Author Topic: .NET (C#,VB.NET,etc...) Programming Thread: Q&A, Tips and Tricks  (Read 17512 times)
Re: .NET (C#,VB.NET,etc...) Programming Thread: Q&A, Tips and Tricks
« Reply #20 on: October 27, 2008, 06:32:34 PM »
magandang book sa C# is Teach Yourself C# in 24 Hours.... pang beginner ang approach... then ang reference na gamit ko is yung kay Herbert Schild na C# Complete Reference and Deitel's C# How to Program... :) :) :)
Offline 'yus
  • Pogi/Ganda Points: 299
  • hw -> fw -> sw
    • yus' projects
« Reply #21 on: October 27, 2008, 06:38:42 PM »
'di ko natapos yang "teach yourself c# in 24hrs"..
di nga ako umabot sa kalahati eh.. hehe  :D (tamad talagang magbasa!)
pero ganun pa man, marami pa rin akong natutunang important basics dyan sa e-book na yan..  ;D
« Reply #22 on: October 27, 2008, 06:42:43 PM »
kahit ako marami ring natutunan na basics jan hehehe... pati database jan ko unang naexperience at MDI programming... may bago ng labas nyan yung 2008version. nadownload ko na pero di ko pa nababasa heheheh.... busy pa sa ibang C# ebooks ;D ;D ;D
Offline salamat
« Reply #23 on: October 27, 2008, 07:45:20 PM »
pwd po enge ng copy nung C# in 24hrs???  :-[
"Anyone who has never made a mistake has never tried anything new." -Einstein
« Reply #24 on: October 29, 2008, 10:29:43 PM »
^^check mo sa mga ebook site dito sa elab...
Let me share some that I learned:
1. Plan first before you code... Plan everything on how to make the software easy to use, maintainable and flexible. Reading design patterns book will help a lot sa pag-attack sa mga object-oriented software design problems/hurdles ...
2. "A great software is easy to use,flexible and maintainable" - From the Book Head First OOA&D
Natutunan ko na malaking tulong ang interface at abstract class for a very flexible and well-maintained software... I learned na very crucial etong dalawa in writing maintainable and flexible software... Too bad, nasasanay na ako masyado sa OOP at hinahanap ko ito ngayon sa C ;D ;D ;D
How to see if your code is easy to maintain and flexible? try to change it... kung heavy ang modification, it is not easy to maintain and flexible...  kaya...
3. Don't be afraid to modify bad software design... (learned from HeadFirst OOA&D)
share din po kayo :)
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #25 on: November 09, 2008, 09:57:05 PM »
sa C# serial port interface, ano ba ang maximum na baud rate? ???
  (sa pic micro ano naman ang maximum baud rate? )
« Reply #26 on: November 09, 2008, 10:01:28 PM »
sa C# 115200 ang pinakamataas na gamit ko.
sa PIC micro naman depende sa crystal mo,computation sa SPBRG at consideration sa percentage error ng computation.
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #27 on: November 09, 2008, 10:05:13 PM »
na-try ko na kanina yang 115200 sa C#..
hanggang ilang lang ba ang (suggested) pwedeng percentage error ? ???
« Reply #28 on: November 09, 2008, 10:09:12 PM »
kung tama ang pagkakatanda ko within +/-2%... gamit ka na lang ng mga crystals na commonly ginagamit sa UART like 11.0592MHz kasi 0% ang computed percentage error nito...
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #29 on: November 09, 2008, 10:17:15 PM »
pwede ba ang non-standard baud rate? ???
« Reply #30 on: November 09, 2008, 10:19:52 PM »
sa C# ba? di ko pa nasusubukan yan pero malamang hinde pwede...
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #31 on: November 09, 2008, 10:29:13 PM »
^ C#
mukhang di nga pwede..
(pero pag PIC pwede di ba?)
wala akong "mapupulot" na ganyan..  :( hehe  :D
« Reply #32 on: November 09, 2008, 10:32:09 PM »
bili ka na lang sa e-gizmo hehe ;D ;D ;D
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #33 on: November 16, 2008, 06:53:10 PM »
pa'no ba mag-read ng data sa serial port? ???
  magrunong na akong mag-send, pero di naman marunong mag-receive.. hehe  :D
gumagana naman yung event handler:
private void serialPort1_DataReceived(object sender, SerialDataReceivedEventArgs e)
      //ipi-print ko sana sa rich tecx box yung na-receive na data
pero di ko makuha kung pa'no ma-save yung na-receive na data..  :'(
« Reply #34 on: November 16, 2008, 07:09:02 PM »
hehehehe.... sending ang pinakamadaling routine sa serial heheh ;D ;D ;D
ganito na lang gawin mo
gawa ka ng stringbuilder instance sa class level
StringBuilder hehe=new StringBuilder();
tapos eto sa loob ng event ng serialport
hehe.Append(Char.ConvertFromUtf32(myser.ReadChar()));
Textbox1.text=hehe.ToString();
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #35 on: November 16, 2008, 07:23:53 PM »
ngek.. bat may error after mag-send ako ng "string" papunta sa pc? ???
« Reply #36 on: November 16, 2008, 07:42:29 PM »
hhmmm cross thread operation not valid..
ok create ka ng delegate sa class level
protected delegate void UpdateDisplay(StringBuilder text);
then gawa ka ng another function para mag update ng textbox mo:
        private void DisplayText(StringBuilder text)
        textBox1.Text=text.ToString();
then sa loob ng serialport event
        private void serialPort1_DataReceived(object sender, System.IO.Ports.SerialDataReceivedEventArgs e)
            hehe.Append(Char.ConvertFromUtf32(serialPort1.ReadChar()));
            Invoke(new UpdateDisplay(DisplayText),new object[]{hehe});
it should now work fine :)
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #37 on: November 16, 2008, 08:01:46 PM »
^ wala ng error.. pero wala ding naidi-display.. :D
nagiging 'blank' lang yung text box..
« Reply #38 on: November 16, 2008, 08:03:11 PM »
ngek hehe ;D ;D ;D sinimulate ko dito ok naman :) :) :) check mo yung laman ng Stringbuilder object mo (debug) :) :) :)
« Reply #39 on: November 17, 2008, 06:00:56 AM »
mommy san pwede makakuha nito? tiningnan ko sa dating mga pinagkukunan naten pero wala eh ^_^
BTW,,
C#
anyone could give me tips, tricks and ideas on how to create my own Windows Task Manager without using the taskmgr process...thank you ^_^ gagamitin ko lang sya for my little app ^_^
TIA
