Woofer is the term commonly used for a loudspeaker driver designed to produce low frequency sounds, typically from around 40 hertz up to about a kilohertz or higher.
subwoofer is a woofer, or a complete loudspeaker dedicated to the reproduction of bass audio frequencies, from perhaps 150 Hz down as far as 20 Hz, or in rare cases lower. Also known as "subs", these are used to augment the low frequency performance of main loudspeakers.
Instrumental Speaker : ?
