi umiilaw tube,kulay power supply nya o else. ano sira nyan madalas?
Offline Siramiko
  • thank you elab
« Reply #15 on: March 26, 2008, 11:23:51 AM »
hindi gumgana ang horizontal oscillator ng tv mo, kaya walang heater(walang ilaw ang puwet ng picture tube)
I shall return
Offline jhamir
« Reply #16 on: March 26, 2008, 06:44:47 PM »
check mo bro kung my supply ang hdt at hdt driver... kung wla  hindi nga mag ooscilate yan...
dampulay na.......
Offline Mike
« Reply #17 on: March 27, 2008, 11:33:24 AM »
hdt driver ,horizontal oscillator   mahina ako sa term., ano yan :D
Offline Mike
« Reply #18 on: March 28, 2008, 12:35:16 PM »
HDT -stand for horizontal driver transistor ba?
Offline Mike
« Reply #19 on: March 28, 2008, 12:39:36 PM »
hdt driver ,horizontal oscillator kung yan ang sira kasa na ba sound noon na maayos? kasi wala rin sound
