Author Topic: PIC Programmer  (Read 53985 times)
Offline cspcboy
PIC Programmer
« on: January 18, 2008, 05:45:31 PM »
ano ang magandang pic programmer? yung david tait or yung serial?
PIC Programmer
Offline Shey
  • Administrator
  • Pogi/Ganda Points: 154
    • Elab.PH
Re: PIC Programmer
« Reply #1 on: January 18, 2008, 07:48:47 PM »
Yung classic pic programmer ni david tait is parallel port based. Mas maganda ang parallel port based na pic programmer kasi most of the time gumagamit yan ng buffer gaya ng 7407 or 7406. Meron kang margin of safety pag parallel port ginamit mo.
Ang serial port naman low cost yan. Karamihan sa nakikita kong serial port pic programmer eh non-isolated so ibig sabihin pag nagkaroon ng short circuit sa programmer mo, patay ang driver ng RS-232 port ng PC mo.
The darkness around me
Shores of a solar sea
Sleeping
Weeping
With you
I walk alone
Every step I take
I walk alone
My winter storm
Holding me awake
It’s never gone
Your dangerous mind
As your true colours show
A dangerous sign
Re: PIC Programmer
Re: PIC Programmer
« Reply #2 on: January 18, 2008, 11:25:11 PM »
eto nga may nakita pa akong bagong version ng parallel PIC programmer... galing sa microEngineering Lab, Inc (www.melabs.com). Tinatawag nilang EPIC Plus pocket PIC micro Programmer.
http://rapidshare.com/files/84778912/epic_schematic.pdf
bisitahin nyo na din yung site nila...
http://www.melabs.com/products/epic.htm
Re: PIC Programmer
Offline Shey
  • Administrator
    • Elab.PH
Re: PIC Programmer
« Reply #3 on: January 19, 2008, 12:26:40 AM »
so they did finally update their programmer na pala muhahahaha..
Sleeping
Weeping
With you
I walk alone
Every step I take
I walk alone
My winter storm
Holding me awake
It’s never gone
Your dangerous mind
A dangerous sign
Re: PIC Programmer
Re: PIC Programmer
« Reply #4 on: January 19, 2008, 06:51:22 PM »
Inchworm ICD2 ang gamit ko. compatible sa MPLAB at automatic ang firmware upgrade ng MPLAB IDE. available ang schematics nyan sa net.
Sa bahay ang gamit ko is JDM at Warp Programmer.
Re: PIC Programmer
Offline Shey
  • Administrator
    • Elab.PH
Re: PIC Programmer
« Reply #5 on: January 20, 2008, 02:09:03 PM »
eto yung parallel PIC programmer ko  ;D
Sleeping
Weeping
With you
I walk alone
Every step I take
I walk alone
My winter storm
Holding me awake
It’s never gone
Your dangerous mind
A dangerous sign
Re: PIC Programmer
« Reply #6 on: January 20, 2008, 08:40:33 PM »
eto naman sakin... yan yung galing sa oshonsoft. ok naman...
kaso ngalang, di ko na inextend para sa 18pins lalagyan ko nalang ng DIP switch para isang ZIP socket lang ang gagamitin ko...:)
Offline Positron
Re: PIC Programmer
« Reply #7 on: January 28, 2008, 03:01:39 PM »
mine is USB pgrogrammer. gawa ko lang na nakita ko sa net. minodify ko lang sya kc sa original kelangan ng ic for usb ro rs232. so what i did is binili ako ng usb to rs232 converter kasi yung laptop ko walang parallel port at serial port. im using diypgmrs na programmer. K182 ata sa commercial ito nsa $100 sya.
kya kahit na sa desktop ok sya gamitin kc usb to rs232 lang or pwede din rs232 ang gamitin alisin mo yung usb to rs232 converter. so very versatile sya and to top it all it can program from 12,14,16 and 18 pic family.
note:
unang gamit ko nga pla david tait kya naiprogram ko yung f628A. kelangan nga pla program ang f628A nito. kya gawa muna kyo ng pang parallel to program first the firmware of 628A.
Offline 'yus
  • Pogi/Ganda Points: 299
  • hw -> fw -> sw
    • yus' projects
Re: PIC Programmer
« Reply #8 on: February 08, 2008, 06:48:44 PM »
sa PicMicro, anong pinagkaiba, in terms of performance and electrical characteristics, ng mga pic na meron "C" sa part# saka ng mga pic na meron "F"???
gamit ko kasi JDM based na programmer (with ICProg).. gumagana sya sa PIC16F73
pero sa PIC12C671 nag-eerror!  :(
may mali kaya hardware ko?  ???
pic12c671 pa naman sana gusto kong gamitin kasi meron syan ADC pero 8-pin lang and hindi messy paggagawa ng circuit..
Offline Ganda692002
  • Pogi/Ganda Points: 13
Re: PIC Programmer
« Reply #9 on: February 08, 2008, 07:21:20 PM »
Di kaya OTP yan at may program ng laman kaya nageerror..
Offline subzer0
  • Pogi/Ganda Points: 38
  • Garbage In Garbage Out.
Re: PIC Programmer
« Reply #10 on: February 09, 2008, 11:58:20 AM »
mga sir,may link ba kau ng ICD2,para sa MPLAB na lang ako mada downlaod ng program?thanks po:-)
Signing Off...
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
Re: PIC Programmer
« Reply #11 on: February 09, 2008, 11:59:04 AM »
meron akong nahanap na possible solution..
http://users.tpg.com.au/btkelly/jdm_b.htm
sana gumana ito..  ;D
Offline clarkent
  • Pogi/Ganda Points: 20
  • iehs
Re: PIC Programmer
« Reply #12 on: February 11, 2008, 03:12:16 PM »
pwede din ba jan ang 16f84?
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
Re: PIC Programmer
« Reply #13 on: February 11, 2008, 06:35:27 PM »
Offline ferds
  • Pogi/Ganda Points: 22
    • my projects
Re: PIC Programmer
« Reply #14 on: February 11, 2008, 08:01:26 PM »
heto gamit ko.. Multi PIC Programmer 5 Ver.2 based on the JDM programmer.
http://feng3.cool.ne.jp/en/pg5v2.html
x--------> www.FerdsAudio.com <---------x
Re: PIC Programmer
« Reply #15 on: February 12, 2008, 08:54:16 AM »
pwede
kamusta naman po yung programmer?
Offline paranz
Re: PIC Programmer
« Reply #16 on: February 12, 2008, 09:25:41 AM »
i havent used the JDM pic programmer, im using the P16PRO only.
Later gagawa ako nyan para makaprogram ng serial eeprom  :)
Re: PIC Programmer
« Reply #17 on: February 12, 2008, 12:45:04 PM »
nakagawa na ako ng p16pro... ok na ok. kaso nga lang di supported yung ibang PICs lalo na yung mga 18F series...
supported ba nyang JDM ang 18F series?
Offline tuldok89
Re: PIC Programmer
« Reply #18 on: February 12, 2008, 02:14:49 PM »
Yung PIC na merong "C" sa Part Number ay OTP o one-time programmable... Yung may "F" naman ay Flash Based, meaning reprogrammable...
Offline ferds
    • my projects
Re: PIC Programmer
« Reply #19 on: February 12, 2008, 02:33:04 PM »
Oo supported nya.. :)
Re: PIC Programmer
