Author Topic: hard disk drive vs. solid state drive  (Read 2435 times)
Offline lightelectro
  • Pogi/Ganda Points: 51
    • Android Tablet Lover
« on: October 01, 2008, 09:52:08 PM »
anong mas gusto nyo? 8)
LATEST ANDROID TABLET NEWS
Re: hard disk drive vs. solid state drive
« Reply #1 on: October 01, 2008, 09:53:06 PM »
SSD ;D
« Reply #2 on: October 01, 2008, 10:08:21 PM »
explain your answers please. 8)
  • Pogi/Ganda Points: 630
« Reply #3 on: October 01, 2008, 10:12:26 PM »
SSD dahil walang moving parts at tahimik.
Magnetic dahil malaki ang capacity. kasya ang pagkadami-daming JAV. ;D
« Reply #4 on: October 01, 2008, 10:17:23 PM »
JAV JAV JAV ;D ;D ;D ;D
Offline ef - el - ay - pee
  • Pogi/Ganda Points: 34
  • Regrets, I have a few...
    • The Taste Bytes Food Blog
« Reply #5 on: October 01, 2008, 10:40:04 PM »
SSD kasi mumura pa xa..yey!
« Reply #6 on: October 03, 2008, 12:09:14 PM »
both depending on uses. SSD portable at compact. HDD malaki capacity
Offline wakanga
« Reply #7 on: October 03, 2008, 08:35:35 PM »
depends on your preferences...but still for reliability and durability i'd go for SSD... :)
« Reply #8 on: October 06, 2008, 08:46:12 PM »
meron din ba write limit ang ssd kagaya nang flash drive? 8)
« Reply #9 on: October 06, 2008, 08:51:59 PM »
'yup meron din. pero improved ang limit nila at mas maganda ang algorithms niya para hindi laging nasusulatan 'yung isang area lang.
« Reply #10 on: October 06, 2008, 08:59:22 PM »
siguradong mag iimprove pa ang technology na yan. magiging mas magaan na ang mga pc and laptops. 8)
« Reply #11 on: October 06, 2008, 09:07:43 PM »
'yup. AFAIK, next year magre-release ang HP ng first product using Memristors. ang sabi nila it will drastically change the memory scene.
« Reply #12 on: October 06, 2008, 09:40:27 PM »
ayus pala itong memristirs ayun sa nabasa ko.
http://blog.wired.com/gadgets/2008/04/scientists-prov.html
8)
Offline 9 Volts
  • Pogi/Ganda Points: 7
  • Moving Target
« Reply #13 on: March 20, 2010, 03:29:51 PM »
mga Masters..Maam/Sir..
5 years na po sken yung pc ko & na upgrade ko na rin yung RAM..
May problema naman po ako sa Hard Drive kc maliit.. IDE HD.. Maxtor.. 89 GB lang po xa..
Gusto ko mag install ng bagong hard drive.. gagawin ko slave yung luma.. pa help po eto questions:
1. May nabibili po SATA HD.. compatible po sa yung sa PC ko na IDE HD yung gamit na HD.. may wire connection compatibility po ba yun sa Motherboard ko..
    iba po kc yung wire eh
2. Napaka bagal po ng data transfer ng computer ko. kahit 1.24 GB na po.. sa Maliit na Hard Disk po ba yun.. d ko pa po na check yung RPM nya.. pero 89GB  yung estimated capacity nya..
3. MAXTOR (IDE) po yung gamit ko na HD.. kung bibili po ako ng MAXTOR SATA or other kind of hard disk na available po ngaun.. pwede po ba yun or may   compatibility po?
4. naiinis na kc ko sa kaka transfer transfer ng mga files sa USB at ibang computer pag nacocorrupt yung PC ko eh.. dahil maliit yung memory.. kahit mag 2 partition ka di kakayanin  nung isang drive yung laman nung isa.. bad3p.. huhuhu
5. If ever naka buy na po ako ng hard drive nailagay ko na.. direcho format ko na po ba ng windows xp cd to format?
pa help po mga masters..
Thanks po!♥
If we hear, we forget; if we see, we remember; if we do, we understand. -- Proverb
« Reply #14 on: March 20, 2010, 06:33:18 PM »
i vote for solid state drive. for office installation, gamit ko is
intel atom, ssd, and lcd screens.
very robust / FAST (crazy fast VERY VERY useful for database queries), low power...
with almost... no seek time.  ;D ;D ;D
konting konti pa lang gumagamit nang SSD for server installation. but if you want to
start a data servers. rely on SSD.  ;D
but capacity wise. Platter based hd's reign supreme... FOR NOW.
this is also good for file servers.
TRUST ME IT'S A GOOD INVESTMENT TO HAVE A SSD, if you want your data SAVED.
as rd said walang moving parts.
Offline jenrei06
« Reply #15 on: April 28, 2012, 06:35:08 PM »
maganda po SSD lalo na kung gagamitin mo lang sya pang boot ang bilis ..
then naka slave ka ng nasa 2TB ganda gamitin ..
pero sa ngaun dipa kaya Price 60GB SSD Gskill nasa 8k pa...
