Author Topic: cp to pc interfacing  (Read 1465 times)
Offline >>>vhinz08<<<
  • The best way to predict your future is to invent!
« on: November 12, 2008, 09:44:48 AM »
pa help naman po! marami naka post about this topic but, kailangan q po very basic at detailed interfacing para q po ma gets, triple A pa lng po me...
ano po ba software at type of connector at unit ng cp kailangan? pwede po ba 32xx or 33xx para mas acessable.
Ang gusto q po mangyari ung pwede makarecive ng message ang pc q through my cp or vice versa, in short pwede sila mag interconnect....
tnx in advance..
Aim high and hit the mark!
Offline zer0w1ng
  • Pogi/Ganda Points: 305
    • The Cebuano Geek
Re: cp to pc interfacing
« Reply #1 on: November 12, 2008, 09:55:19 AM »
gnokii http://www.gnokii.org/
It is customizable to what you will want to do.
The Cebuano Geek
Offline SpongeBob
  • Pogi/Ganda Points: 33
« Reply #2 on: November 12, 2008, 10:00:19 AM »
tnx in advance..
mahirap sa yo ang 33xx kasi FBUS protocol yan, gamit ka ng 6210 kasi Hayes ang gamit
« Reply #3 on: November 12, 2008, 01:31:07 PM »
ok! tnx po mga sir! pero pa help naman po if papano gagawin, meron po ba kau step by step procedure?
Offline zer0w1ng
    • The Cebuano Geek
« Reply #4 on: November 12, 2008, 01:37:15 PM »
You need to know and program in C language to modify the source according to your specifications.
The Cebuano Geek
« Reply #5 on: November 12, 2008, 01:41:30 PM »
yup! me knowledge po me bout C language! but i have no basic idea kung papano po gagawin! tnx po...
ano po ba dapat 1st step na gawin q?
tnx po...
Offline zer0w1ng
    • The Cebuano Geek
« Reply #6 on: November 12, 2008, 02:29:39 PM »
First you should know the what you need or requirements (the problem and solution).
Then you could analyze what part of the code to change or improve based on your requirements.
You could not go to the next step without knowing first what you what to do.
These are parts of the steps software development process (waterfall model):
Requirements
Design
Implementation
Verification
Maintenance
See here for more info http://en.wikipedia.org/wiki/Software_development_process
The Cebuano Geek
« Reply #7 on: November 12, 2008, 02:51:41 PM »
Start with aquiring the unit (6210) ang dlr3p cable.
Use hyperterminal to test your setup after that you can now develop your program.
« Reply #8 on: November 12, 2008, 02:57:37 PM »
what i want is kung pwede po mkahingi ng mga source code, at same time schematic diagrams para magkaroon po me ng idea, la pa po kc me idea eh, kahit ung pag connect lng ng cp to pc, no po ba port ang gamit? parallel, serial o usb po ba?
tnx po...
sana d kau magsawa sakin.... je je je..
Offline zer0w1ng
    • The Cebuano Geek
« Reply #9 on: November 12, 2008, 03:03:25 PM »
Source code is on the site I posted above.
For the connection, buy a nokia datacable to connect to the PC.
This is connected via serial port.
If you want to make your own see here http://www.panuworld.net/nuukiaworld/hardware/cables/fbus.htm
The Cebuano Geek
« Reply #10 on: November 12, 2008, 03:12:04 PM »
thnx po mga sir!
GOB Bless....
