you can use rf module from alexan. Or you can use bluetooth if you have the budget.
halo po, ano po yang rf module from alexan? sino yan si alexan? can u give me also a biasing of stepper motor? please.
First you have to learn Visual Basic programming then once ok na.. you need to learn PC Interfacing using the serial port of the PC or Parallel Port.. sa serial port interfacing add mo lang yung MSCOMM.OCX sa Visual Basic.. ( check google for VB programming tuturials )yung RF module or Radio Telemetry Module.. bale dalawang gadget yan, yung isa connected sa PC mo via serial or parallel port, the other one is connected to your room divider..http://philippines.rs-online.com/web/search/searchBrowseAction.html?method=retrieveTfg&Ne=4294960157&N=4294857413
hello, i forgot to ask how to bias a stepper motor. paano po kaya? any people there can help me? ty n advns..
may sequence how to run a stepper motor but it differs kung anu gagamitin either bi-polar or unipolar.
maraming magandang articles sa net about sa pag-control ng stepper motors.. diko makita yung mga nabasa ko eh.. hanapin ko lang..
hi po, pagpasensyaan mo talaga, wala kasi akong idea nitong bi-polar at uni-polar na stepper motor. For you po, ano ang best? Bagohan lang talaga ako sa ganito eh.. please help... Tnx
Mas maganda pa puntahan mo ang site na itohttp://en.wikipedia.org/wiki/Stepper_motor
salamat po sa link... ano kaya dapat? unipolar, o bipolar na stepper motor?
1. for more precise angle movement then use unipolar stepper2. if you want more torque then use bipolar stepper. -underpazz campaigns for more technical post on technical threads-underpazz campaigns for "no hijack policy" on technical sections
pwede na ordinary motor sa application mo.
