Author Topic: .NET (C#,VB.NET,etc...) Programming Thread: Q&A, Tips and Tricks  (Read 17502 times)
Re: .NET (C#,VB.NET,etc...) Programming Thread: Q&A, Tips and Tricks
« Reply #40 on: November 17, 2008, 05:48:29 PM »
mommy san pwede makakuha nito? tiningnan ko sa dating mga pinagkukunan naten pero wala eh ^_^
nakuha ko sa torrent hehe ;D
« Reply #41 on: November 18, 2008, 12:46:51 PM »
heheh nakuha ko na yung isa.. ^_^
yung pandalawa eh broken link raw..
but anyway nagawa ko na yung process manager ko (task manager)
ang prob ko na lang dun kung paano ko pagsasamahin yung string ng username at memory usage nya...
^_^
« Reply #42 on: November 18, 2008, 11:13:05 PM »
sister gigz,
performancecounter control ang ginamit mo?
« Reply #43 on: November 19, 2008, 03:21:34 AM »
sister gigz,
System.Diagnostics lang po mommy at array.GetProcesses
^_^
wala pang time para makapag-isip para dun sa gusto kong lagyan ng username at memory usage.. ^_^
yung confirmation window ok na ^_^ saka yung SelectedIndex = 0 ^^)
« Reply #44 on: November 19, 2008, 04:34:20 AM »
ganito gusto kong mangyari mommy
yung username at memory usage eh filled up ng data.. sinubukan ko na yung multicolumn ang prob eh nagiging horizontal yung pag-adjust ng window.. tried ko na rin yung AddRange.. eh parang balewala.. tsk tsk tsk... paano kaya ito ^_^ heheh next week ko ulet magagawa.. =)
« Reply #45 on: November 20, 2008, 08:40:48 PM »
anyone of you knows about hijackthis application?
yun ang target application ko na gagawin ngayon after maperfect yung process killer ko ^_^ heheh sana magsuccess ^_^
more tools ng kaizer killer to go ^^,
Offline daprogrammer
« Reply #46 on: November 22, 2008, 03:30:50 PM »
regarding sa multi-column ma'am better use a datagrid, iba kasi ang implementation nang multicolumn sa listbox, hindi cya as multidimensional array, minu-multicolum lang niya ang items nang list box. regarding naman sa user name at memory usage, ma'achive mo yan using windows API (unamaged code) i-pass mo lang ang makukuhang windows handler mo sa nagawa mong routine. May ginawa din ako nito before in C# but I designed it to track my own applications only.
BTW: Pwede mo rin isali ang FileSystem object wherein ma view nang user ang mga hidden and suspicious files.
« Reply #47 on: November 22, 2008, 03:39:22 PM »
this is what i really planned for.. about the data grid.. pinag-iisipan ko na yan.. kasi sa tingin ko hopeless na talaga ^_^
« Reply #48 on: February 18, 2009, 09:44:27 PM »
may gumagamit na ba ng WPF dito? mukhang ok siya yun nga lang parang ang hirap gamitin sa simula...
Offline ajak
  • Pogi/Ganda Points: 50
« Reply #49 on: February 18, 2009, 11:32:13 PM »
ako sister nakapagtry ng konti dyan, ang galing nung isang tutorial, pede gumawa ng parang mspaint... ung inkcanvas...
Offline krnadik
« Reply #50 on: February 20, 2009, 10:04:27 AM »
question lang po...
ano po ba ang difference kung dineclare mo ang isang variable na 'string' compared sa 'public static string'?
Offline jhalot
  • jack the pumpkin king.
    • Evil Impz
« Reply #51 on: February 20, 2009, 03:00:27 PM »
ang galing nyo naman kailan pa kaya ako aabot jan... try ko na talagang mgaral ng C#....
ask ako dito nxtym through my practice sa C#...
still downloading pa ngaun... with the tutorials... hehehe...
mukhang exciting ang C# ah...
I am nobody, nobody's perfect, therefore Im Perftect.
« Reply #52 on: February 20, 2009, 03:36:34 PM »
question lang po...
I presume class level variable declaration ang tanong mo...pag naka public static string ka, di mo na kelangan ng instance para i access ang Variable na yun..
ex #1:
    class Program
        static void Main(string[] args)
        MyClass.Test="hello";
        Console.WriteLine(MyClass.Test);
    class MyClass
        public static string Test;
pag string naman, implicitly private siya...
ex#2
    class MyClass
        string Test; // equivalent to private string Test;
pero kung lalagyan mo ng public sa unahan, maaaccess mo siya pero kelangan mong gumawa ng instance ng class...
anyway, di recommended na ginagawang public ang variable dahil pwede itong makasira ng encapsulation ng class mo dahil less ang restriction.. good practice is to use C#'s properties (get set)...
Offline jhalot
    • Evil Impz
« Reply #53 on: February 20, 2009, 03:44:57 PM »
ok lang bah gamitin ang visual c# na express? o masmaganda yung original talaga?
rookie pa kac ako... cgro tong express lng muna... ito lang din ang available ko dito.. hehehe..
pero kung may link kayo saan mka DL ng C# pede henge?
thank you very strong.
« Reply #54 on: February 20, 2009, 03:54:21 PM »
Visual Studio 2008 Express Edition din ang gamit ko kahit meron akong licensed copy ng Visual Studio...
all of my projects are created in Visual Studio Express 2008 Express Edition. So far, wala pa akong nakikitang limitation ng Express Edition...
Offline jhalot
    • Evil Impz
« Reply #55 on: February 20, 2009, 04:00:10 PM »
ahhh ok... salamat po...
so tama pala ang ginawa ko... di pa natapos ang installation ko... hehehe tagal pala ng installation nito..
thank you very strong...
« Reply #56 on: February 20, 2009, 04:02:31 PM »
yes matagal talaga yan hehe.. good luck sa pag-aaral! :) :)
Offline jhalot
    • Evil Impz
« Reply #57 on: February 20, 2009, 04:18:12 PM »
may tanong ako bout C#? so pede tong gamitin din in databasing?tama ba word ko...
kagaya ng VB connected with MS Access.. ang C# ano sa kanya?
salamat.
« Reply #58 on: February 20, 2009, 04:27:53 PM »
salamat.
yes pwede kumonekta ang C# sa MS Access.. + meron siyang database explorer..
Offline jhalot
    • Evil Impz
« Reply #59 on: February 21, 2009, 07:32:07 AM »
ang prob ko kahit sa VB di ko alam mgconnect with MS Access.. hehehe...
madali lng bah sa C# mglink sa Access? paturo ako next time pgnagstart na akong magaral ha? salamat.
ano yang database explorer ??
