Author Topic: can the servo motor can operate a roll-up roll-down billboard??  (Read 1065 times)
Offline arkiose99
« on: November 11, 2008, 01:15:30 PM »
kasi thesis namin ay roll-up roll-down na billboard.......
possible ba xa na servo motor ang gagamitin namin??
Offline underprezzure
  • Destroyer! Web Crawler! Buster! Babaylan!
    • www.instructables.com
Re: help me...
« Reply #1 on: November 11, 2008, 01:20:52 PM »
Do not post heavy redundant threads on the forum.. You already bombarded almost the same topics on each technical sections...
Kindly refer to your relevant old threads. Thank you.
EDIT: Yes. you can use a servo.. High Torque servo.
-underpazz campaigns for more technical post on technical threads
-underpazz campaigns for "no hijack policy" on technical sections
I am not reinventing the wheel, I am just making a difference.
Follow Forum Rules and Regulations
Search the forum before posting
Zero tolerance on spam
Stop thread hijack
Re: help me...
Offline zer0w1ng
  • Pogi/Ganda Points: 305
  • Enter any 11-digit prime number to continue...
    • The Cebuano Geek
Re: help me...
« Reply #2 on: November 11, 2008, 01:22:41 PM »
Normal servo motors could only turn 180 degrees.
But you could modify it to become like a DC motor with PWM speed control.
See here http://www.seattlerobotics.org/guide/servohack.html
This hack is very common to replace motors because they are geared thus having a high torque.
The Cebuano Geek
Re: help me...
Offline arkiose99
Re: help me...
« Reply #3 on: November 11, 2008, 01:38:52 PM »
wats da ideal motor should i use to my thesis?DC motor,stepper motor,or servo motor?.
Re: help me...
Offline zer0w1ng
    • The Cebuano Geek
Re: help me...
« Reply #4 on: November 11, 2008, 01:48:31 PM »
Depends on how large is your billboard.
With miniature models, you could use modified servo motors.
The next strong motor I could think and widely available is car wiper motors.
For industrial grade, either a 3phase AC motor or large DC motors like the one used for conveyors.
The Cebuano Geek
Re: help me...
Offline arkiose99
Re: help me...
« Reply #5 on: November 11, 2008, 02:02:05 PM »
ahh.k...salamat...........
remote control billboard kasi thesis namin...
useful bah ang remote control roll-up roll-down na billboard??
wats da advantage to my thesis betweem the autmatic billboard keeper....
give me some idea...
Offline mArKhAo
  • Pogi/Ganda Points: 70
  • point and shoot
Re: help me...
« Reply #6 on: November 14, 2008, 10:20:46 PM »
hehe remote? use bluetooth :)
Offline arkiose99
Re: help me...
« Reply #7 on: November 15, 2008, 07:49:55 PM »
RF po gamit namin....anong motor po bah ang dapat kung gamitin??
Offline bravokilo
  • Pogi/Ganda Points: 108
Re: can the servo motor can operate a roll-up roll-down billboard??
« Reply #8 on: February 19, 2009, 10:26:50 PM »
Arkiose99:
      I have the solutions to your problem but I might be too late. Remote can mean wired remote or wireless remote.  Just use DC motors.  For wired, use telephone wires. For wireless us and RC radio system.  you see, the DC motor can turn CW or CCW depending on polarities.  Use a DC motor, geared. No need to hack a servo.  you have to disable the pot anyway if you want long travel. Put a drum to roll in a cable. Then put "end switches" so you do not exceed opening and closing the canvass billboard I assume.  if you are talking actual huge billboards, use AC motors but you have to gear it for torque.  Tell me what size billboard are you talking about.  I only need to drop two wires to control a dc motor to run CW or CCW. To give you and idea, use a double pole, double throw sw with a center off. one side runs it CW, the other side CCW.  you just cross the connections on the two outside terminal where you have your battery connected.  The motor is connected to the middle pair on the sw. The end sw opens when you reach the end point. The line is in series to this sw. however you have a diode accross the terminals of the end sw. hen you reverse poles, the diode bypasses the sw and will run the motor the other way.
BravoKilo: Callme (8253867) or text me(09197726274) or email me at rcdevices@yahoo.com.ph. Text me when you email.
 :D
