Author Topic: tinamaan yata nang virus  (Read 2416 times)
Offline lightelectro
  • Pogi/Ganda Points: 51
    • Android Tablet Lover
« on: November 04, 2008, 10:36:45 PM »
ang computer ko ay wala nang "folder options" at "task manager" dahil hindi daw ako administrator.
Administrator naman ako. updated naman ang avast ko. nakalusot siguro sa avast. ???  8)
LATEST ANDROID TABLET NEWS
Offline rurikdgreat
  • Pogi/Ganda Points: 11
Re: tinamaan yata nang virus
« Reply #1 on: November 04, 2008, 10:43:25 PM »
virus nga yan. try mo mag system restore.
Life's too short...... call CQ!
A HAM will always be a HAM.
Offline johnpats
  • Pogi/Ganda Points: 7
« Reply #2 on: November 04, 2008, 11:08:49 PM »
hmm tingin ko d ako makatingin,, joke joke  :) :) :)
user din ako ng avast unitl right now, cguro advice ko lng babaan mo ung security level exemption ng avast mo, im sure bina block nya ung other access ng program u bcoz experience ko sa avast is super tight ung security level nya....
\\\"wag mong isipin ang sahod mo, dahil pag nag-e-enjoy ka sa ginagawa mo, darating at darating ang pera sayo..\\\"
« Reply #3 on: November 04, 2008, 11:16:58 PM »
may nakita ako na solution sa net na dadaan ka sa regedit para bumalik ang folder options at task manager. pero ang regedit din ay na disable nang virus. nakakainis na virus ito. 8)
Offline inbuenokudos
« Reply #4 on: November 04, 2008, 11:18:34 PM »
e2 try mo to..
1. Open Notepad
2. Copy the code below:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
"NoFolderOptions"=dword:0000000
[HKEY_CURRENT_USER\Software\Policies\Microsoft\Internet Explorer\Restrictions]
"NoBrowserOptions"=dword:00000000
3. Paste mo sa notepad then save mo as FolderOptions.reg
4. Kailangang .REG and extension ng filename.
5. Close mo notepad then double click the FolderOptions.REG File.
e2 ung remedy pg na disable o dm makita ung 'Folder Options' under sa 'Tools'...enjoi..
hope it helps..
¡ɥnɥ uʍop ǝpıs dn pɐǝɹ
..ɥd.dɐ1sɔıuoɹʇɔǝ1ǝ..sopnʞouǝnquı
« Reply #5 on: November 04, 2008, 11:21:56 PM »
dmn kelangan mg run ng regedit.just open notepad then follow the procedures.pg dm makita ung notepad mo, just
1. click 'Start'
2. click 'Run'
3. then type 'Notepad' in the address bar
« Reply #6 on: November 04, 2008, 11:26:32 PM »
how about the regedit? paano rin i enable? 8)
« Reply #7 on: November 04, 2008, 11:30:36 PM »
paano ba gamitin ang vrdb? sabi kasi pag may virus attack ay pwede mo syang gamitin para mag restore. paano ito gamitin sa pag restore? 8)
Offline ajak
  • Pogi/Ganda Points: 50
« Reply #8 on: November 05, 2008, 01:00:12 AM »
Offline graSS
  • "High"
« Reply #9 on: November 05, 2008, 07:18:36 AM »
try mo autorun eater may option dun ng FIX REGEDIT & FIX TASKMANAGER... kng d pa rin magawa download ka ng TUNE-UP UTILITIES may short cut dun pra sa TASK MANAGER or try this one :
REG add HCKU\Software\Microsoft\Windows\CurrentVersion\Policies\System /v DisableRegistryTools /t REG_DWORD /d O /f
punta ka sa run command tapos paste mo yan then hit OK.... pagkatapos try REGEDIT kng makakapasok na  ;D  ;D  ;D
« Reply #10 on: November 05, 2008, 10:14:47 AM »
thanks try ko ngayon. 8)
Offline Vhangell
« Reply #11 on: June 01, 2009, 09:49:48 AM »
try to run drweb's cureit to remove the virus
http://freedrweb.com
run it in safe mode...
Offline cirkitbored!
  • Pogi/Ganda Points: 21
  • Somebody’s boring me — I think it’s me.
« Reply #12 on: June 01, 2009, 09:03:17 PM »
the syntax above bale HKCU po hindi HCKU...
pwede rin po ito
REG delete HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System /va /f
deletes the specified key altogether... we dont actually need any setting under the POLICIES\SYSTEM key
ini exploit lang ito ng mga virus writers to restrict certain features para di matanggal ang virus
but... even if you are successful to delete the key and the virus is still there, chances are gagawan nya na naman ng settings ito, so parang wala din
solution... punta ako sayo sis, then meryenda.. ayosin ko... ;D ;D ;D
Ang hindi lumilingon sa pinanggalingan, mabilis makakarating sa paroroonan. :D
Ang taong mahilig mag-aral sa gabi, kinabukasan ay puyat. :D
Kung kaya ng iba, bakit tutulong ka pa!?! :D :D
« Reply #13 on: June 01, 2009, 09:27:35 PM »
hello, ok napo pala ang pc ko. matagal ko nang ni reinstall nang os. by the way na solve ko sya na pero marami nang damage sa pc kaya reinstall ko na. 8)
Offline /
  • Pogi/Ganda Points: 317
« Reply #14 on: June 28, 2009, 10:51:59 PM »
hehehe natakot mag pa meryenda.
« Reply #15 on: June 29, 2009, 09:09:30 AM »
^ hehe. 8)
Offline Woots29
  • Pogi/Ganda Points: 344
  • asan si mojacko?
    • Woots Page
« Reply #16 on: June 30, 2009, 04:48:51 PM »
maganda ung autoruneater
may fix taskmanager , registry at folder options na dun
WootsPC2 Videos  Woots Page
Offline luciferlove
« Reply #17 on: July 06, 2009, 10:18:24 AM »
hilig kasi ng mga tao gumamit ng windows as admin users kaya ganyan.  only use admin for maintenance purposes or installing necessary programs.  At sa mga mahilig sa mag disable ng UAC sa vista, ganyan din ang problema kapag na-virus.  Disable niyo pati mga autorun sa removable storage access.
Offline snider
  • Pogi/Ganda Points: 25
  • Hi.
« Reply #18 on: July 06, 2009, 11:21:08 AM »
gamit po kayo ng tuneup utilities kahit na disable ang registry minsan sa tuneup ok sya.
pra nmn sa folder option easyway para anable ulit
start menu>run type regsvr32 /i shell32.dll  enter
presto ok na ulit folder option tested kona po.
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #19 on: July 06, 2009, 12:46:04 PM »
^wow try ko nga
